Question about GoVideo Go Video DVD/VCR Combo
Disk Initialize Can't seem to get a new disk initialized. Have gone to Disk option Tried to select Disk Initialize, but it grayed out and will not let me select form that portion of the menu. I can select from the bottom of the menu to select PBC, Auto Play and YourDVD Is there something I have turned on, or need to select before it will let me do this?
  • Adavid Nov 26, 2008
    I have the same problem. Have not been able to solve the problem by using the owners manual.
  • Anonymous Dec 02, 2008
    I am unable to load DVDs and CDs. The TV screen show "Loading" for a long time, then say "Bad Disc" regardless of what is in there. It won't even load a cleaning disc. I have read the manual and checked all connections but nothing solves the problem. I tried calling your 800 number but it has been disconnected. Help, please!
Had similar problem. My unit is 5 years old an found it cannot recognize certain higher speed DVD-R. The DVD that failed was Memorex and indicated "up to 16X". I tried a different brand "Sony" that indicated 1X - 16X" and the latter worked. I believe the older units cannot read the high speed disks.
Posted on Dec 30, 2008
If it's a DVD recorder, make sure you are using compatible DVD-R media. Check in the user's manual if it supports DVD+R or DVD-R.
Posted on May 05, 2008
Initializing discs
If you are using the same OS and have made no changes to software, it sounds like the drive may be faulty.
Try a disk cleaning kit and re-install the software for the program you are using.
Example, Try NERO or some other program after cleaning the drive.
Do a un-install of whatever program you may be using and re-install it.
If you can rely on the software, then the drive is probably at fault and should be replaced.
Look in systems information, under hardware configuration and look for problem devices.
Hope the helps.
Try it, it may work !!
John Ray
john@johnrraycomputer.com
Jun 29, 2009 | LG LRY-517
NO DISK when disk is in. Initial DVD Player Model:IDM-9520
Chances are the Laser that reads the disc has gone bad. It's usually cheaper to buy a new one instead of having it repaired.
Aug 29, 2008 | Philips DVD724 DVD Player
Go video vr3840 dvd/vcr player recorder combo
HELLO. IT SOUND'S LIKE YOU NEED TO CLEAN YOU RECORD & YOUR PLAYER TO ME . "GOOD LUCK"
Jul 23, 2008 | GoVideo Go Video DVD/VCR Combo
DVD recording problem
i thing u r read write head is gon
Apr 01, 2008 | Televison & Video
LG DR275 Initialize problem
hello..Carol..please refer to your user manual and look in the chapter that includes "how to" maybe you don't have to manually initialize the disks..this will be done automatically...keep it easy...please tell me how it went !...good luck...Ron
Mar 05, 2008 | LG DR275 Recorder
Hard drive shows full even after erasing 120 hours.
You should empty the recycled bin in the system and delete all temporary files on it.
Jan 10, 2008 | Pioneer DVR-640H DVD Recorder/HDD Recorder
Recording problem with LG RH266 Recorder..
Just bought unit. Had same problem.Tried lots of different types of disks with no luck. Tried to play already written +R disk. Worked OK. Then took out and replaced with blank -R. Came up with new screen asking me if I wanted to initialize disk. Answered yes and it took about 20 seconds. Then tried to DUB from HDD to DVD again. This time it came up with the dubbing menu, I hadn't seen before, and worked.
Hardly ideal, but the trick was to get it to recognise it as a blank and initialize. Currently burning my first disk. Didnt realise about 'FAST' mode, so taking ages.
Jan 05, 2008 | LG RH266 Recorder
Will not initialize a new disk; often freezes up when trying.
Hello, I would suggest opening the unit & cleaning the lens with a cotton swab lightly soaked with rubbing alcohol. Especially if it has been used in an enviroment wich is dusty or the unit has been smoked around. Also, are you using the same type of discs, Some discs are better quality than others try using Imation they read in almost anything. Also if you do have to clean the lens you may want to lighty lubricate the rails the laser moves on using a drop or two of 3in1 oil per rail.
If it still will not work then I would say that the laser pickup is failling. Specificly the laser used for burning the disc, Since there are usually two lasers one for burning & one for playback.
Jun 04, 2007 | Samsung DVD-R135
GoVideo Go Video DVD/VCR Combo Logo
111 people viewed this question
Top GoVideo Televison & Video Experts
 Grubhead
Grubhead
Are you a GoVideo Televison and Video Expert? Answer questions, earn points and help others
