Question about Kyocera FS-4000DN Laser Printer
I have another Kyocere fs-1800. This printer will take the paper from the bypass tray first if I have paper in the bypass tray. If not it will take it from the drawer. I have purchased a fs-4000dn. It will only take the paper from the drawer. I can not get it to take the paper from the bypass tray. Is there a setting somewhere that I need to set to make it take paper from the bypass tray first?
    Sergeant:
  • 223 Answers
Surf to Kyocera's website, download the latest software for your operating system, once you have the software installed you should be able to set all the options you would like in the printers control panel. such as start.. printers and faxes..... right click printer go to properties for all tray assignments and settings. (this instruction is for windows) bypass must be selected after you select print. hope that helps.
Posted on Aug 25, 2010
    Sniper:
  • 62 Answers
Under paper handling for mp tray (bypass) change the feed select to manual tray instead of cassette..then when you have paper in bypass it will pull first
Posted on Sep 23, 2010
4 Suggested Answers
  • 62 Answers
SOURCE: set up KYOCERA FS-1350DN printer
you need to scroll thru your menus...paper handling section...make sure mp tray is set to FIRST..that way it will pull from the mp tray untill it is empty than switch to your cassette
Posted on Jan 06, 2010
  • 62 Answers
SOURCE: Kyocera FS-4000DN Laser Printer call for service
that's just a toner motor error..most likely the toner was not put in properly..remove the toner than reseat the toner making sure it snaps secure into place..you should than be fixed
Posted on Feb 01, 2010
  • 233 Answers
SOURCE: how to i stop paper jams on kyocera ecosys
The first thing you need to do is open the device and clear any debris: leftover paper pieces, toner, etc. If this does not fix the jamming, the device could use a more thorough service. Inspect all of the moving parts and make sure that they are firmly attached. If it's possible to tighten down some components, a minor tweak with a screwdriver can work wonders.
Something a little unorthodox, but that has helped me in the past is lubrication. You could try lubricating the printer with mineral oil or paper shredder oil. There are two ways of doing this. You could open the machine up, locate rollers and then brush the oil onto the rollers. Or you could simply put a very then layer of mineral oil on a piece of paper and then run the paper through the machine. The first few pages out of the machine will have oil on them, but after a half dozen pieces or so, the parts should operate more smoothly and be less likely to jam.
I hope that helps.
Posted on Mar 01, 2011
Konica Minolta BH164 Copier gets paper jam in LGL and FS size papers only what to do
then place the LGL and FS in tray one does it work??? is this printing or copying???
Jul 11, 2016 | Konica Minolta Office Equipment & Supplies
How do you use the bypass tray on a Kyocera FS6525MFP ?
All the information for your product can be found here, including documentation, drivers, etc.
http://www.kyoceradocumentsolutions.eu/index/products/product/fs6525mfp.html
Hope this helps, Nik.
Jul 14, 2015 | Kyocera Ecosys FS-6525MFP Laser...
How do I get the pritner to pull paper from open tray if there is an envelope or special paper being used?
You need to set the correct paper in the bypass tray settings on the machine. Once that is input you will have to tell the printer that you would like to print on envelopes through the bypass tray. This is done through the printer preferences. Hope this helps!
Oct 07, 2014 | Kyocera Mita FS-4100DN Mono Laser Printer
Messege * load mp tray * but tray has plenty of
MP tray is not the cassette it this flap that pulls down above it.
The machine will revert to asking to place paper in its MP tray when the information it is receiving about the document from whatever program tell it that the size is not the same as what the cassette is set to...
so, check page size in of document in word program or whatever you are using
also check paper type and size settings match those you just checked in the printers properties under printers in control panel.
If you put a piece of paper in the MANUAL BYPASS TRAY bot the cassette it will print on that.
To get evverything back to normal, turn off printer, delete jobs in print que, change paper size of document in word/excell/etc is set same as paper type in printer, print again.. all should be good...
p.s. these are good quality printers that why I bother to answer you... cheers
Nov 12, 2009 | Kyocera FS-2000D Laser Printer
Kyocera fs-3900DN
Very weird message! Pull down the by-pass tray in the front of the printer and insert a sheet of paper , then print.
Jan 14, 2009 | Kyocera FS-3900DN Laser Printer
Kyocera FS 9130DN is showing MP tray transport jam and to open front cover. No paper is jammed or in the machine.
check the bypass transport connector for a small piece of paper. or the paper sensor arm is jammed down there are 2 one in the transport unit and one in the mp tray
Nov 03, 2008 | Kyocera Office Equipment & Supplies
Kyocera Printer FS-1800 plus - paper jam Can't find the printer manual. Please provide steps to clear the paper jam and reset the printer.
Hi, first of all,pull out paper tray and check any paper,or scrap jammed.When paper tray is pulled out,open paper transport unit-You have green handle on the right side of machine,in the place of right side of paper tray.Pull out paper transport and remove paper.Just close paper transport unit and paper tray,open and close top cover.
Nov 29, 2007 | Office Equipment & Supplies
Kyocera FS-1920 won't pick up paper from tray
replace pick up rollers and paper tray roller. Take out paper tray and toner, lift printer so you can see underneath you should see a set of rollers its nopt to hard to get out. also in the paper tray there is a roller swop that out to
Dec 14, 2006 | Kyocera Mita FS-1920 Laser Printer
Kyocera FS-4000DN Laser Printer Logo
276 people viewed this question
Top Kyocera Office Equipment & Supplies Experts
Kyocera HP Expert
CheckitRight
CheckitRight
Henry Gertcher
Are you a Kyocera Office Equipment and Supply Expert? Answer questions, earn points and help others
