Question about Hotpoint RLA30 Compact Refrigerator
My fridge keeps freezing everything even on the lowest setting - does it need a new thermostat?
  • Hotpoint Master
  • 43,501 Answers
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Posted on Aug 28, 2010
Haier minifridge freezing everything
My mini-fridge did a similar thing, until I realized that managed to put on the wrong temperature knob. It was technically backwards. They may have done this to you. I mean, it is a longshot, but try putting it on the highest setting to see if that helps. If it does not, you're most likely dealing with a faulty knob that's not actually changing the settings on the thermostat.
Apr 10, 2014 | Haier Refrigerators
My refrigerator freezes my food and drinks even at lower setting. The freezer is at the lowest setting and freezes my food like rocks.
There is a thermostat inside the casing telling the fridge to keep cooling - forever.
Replace it
Oct 28, 2010 | Refrigerators
My side by side refrig. keeps freezing everything. It is turned lowest setting. Model GLRS2677AW6
Hi, this problem is going to be with the running thermostat2.gif (cold Control). It has gone bad and stays open which in turn will keep the compressor running continually and will cause the fridge2.gif to get colder and freeze food. It can normally be located in the control panel inside the fridge (it is the control that has wires, the other is the damper). Locate the thermostat and replace it. If you have any other questions or concerns please feel free to comment again. Good Luck!! Mike
Oct 09, 2009 | Frigidaire Refrigerators
Fridge keeps freezing up
Then replace the thermostat. It's cheaper that wasting all that beer. Seriously I think your thermostat is broken and stuck on coldest setting. Sea Breeze
Aug 21, 2009 | Kenmore 564-91179400 / 564-911714001
Hi my fridge freezes every thing even at it's
your thermostat is bad, what it does it sense the temperature set buy the control setting, once it goes bad it does not recognize the temperature hot or coold and the unit keep running and freezes everything. thermostat work like the therometer switch, when it reach certain temperature it cut off.
Jul 16, 2009 | Dometic Refrigerators
Fridge is freezing
there is a way to adjust it but its very difficult..best to just replace it. the thermostat that is.
Jun 09, 2009 | Whirlpool ED2FHGX Side by Side...
Fridge keeps on freezing everything inside of it
This refrigerator only has one thermostat located in the fresh food compartment it is designed to activate the sealed system (cooling) until it reaches approximately 37 deg f in the fresh food compartment. The damper controls how fast the cold air can move from the freezer compartment to the fresh food compartment. Allowing you to control the temp in the freezer by controlling the flow of cold air to the thermostat.
You have one of two problems.
#1 your thermostat is no longer opening when it achieves set temp. fix = replace thermostat pn 61005798 $35
#2 your damper arm or assemblie has broken. Fix = Replace damper or broken arm and actuator.
damper assembly pn12001377 $44
damper actuator pn 61002000 $2
damper arm pn 61001999 $2
thermostat actuator arm damper arm
damper assembly both pics
Apr 06, 2009 | Refrigerators
Hotpoint RLA30 Compact Refrigerator Logo
262 people viewed this question
Top Hotpoint Refrigerators Experts
John Tripp
John Tripp
Sal DeAngelo
Dan Webster
Dan Webster
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
