Question about Fisher RS929 Receiver
I have one RS-929 amplifier in my hand. STK401-140 was short, I gave change a new one for it, but no audio sound after then. Can you send me a schematic diagram if available. Thanks Jack
What kind of dvd player and tv do i need for my fisher rs 929 receiver
Whatever your budget can afford. There is no special TV or DVD player required.
Aug 27, 2014 | Fisher Am Fm Stereo Receiver Tuner...
My Fisher RS 929 controller board(front panel board)and the tuner board has failed. Where can I source these boards?
Unless someone has NOS parts most likely new boards are not available. (New old stock) I would check ebay unless you have some electronics repair experience. I would be glad to walk you through some test procedures.
Feb 21, 2014 | Fisher RS929 Receiver
Keeps blowing fuses
Possible replacement, try disconnecting the earth wire from the unit and connect the fused power wire to see if the unit is being grounded by the car or an internal short, Alternativle supply a seperate earth wire to the body of the unit. Ebay have stacks of these at great prices, hope this guide sets you on the right path, good luck
Jun 01, 2010 | Kenwood KAC-929 Car Audio Amplifier
What's the final loss to shopkeeper??
The actual loss is of Rs 10/- Only. to first shopkeeper.
May 25, 2010 | Computers & Internet
Can you power 2-10" subs and 2-6x9 speakers with this amp?
You could but the only problem is even if you ran the speakers in parallel, meaning + to + and - to -, the best power you would get out of the amp is 230 watts per channel. Would probably make your 6x9 sound good but not enough to push your 10's.
Nov 19, 2009 | Kenwood KAC-929 Car Audio Amplifier
My Kenwood KAC-929 gets power but DOES NOT put any sound out. Whats My Possible problem(s).
Hello Spicer_kyle6,
Possible problems: 1) No output from the head unit. Try a different set of preamp outs. 2) No input to the amp. Check the RCA's and make sure that they are good and coming from a functioning preamp or subwoofer output on the head unit. 3) Input gain turned off or down too low. 4) Speaker wiring shorted, grounded, or open. Check all wires. 5) Speakers defective. Connect to a known good output to test. 6) The amp itself could be defective and still show a power-on indication.
Hope this helps.
Apr 28, 2009 | Kenwood KAC-929 Car Audio Amplifier
No sound from my woofer
Check your speaker connections... try using a multimeter set to "OHMS" and see if the speaker is reading around 4-8 ohms... if it shows no reading there is no continuity in the coil of the speaker
Mar 24, 2009 | Kenwood KAC-929 Car Audio Amplifier
Kenwood KAC-929
From the Input of amp, just connect cheap speaker with wires to input of amp.
If you have sound from speaker, most likely the amp is bad or loose connection.
Dec 25, 2007 | Kenwood KAC-929 Car Audio Amplifier
Top Fisher Audio Players & Recorders Experts
Henry  Thomas
Henry Thomas
SHARCNET-USA
SHARCNET-USA
Are you a Fisher Audio Player and Recorder Expert? Answer questions, earn points and help others
