Question about Samsung CLP 300 Laser Printer
Samsung 3160fn all in one printer. making loud clicking noise when printing
  • Anonymous Jun 29, 2008
    Loud clicking noise when printing. Toner access door keeps coming open
  • 4 Answers
Here's what I posted in regards to my CLP 300 which had the same problem. Might be the same thing??...
Mine did this after I replaced a toner cartridge (the round ones). Here's what causes the loud clicking:
Some (most?) replacement ink cartridges have a little square chip -- like a mini circuit board -- on them which gives the printer information about how full they are. This is located on the insertion end, right next to the round black thing with the little gears on it.
For the cartridge to go in all the way, and allow the gears to properly "seat," the square "circuit board" needs to "float" just a little on the spongy thing it's attached to. So when you push the cartridge in FIRMLY, the gears seat, and the "circuit board" will end up getting pushed in about 1/16 of an inch.
I think what happens in some cases (at least with mine) is some cheap replacement cartridges don't let the "circuit board" push in at all, which means the gears don't quite seat properly, and, as they are trying to connect on the printer's gear receivers, they are constantly connecting and disconnecting, causing that loud clicking noise.
On one cartridge just pushing in the "circuit board" really hard freed it up and allowed it to "float" (be pushed in little when the cartridge was then inserted). In another case, I ended up getting a butterknife and prying off the circuit board (breaking the plastic or glue seal that was holding it) then setting back in, on top of the little spongy sticky thing it's supposed to float on.
In both cases, the cartridges were then able to go in all the way, and the clicking noise stopped.
Hope this helps!
Posted on Aug 06, 2008
  • whitehorse1 Aug 06, 2008
    By the way, when I spent 30 minutes on the phone with Samsung about this, they were about as helpful as a fart in the wind!
    Welcome Back:
    Visited the website for 2 consecutive days.
This also applies to Samsung CLX-2160. After cleaning blades and reassembling I got that loud clicking noise. The black toner cartridge wouldn't go all the way in. A little persuasion was used to push it in further and the noise stopped.
Posted on Apr 14, 2010
  • Samsung Expert
  • 113 Answers
This can help too by knocking on the black toner on the floor and turn the black tomer gear and place it back. this sometime is course by the toner gear jam. usally this will sole the clicking sound.
Posted on Apr 17, 2010
2 Suggested Answers
  • 4 Answers
SOURCE: Hi I Samsung CLX-3160FN All-In-One Printer and
You need to use fesh toner, or could LPT ports setting from your BIOS of your computer is not proper as per the requirement.
Posted on May 01, 2010
My Samsung scanner says "Scanner Locked" What does this mean. It makes a loud clicking noise like it is about to breakdown.
If you look into the paper output of the printer you find a green lever. Pull it to the front. Open scanner lid and check the position of the lever.
Restart printer by switching off and on again.
Oct 20, 2010 | Samsung CLX 3160fn All-In-One Printer
My printer samsung CLX-3160FN, does a strog
There is mechanical problem with your printer so that printer need servicing.
Feb 24, 2010 | Samsung CLX 3160fn All-In-One Printer
Samsung clx-3160fn won't print
Usually I've seen that happen when you use generic toners. There are 4 toner clutches down the right side, with the right cover off you can see which clutch is doing the grinding. Many of the generics are overfilled and hard to turn and will make the noise until you loosen them by hand turning them til they loosen up, or just replacing.
Dec 28, 2009 | Samsung CLX 3160fn All-In-One Printer
Why Samsung CLP-300 Printer making annoying/loud clicking noises?
So try to get the black toner cartridge out of the Machine. On zhe backside of the Cardridge is a gear. Try to turn the gear, maybe the Toner inside is clump together. When you can turn it very easy in both directions it's fine.
Oct 19, 2009 | Samsung CLP 300 Laser Printer
Cant receive faxes
Did you try to check the toner?
Try to print if the copy is lighter than before or it cant copy or print then you need to replace your toner cartridge.
Hope it can help you. (" ,)
May 22, 2009 | Samsung CLX 3160fn All-In-One Printer
Samsung 3160N - clicking sound but printing okay
Check the toner cartridge make sure it is all the way in. Also full out all those toner cartridges and check the gear that rotates when you print see if there is no broken teeth. This happens on mine too.
Mar 05, 2009 | Samsung CLX 3160fn All-In-One Printer
Samsung printer, transfer belt error message
Check on you drim uint the gears damaged.
Aug 06, 2008 | Samsung CLP-500 Laser Printer
Hard to tell without hearing it. But, if it is doing it all the time it is turned on but not in use most of the time that would be a fan making the noise. The other suspect would be a fault toner cartridge or the fuser. you may need to have a tech look at this.
Hope that helps...
Jun 16, 2008 | Samsung CLX 3160fn All-In-One Printer
Terrible noise when printing
turn off, remove the cartridge and turn back on, do you hear the noise? if no then it's the cartridge
hope this helps
Jan 07, 2008 | Samsung CLX 3160fn All-In-One Printer
Samsung CLP 300 Laser Printer Logo
572 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
