Question about LG DLG5932W Gas Dryer
My LG Tromm DLG5988W is not getting hot and drying clothes. I cleaned the sensors, lint filter, ducts, etc. I noticed that the cooling light stays lit, while the dry light flashes
SOURCE: LG Tromm dryer now takes two cycles to dry a load
Rob, sounds like you're on the right track. The other things that could be bad is part of the heater coil is out or, less likely, that you have thermostat or high limit switch issues. These will likely require a service person to resolve. Good luck, sir.
Posted on Dec 24, 2007
  • 4 Answers
SOURCE: DLE5955 Tromm Dryer. We have had
Sounds like your outside vent is plugging up. Go outside your house and check for lint build up and just pull it loose with your fingers or a shop vac.
If it's not obviously plugged from outside, feel the volume it should be significant. If it's very weak (while running of course) your ductwork may be plugged elsewhere, for example at an elbow, or the joint between a flex hose and the actual duct.
Posted on Jun 26, 2008
  • 3 Answers
SOURCE: dryer LG DLE5955w
are you missing any socks? if so you need to throughly check the duct chamber in the machine, get it serviced this is a fire hadzard.
Posted on Jun 23, 2009
  • 574 Answers
SOURCE: LG DLE2512W Will not heat even after replacing Heating element.
there are a couple of thermal fuses also that could be blown inside the back check these also
Posted on Aug 25, 2009
  • 3 Answers
SOURCE: LG TROMM DRYER DLE5977 Burning Smell
It is a POS dryer, we have the same one. My suggestion get another dryer. We vacuumed it all out (don't you have a problem with the lint catcher?) Then it started loud pounding noise, which a lot of people seem to have the same problem, then our sensor went out and we had to dry the clothes 5-10 x's...now crack in stainless steel drum and is chewing up all our expensive clothes!
Posted on Dec 31, 2009
It take 3hrs to dry clothes
Check and clean the lint filter and all the duct work on the dryer and the external duct vent for lint buildup.
Jan 02, 2011 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
My lg tromm DLG69885 gas dryer is not heating; otherwise it works fine. Dry light flashes cooling light stays on solid
I am using LG Tromm DLE2514 washer dryer. It 's running but didn't dried the clothes. I clean it's lint but still it's not working. The one thing i notice now is it's drying light is blinking and cooling light is turn on all the time during the cycle. So what's the problem with my dryer?
May 20, 2010 | LG DLG5932W Gas Dryer
Slow to dry
Hi!!
Have you cleaned the filter and the exhaust duct??
Lint plugs therm up, the heat sensor shuts off heating element thinking it is hot enough. Result: Clothes not getting dry.
Unplug duct and clean it, also clean the exahust passage of dryer. (where duct hooks to dryer)
Click below if this was helpful, Good luck.
Mar 28, 2010 | Dryers
The check filter light keeps coming ob to my lg tromm dryer model dle2514w. I cleaned the lint filter and also cleaned the air duct in theback, what else could this be
Clean the vent all the way to the outside.
The dryer will take 4-5 loads to reset the filter sensor.
Mahe sure the vent is not smashed behind the dryer.
Jan 18, 2010 | LG DLE2514 Electric Dryer
Model DLE7177RM, takes about 3 hours to dry a load of clothes. Dryer is NOT overloaded.
Does the dryer heat up or is it just cool air drying the clothes ? If it does actually dry the clothes eventually then it sounds like it is heating up. First thing to check would be exhaust hose. Is warm air blowing out of it ? If warm you got heat. If cool then your heating element isn't working. It should be fairly strong current of very warm air. If weak but warm, then somewhere between lint filter and end of hose you have a blockage caused by lint buildup or hose is bent and blocking air flow. Check hose first. You can disassemble lint trap and go beyond the lint screen into metal duct within dryer and clean with a long brush and vacuum. You can also disconnect exhaust duct flexible hose at back of dryer and work through metal duct from that end too. If you notice increased air flow then it should solve problem,
Aug 05, 2009 | LG Dryers
Feb 21, 2009 | LG DLE5977 Stainless Steel Electric Dryer
DLE5955 Tromm Dryer. We have had this dryer for 3 months. The cooling light has started to come on during the entire cycle and stays lit. Clothes are not drying as quickly as before. They are damp at...
Jun 08, 2008 | LG Dryers
Lg tromm front load dryer dlg5988w
dryer has two fuses check both circuit breakers one is for heating the other is for the plug this fixed my front load lg this gives you the heat that you need to dry your clothes
Mar 01, 2008 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
The problem with the LG tromm dryers are seemingly two fold.
1. The dryer stops heating and drying the cloths. I found out AFTER HAVING IT SERVICED TWICE AND WAITING A MONTH FOR A NON ESSENTIAL PART. The problem turned out to be the dryer vent going from the wall to the outside was severly clogged. Once this was corrected the dryer worked great.
2. The second issue probably is a design issue in that a large amount of lint seems to get by the lint filter and ends up in the vent that the dryer is connected to and goes out side the house. In my case I have a long dryer vent imbeded into the wall to the exterior, in a shorter vent this probably wouldn't be an issue.
Dec 20, 2007 | Dryers
LG DLG5932W Gas Dryer Logo
427 people viewed this question
Top LG Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Mike
Mike
Are you a LG Dryer Expert? Answer questions, earn points and help others
