Question about Garden
The Fan Belt that drives the grass cutting blade is broken. Where can I buy a new Fan Belt for the mower? Im living in Norway. Thanks
    Brigadier General:
  • 3,911 Answers
Thought they used zambonis to shave their ice, now I find out they have growing grass in Norway. Look in the phone book, business section, for small engine/lawn mower repair shops. These guys actually also sell mower parts. Will vastly help, as there are scores of different belts, if you take along your old belt or the name and model of your mower.
Posted on Aug 26, 2010
John deere d110 not cutting grass
check belt and pulleys --if belt to loose wont turn blades to cut the grass
Aug 31, 2016 | John Deere D110 42 in. 19.5 HP...
Zero turn mower is sputtering and dies
Check everything is clean. Check the air filter is clean, check that the engine cooling fan, cutting blades and cutting deck are free of grass. Check all the drive belt pulleys to ensure accumulated grass is not jamming anything. Check the fuel filler cap is clean and the breather hole works.
Jun 27, 2013 | Husqvarna Zero Turn Mower Z5426
Mtd yardmachine 7 speed shift to go is my mower. it runs but want pull. does it have 2 belts or just the deck belt. the deck belt has more play than normal ..i think. as i was cutting the grass it stopped...
There are two belts, one for the deck and one for the main drive. The main drive belt can be seen on the upper pulley under the engine. Check to see if it has slipped or broken.
Aug 02, 2011 | Mtd Garden
When I engage the blades on my ez4824 the blades intermittently stop cutting particularly in higher grass. Do you think this is a loose belt problem? Thanks.
That is the most likely cause of the problem - taller and thicker grass the blades encounter more resitance and the drive belt slips and it doesn't cut. This would likely cause a juddering of the machine when it occurs.
Hope this helps.
Jul 11, 2011 | Husqvarna EZ4824 24 hp 48" Zero Turn Lawn...
If the belt comes off a riding lawn mower...will it still cut grass
Probably not.
I would expect to find two belts on a riding mower; one to drive the riding lawn mower (lets call this the DRIVER) and one to drive the actual mower part (lets call this the MOWER).
To answer your question one way, if the driver belt is off, it will still cut grass, but you cant move the mower. If the mower belt is off, it will move but not cut the grass.
If your belt is broken, take it to an automotive parts store or garden equipment place for replacement. You might also support a FixYa.com advertiser.
I hope this answers your question. Thanks for posting at FixYa.com and please vote.
thanks
a
Nov 14, 2009 | Garden
I have a Craftsman Lawn tractor. Blade leaves grass uncut.
Hi Tom,
Check your spindle shafts for loose play. If your bearings are worn out and sloppy, the belts pull the spindle to one side and an angle cut results... close cut grass at outer edge and high in center will leave this grass trail you are describing. I'd replace the bearings next year for sure.
I hope this helps... Good luck!
Oct 04, 2009 | Garden
G-110 deck belt keeps jumping off pulleys
check for a broken belt tension er or maybe grass clippings under belt area, check for a broken or loose pulley bearing, even a bent shaft on the deck.
Aug 07, 2009 | Mtd 46" Dozer Blade, Fits All & Yard -...
I have replaced the drive belt linking to the two blades on my Rally ride-on lawn mower (92cm 5 speed 11.5 hp) and they are now cutting effectively. The problem I have is that the blades are still driven...
Here's what I have run into many times when all adjustments are correct. If it is not an original equipment belt after market belts vary in length. Which means most times they are usually a bit short. In this case you have two outs. One is to live with it which is not always safe and two get an original equipment belt from a dealer or the manufacture.Good luck.
Mar 24, 2009 | Garden
Craftsman 42" riding lawn mower blade free spinning but wont cut
It sounds to me that you need a new mower deck drive belt, or your blades need sharpening. If the blade edges are rounded, they won't cut butter... Also, when mower is off, check mower deck drive pulleys to make sure you don't have any that are locked up or are dragging. You can check this by pulling the belt away from pulley and spinning the pulley by hand. MOWER MUST BE OFF before attempting any of these checks. You would be surprised how many people would try this with the mower running.
Hope this helps
Mar 11, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
