My themostat goes into a flashing mode> - Heating & Cooling
    Problem Solver:
  • 28 Answers
You need to reset it by pressing the very small button located near the other controls it is small enough you will need a sharp object to push it
Posted on Aug 26, 2010
2006 vector get flashing oil light twice then shuts down
Maybe its trying to tell you something. Low oil or no oil flow, try replacing level sensor.
Feb 15, 2016 | Yamaha 2006 RS Vector GT
What makes a 1995 geo tracker idle up and down when it is low on water
low , you mean the radiator is low? inside it?
why is .>>? fix that first.
but when the RAD goes slow so does the water near 3 things.
the themostat does not work in air, it goes NUTS.
same with ISC valve (speed controller)
same with IAC valve .fast idle valve.
same with ECT sensors.
the EFI system can not work right at all low on water, this is called
a first order failure.
Jun 24, 2014 | 1995 Geo Tracker
After flashing with mx key phone goes in restriction mode plz???????
Hi.Its easy just follow this, after you have done" BusCheck" Go to "Service">>IMEI & Security>>Simlock >>and select "Repair Simlock" again press "Repair Simlock". Good luck.This trick is a kind of unlock.
Oct 10, 2011 | Nokia 3110 Cellular Phone
My micro sd card cannot autoplay. I can see my pictures using my digicam but when I connected it to the computer, the Avira anti-virus pop up saying that the autorun was blocked. I can't see any...
I found this on the link below. All credit goes to the original poster. hope it helps.
Go to Avira's configuration > click Expert Mode > Guard > Scan > Further actions > untick the "Block autostart function" option, click Apply
http://forum.avira.com/wbb/index.php?page=Thread&threadID=113239
Jul 14, 2011 | PNY 2GB microSD Memory Card
I have a Bosch dishwasher model # shx4ap05uc/06 and I want to silence the alarm for when it is done. It goes off every 10 minutes until you open the door
Yes, you can switch the cycle completion signal off (or raise/lower the volume)
1. Switch the dishwasher off using the ON/OFF button
2. Open the door
3. Switch the dishwasher on again. (One of the wash cycle LEDs will flash.)
4. Hold the > button in. Continue holding it and press and release the Start/Reset button once, then release the > button.
"Clean" and one other LED should now be flashing. This indicates that the dishwasher is in the options/settings mode. If they are not flashing, start over at step 1.
5. Press > repeatedly, until the LEDs for "Clean", "Sanitized" and "Rinse Agent" are all flashing.
6. Press repeatedly until none of the LEDs are flashing.
The number of flashing LEDs indicate the volume setting . . .
0 = Silent
1 = Volume level 1
2 = Volume level 2
3 = Volume level 3
7. Press the Start/Reset button once to save the setting and exit the options mode
8. Close the door
9. Switch the dishwasher off.
Hope this helps. Please let me know if you need further assistance.
Regards,
BElectric
May 27, 2011 | Bosch Dishwashers
How to adjust the time on a CASIO W-59 watch
Hi Harry,
Your Module number is 2271.
1. To set the time, press and hold button A (left top) until Seconds digits start to flash.
2. Press button D (lower left) to move flashing in the following sequence to change other setting:
Seconds >> Hour >> Minutes >> 12/24 Hour Format >> Year >> Month >> Day >> (Then back to Seconds)
3. While a setting is flashing, use E (+) (bottom right) and B (-) (top right) to change it.
Note: When in the 12/24 Hour Mode, use E and B to toggle between 12-Hour and 24-Hour Mode.
4. Press buton A to exit setting screen.
Your time should now be set.
You may also download a manual for watch/Module number:
http://pathfinder.casio.com/resource/manuals/module_2271.pdf
This should give you all the info you need to operate all the functions of your watch. Thanks.
Regards, Bill
Sep 27, 2010 | Watches
My lexmark blinks green but wont turn on everytime i try to turn it on it just spins for a second and goes right back to blink mode
The flashing green light probably means communication error, it is not normal.
These Dell/Lexmark comm. errors can be difficult.
Try this:
Start > Control Panel > Printers2_bing.gif and Faxes > RtClick Your Printer (default) > Properties > Advanced (on mine) > Check "Print Directly to Printer"
Feb 12, 2010 | Lexmark Z2420 Printer
My LG flatiron W1943TB turns on, says analog power saving mode, goes black and then the power button flashes.. but the monitor is hooked up to my dell notebook bc my LCD died
Hi erin mckinle,
That is probably it's, uh, analog power saving mode. When the screen goes black and the power button flashes, make some mouse gestures or hit some keys that would not affect anything (try spacebar). That should bring up the screen. If you think it goes into power saving mode too fast, go to Control Panel --> Power Options, and change the values. Hope this helps.
Jan 02, 2010 | LG W1934S-BN 19" Monitor
How do I set the clock on Accurian IPod docking alarm clock
When in standby mode (press and hold power button to enter standby), press MODE. Now press |<< TUNE/SKIP >>| to set 12-hour or 24-hour display mode. Press MODE to confirm display setting. The display flashes. Press |<< TUNE/SKIP >>| again to set the hour, then press MODE. Press |<< TUNE/SKIP >>| to set minutes, then press MODE to confirm the time.
Nov 12, 2009 | Digital Products International ILIVE...
How could i reduce the volume pls help
*#3646633# > (3)audio >> (1) set mode
select normal mode......!!!!!
your mobile's volume will be adjusted to normal...
mail me for further queries at shukla.thunder@gmail.com
Apr 09, 2009 | Sigma E500 ST for Canon Flash
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
Mack Baxter
