I am geeting error code 48 on my phaser 7750dn
    President:
  • 2,072 Answers
That is a fan failure code, Either the Fuser fan ( most likely) behind the back cover near the front.Low voltage power supply fan or rear cover fan is not operating.
Most of the time it is the fuser fan that is not running or even if its running slow it will give you that error code.
Here are the notes
Problem:
    Fan Failure Message (Code / Error 48)
Cause:
    The machine logic detected a failure of the Fuser fan, LVPS fan or rear fan.
Solution: i am geeting error code - thumbsup.gif Fixed! thumbsdn.gif Did not fix.
  1. Insure there is adequate ventilation around printer. Refer to Section 1 of Service Manual for required clearances.
  2. Follow the procedure in Chapter 3 for this error.
  3. This problem can be very intermittent. Fans can work in diagnostics and fail in the middle of large print jobs. If unable to duplicate problem replace all 3 fans.
  4. Use service diagnostics to verify the Fuser, LVPS, and ROS fans. These fans have a third wire which provides feedback to the Engine Board.
  5. Visually check each or these fans for a build up of dust or toner.
  6. There is a correction to this procedure in the Service Manual. The fans that can cause this error are the Fuser, LVPS, and ROS(laser fan). Not the Rear fan. The rear and bottom (developer) fans are not monitored by the system and won't generate this error.
Parts that may resolve this issue are:
  • FAN ASSEMBLY, FUSER (63%)
  • FAN ASSY; LOW VOLTAGE POWER SUPPLY (45%)
  • FAN REAR ASSEMBLY (Laser Fan) (25%)
Posted on May 05, 2008
Error code 14 ; says cyan sensor malfunction. Where is sensor and how might I clean it?
E-mail me at rak458@aol.com.
I can't post all of it on here.
Just put Phaser 7750 in the subject line.
Jan 15, 2010 | Xerox Phaser 7750DN Laser Printer
Error Code 9-456
This error code means the life of the black developer is at its end. It is probably time to replace all four developers and the only reset is replacing the engine control board.
The costs will come around 1000usd I recommend you buy a new one.
Jun 18, 2008 | Xerox Phaser 7750DN Laser Printer
Code 35
This code means that the fuser Main Lamp has failed and your fuser won't heatup so the sensor that controls the temperature gives that error and you have to replace the fuser part number 115R00025.
Open the left cover unit and you should see the fuser held down by two orange plastic screws and it pull it out from the green handles and that's it.
Good luck!!
Dec 03, 2009 | Xerox Phaser 7750DN Laser Printer
Error code 7-402
Error codes 7-401 to 7-404 are life end for the tray rollers. If no jamming probs then enter diags mode (Back and'i' buttons and switch on) scroll down to NVRAM access and select. find CRU counters and select, clear each tray counter and then exit.
Jun 01, 2009 | Xerox Phaser 7750DN Laser Printer
Xerox phaser 7750gx
Hiya,
Can you be more specific regarding the Engine Logic Board Failure as in is it timing, rom/ram, micor pitch or NVRAM as code 80 is a failure code for
Engine Firmware Halt Failure .
Ta
Nov 01, 2008 | Xerox Phaser 7750DN Laser Printer
Phaser 7750DN fan failure Error Code 48
Yep, the fuser fan is he one that fails. You can remove the top and rear covers and then carefully remove the shrouding and whatever else makes it easy to get at.
What you can do if you dont have a fan handy is, remove the silver label on the fan. Behind that label there is a black rubber cap over the bearing in the fan. You can flush that bearing out with alcohol several times and then use a very highly refined oil , to lubricate it. Just pretty much fill up that little hole around the bearing, put the rubber cap back on and then wipe it clean with alcohol and tape it back on.
If you need a fan, Go onto google. Type in ( the parts drop) not parenthesise.and call them, Ask for Britt, I dont work for them, but they are 100 percent professional and will charge you a fair price.
Cleaning and lubing will fix it about 60 percent of the time.
Sep 19, 2008 | Xerox Phaser 7750DN Laser Printer
Xerox Phaser 7750
There is a motor in the laser called the polyogon motor, It turns the mirrors in the laser.
It most likely is not starting fast enough.The laser isnt that hard to remove. But if it has failed, it is pretty expensive.
Let me know if you want to attempt to pull it.
Sep 10, 2008 | Xerox Phaser 7750DN Laser Printer
Xerox Phaser 7750DN FUSER JAM
Are you getting a specific code? 10-XXX ?? That would help narrow it down.
May 06, 2008 | Xerox Phaser 7750DN Laser Printer
Xerox Phaser 7750 code 35
Somehow you jarred the fuser. Turn the machine off and reseat the fuser. Open the left side door, there will be 2 thumb screws.
Remove and reseat the fuser, if that doesnt work you have to replace the fuser.
Apr 05, 2008 | Xerox Phaser 7750DN Laser Printer
1,038 people viewed this question
jasbo
jasbo
