Question about Dell Inspiron 1525 Laptop
Booting problem......while booting it hangs in the setup is starting menu....
    Sergeant:
    Champion:
  • 233 Answers
The issue might be due to many reasons such as corrupted display drivers. <div><br /></div> <div>Visit the below link for more information</div> <div><br /></div> <div><a rel='nofollow' href="http://notebook-solutions.blogspot.com/2009/07/my-laptop-computer-will-not-boot.html">http://notebook-solutions.blogspot.com/2009/07/my-laptop-computer-will-not-boot.html</a></div>
Posted on Aug 25, 2010
Why is my laptop comming up with aptio setup utillity
Try this
1/ Select the Boot menu in the Aptio setup utility, select 'Launch CSM' and change to enable
2/ Select the Security menu n the Aptio setup utility, select 'secureicon1.png Boot Control' and change to disable
3/ Select Saveicon1.png & Exit and press 'yes'
4/ Hold down the powericon1.png button until the unit switches power off completely
5/ Switch back on and continually press the F9 button for about ten seconds; this should now allow the unit to boot up into the Windows Recovery menu
6/ Select 'Advanced Start Up' and wait until the recovery menu appears
7/ Select ' Advanced Options'
8/ Select 'System Restore' and select a date prior to when the problem occured
System Restore worked perfectly for me; good luck
Aug 03, 2014 | ASUS Computers & Internet
I wanted to remove network boot from bios setup to normal cd rom boot
Hi
When you start the computer click F2 to inter the Bios setup
then go to boot menu and choose boot order make the first boot for CD Drive
there's kind of MB contain boot menu you can reach it by click F12 when you start the PC
Apr 24, 2011 | Intel Computers & Internet
I have a compaq presario 5600 / P4-1.5G/128MB/40GB/C48/M The other day the system hung, and nothing was working. I changed the CPU battery, cleaned the dust. the system started with Intel boot agent 4.0...
You probably need to set your boot order in BIOS (setup) to load from CD first. Reboot the computer and press either F1 or F10 repeatedly until the setup (BIOS) menu comes up, then, using your arrow keys, navigate to the boot menu and set the boot order to CD first.
If you can't get into the BIOS through F1 or F10, try other "F' keys until you get in. Also the "Del" key.
Recovering to factory settings is kind of a drastic measure just because of a system hang. You would be better served to find out why the system hung. IN FACT, understand that depending upon what is wrong, the system may hang during the recovery, leaving you with fewer options for repair.
Post back if you want to try to troubleshoot this further. It will take a while, but we should eventually be able to determine what is causing the hang.
It could be just an application that needs to be removed or re-installed. Have you installed any new software recently? What software were you using when the hang occured? What operating system are you using?
It could just be a virus or a bad memory module. Are you able to boot into SAFE MODE" (press the F8 at boot)?
If you can boot into Windows, go to "Start" > "Control Panel" > "Administrative Tools" > "Event Viewer" > "System" and check for any error entries. Also look at the "Applications" log.
Aug 15, 2010 | HP Compaq Presario PC Desktop
PC BOOTS HALF WAY
Try booting into safe mode. If it's a driver problem, safe mode will allow you to start Windows with only the bare minimum of hardware and drivers being engaged. To get to safe mode, press the F8 button on your keyboard during the Windows boot process until it takes you to a screen to let you select Normal, Safe Mode, Safe Mode with networking, etc. I would suggest not using anything other than just Safe Mode. From there, uninstall any software or new drivers that you recently installed. Alternatively, you can use the System Restore feature to rollback to a previous restore point.
Aug 10, 2009 | HP Computers & Internet
How to install windows
You need the windows CD to install windows, insert the cd in drive and press enter when asked to press anykey to start from cd.
if you don't get the start from cd and the windows setup doesn't start then most likely your computer is not set to startup from a cd drive, look in the cornerts of your computer screen look for boot menu or press this to enter setup / bios
you can either use the setup / bios or the boot menu and boot from the cd.
if you use the boot menu, make sure the cd is in the drive and select the drive from the list
if you don't find boot menu or it doens't work go into the bios / setup and you will need to change the boot order to include the CD drive FIRST before hdd or floppy. consult your motherboard manual or ask me if you need help in the bios.
Dec 01, 2008 | Microsoft Windows XP Professional With...
Replaced cmos battery
Try this:
Press and hold F1; then power on the computer. Hold
F1 until the “Easy-Setup” menu appears.
If you have set a password, the “Easy-Setup” menu appears
after you enter the password.
Plagiarized from:
http://www.wimsbios.com/phpBB2/topic9023.html
Mar 28, 2008 | IBM ThinkPad 600X Notebook
Does not display setup or boot menu
first try to clean you mother board with anty dust spray
secound on your motherboard you can see clear comos junber behind the battery comos try to clear it ...... i think your motherboard will workink after that
Jan 18, 2008 | MSI 865PE Neo2-V Motherboard
Dell Inspiron 1525 Laptop Logo
mukhtar21 shaikh
mukhtar21 shaikh
