Question about Fisher and Paykel Washing Machines
I purchased Fisher paykel washing machine from New zealand.Model no is IW 512 & sr No 552634 nz.I am getting fault code of 49.Please advise. The following are other symtoms It stopped abruptly after filling some water .The electric supply went off.On restoration of the power supply,it could not be restarted &it shows the fault code of 49 only.Now it is not possible to do any function.The water accumulated in the drum also cannot be drained,The door lock swich is ok. Your earliest action will be highly appreciated as there is no competent technician to atted this fault in India.Pl help Regards Arvind
  • 343 Answers
Fault code #49 is 'faulty cold inlet valve' You need to replace it with another COLD valve as F&P says they are different to the hot valve.These valves do not use mains voltage and must be replaced with the F&P part. Access via the 2 screws at the rear of the facia.
Remove the inlet valve retainer via the 2 screws between the inlet valves.
TIP.... I cut away the top of the valve slot so that the valve can be lifted straight up and out, without having to move the mixer box or spill any panni.
Don't forget to swap the seal from the old valve to the new one.
Once the valve is replaced the retainer makes everything secure again.
Good luck....Nomess
Posted on Aug 26, 2010
Testimonial: "Subsequently a local technician checked the machine.He checked the output voltage of PCB,which is hardy @3 volts.The cold inlet valve rating is 12v.He interchanged input wires to cold valve with hot water valve.Then also it didnot work.I told him the hot water valve will receive supply only when it comes in cycle of hot water requirement.I think he is not convinced.He said there is some fault with PCB.He fills that some tracks of PCB are broken.He repaired thesuspected tracks nicely.The problem still persists."
  • a2zmodi Aug 26, 2010
    Is the 3v output at for cold water valve? Are you convinced with My logic of hot water su pply?
    How shold confirm the PCB defect?Further guidance please.THanks
Fisher paykel aquasmart fault 49
Fault code 49 is water valves, But the Aqua-Smart board is outputting the wrong code here, The Smart pump has blown the water valves fuse, A common thing in Aqua-Smart Machines.
The Smart pump has jammed with lint and caused over current to the board and taken out parts on the board that drive the pump.
Best to get a new/recondition board for your machine.
Apr 20, 2013 | Fisher and Paykel Aquasmart wl80t65c
Fisher paykel aqua smart fault 49
Fisher and paykel toploader washing machine fault 49 water valves all show 60 ohms next step?
Fault code 49 is water valves, But the Aqua-Smart board is outputting the wrong code here, The Smart pump has blown the water valves fuse on it's overload, A common thing in Aqua-Smart Machines i always keep seeing,
Nov 26, 2012 | Fisher and Paykel Washing Machines
My Fisher & Paykel smart drive excellence 5.5 (New Zealand) has suddenly decided to be strange - after a wash and spin, the long wash and spin lights come on and the machine emits a long continous...
this sounds like a computer error asthe first and last lights is an error code 129 which does not exist if its the first and second to last light then its a sensor fault
Nov 14, 2017 | Fisher and Paykel Fisher & Paykel Washer
What is error code 136 on a fisher & paykel IW709AU top load washer
136 fault is 'motor stall'...Quite often this is a broken wire to the motor. However it could also be a Motor fault, or Rotary Position Sensor problem. Water damage can cause this fault as well. After a visual check for broken wires or water damage, and if your machine is in good condition, you should consider a tech....Good luck...Nomess
May 20, 2010 | Fisher and Paykel Fisher Paykel Intuitive...
Fisher Paykel Intuitive Eco Washer - IWL15: what is error code 136 on a fisher & paykel IW...
fault code 136 is a hard one possible causes are faulty rotor speed sensor on motor,siezed bearings or rotor,motor windings ,or motor control module, would suggest you get a tech for this one to diagonse correctty ,without proper tools to test eg: rss tester you could cot yourself more money... hope this was some help....:)
May 18, 2010 | Fisher and Paykel Fisher Paykel Intuitive...
Code 49
it probably Needs a new cold water solenoid valve.
Sep 02, 2009 | Fisher and Paykel Fisher Paykel Intuitive...
F&P Intuitive WM. Needs Bearings and seals replaced
Hello you can get the parts from any New Zealand F & P service center( $50-80nz). You need a special F & P tool kit (you can buy for around $100nz from F & P also) to remove the seal and bearings and to insert the new. unless you know an appliance tech or have a service manual it could be a tricky one. cheers
Please Rate my Advice
thanks
Steve
Feb 22, 2009 | Fisher and Paykel Fisher Paykel Intuitive...
Code 49 and Manual Book
Fault 49 usually points to the cold inlet valve. I have come across many with this fault that the valve tests ok and it needs the motor controller replaced.
Jan 06, 2009 | Fisher and Paykel Fisher Paykel Intuitive...
Washing Machines Logo
119 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Gerry Harvey
Gerry Harvey
michael_t919
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
