I have an hp OfficeJet G85. The automatic document feeder won't work about half the time. Is there a way to clean or fix the feeder? Everything else works fine.
  • 905 Answers
Depends on how the ADF is malfunctioning. If it just plain doesn't work, then you are likely looking at a control cable / connector issue.
If it grabs multiple pages at same time, or doesn't want to grab pages at all, you can try using a "cleaning sheet" available for inkjet printers. Most office supply stores will sell these. The cleaning sheet helps to clean the paper path (wheels, idlers, etc). You should also be able to pop open the ADF cover, and remove any paper debris that is present. See owners manual for this procedure though, it is easy to break the cover.
Posted on Aug 25, 2010
Testimonial: "thanks i'll try that"
Multiple pages feed when printing on hp 7410
  • If the automatic document feeder (ADF) does not pick up any pages at all, the rollers inside the automatic document feeder need to be cleaned.
  • If the automatic document feeder picks up multiple pages instead of single sheets, the separator pad inside the automatic document feeder needs to be cleaned.
SolutionLoad one or two sheets of unused plain white full-size paper into the document feeder tray, and then press Start Copy Black to pull the pages through the automatic document feeder. The plain paper releases and absorbs residue from the rollers and separator pad.note.pngNOTE:If the automatic document feeder does not pick up the plain paper, try cleaning the front roller. Wipe the roller with a soft lint-free cloth dampened with distilled water. If the problem persists, or the automatic document feeder does not pick up the plain paper, clean the rollers and separator pad manually. Follow the procedures below to remove the face plate from the front of the automatic document feeder, access the pick assembly inside the automatic document feeder, clean the rollers or separator pad, and then reattach the face plate.
Please Click on this link to know more in detail.
Thanks
Apr 01, 2012 | HP OfficeJet 7410 All-In-One InkJet...
What does "Original Jam" mean and how do I fix it?
Your "original" document -- the document that you are trying to copy, has jammed inside the printer's sheet-feeder.
Remove all the pages of the original from the "input" tray, and then look for a "missing" page -- one of your original pages is "jammed" inside the printer.
Jun 10, 2010 | HP OfficeJet G85 All-In-One InkJet Printer
Hp officejet pro L7590 - automatic document feeder will not pick up - how do I fix this problem?
Hi
Check the following
--Check the paper in the ADF (automatic document feeder)
--Make sure the ADF pick assembly is in good working condition
--Remove the document feeder and open the ADF cover.
--While lifting the blue-green lever, carefully rotate the pick assembly toward the open ADF cover until it stops.
--Make sure the bottom roller is held firmly in place by the two-catch, which is located to the left and the right of the roller.
--Clean the rollers and separator pad
Mar 03, 2010 | HP Officejet Pro L7590 All-in-One InkJet...
My Officejet G85 does not from a document
Ensure it is installed (use the driver CD) and set it as the default printer in Control Panel > Printers.
Jul 08, 2009 | HP OfficeJet G85 All-In-One InkJet Printer
The copy paper feed misaligns and jams, what's the fix? Jack
to fix misalign and paper jam problem, follow this steps.
NOTE: If the automatic document feeder does not pick up the plain paper, try cleaning the front roller. Wipe the roller with a soft lint-free cloth dampened with distilled water.
Follow the steps below to clean the rollers or separator pad.
1.Lift the cover of the automatic document feeder. This allows access to the rollers and the separator pad.
2.Lightly dampen a clean, lint-free cloth with distilled water, then squeeze any excess liquid from the cloth.
3.Use the damp cloth to wipe any residue off of the rollers or the separator pad.
4.Close the cover of the automatic document feeder.
This should solve the problem. Cheers!
Apr 25, 2009 | HP Officejet 6310 All-In-One InkJet...
Document Feeder Problem
There is no such manual for the HP OJ G85. Disassembly is not complicated. Just take your time.
Inkworks
866-381-0541
Sep 10, 2008 | HP OfficeJet G85 All-In-One InkJet Printer
Vertical paper feeder for the copier not grabbing next original sheet
I'm having a similiar problem. Can't consistantly feed one sheet at time. If i load several sheets it pulls all through, etc
Sep 03, 2008 | HP OfficeJet G85 All-In-One InkJet Printer
Printing thick black lines in copies from the automatic document feeder but not from the scanner
You can remove the plastic knob by pulling it gently forward and disconnecting it to clean inside and then reconnecting and closing again.
Jul 29, 2008 | HP Officejet 5610 All-In-One InkJet...
The feed on the printer quit
The automatic document feeder plug is on the back of the feeder and plugs in to the lower half of the printer in the back. You can't miss the round plug hole. Pretty staight forward.
Inkworks
May 15, 2008 | HP OfficeJet G85 All-In-One InkJet Printer
Top feeder won't work properly
hello!
have you tried cleaning the separator pad inside the automatic document feeder?
try to Load one or two sheets of unused plain white full-size paper into the document feeder tray, and then press Start Copy Black to pull the pages through the automatic document feeder. The plain paper releases and absorbs residue from the rollers and separator pad.
If the problem persists, clean the rollers and separator pad manually
May 07, 2008 | HP Officejet Pro L7680 All-In-One Printer
79 people viewed this question
k24674
