Question about Microwave Ovens
I have read the post of aasc http://www.fixya.com/support/t3615482-ge_side_side_model_gsswgpdww_freezer Thanks for your post, which is pretty much the most detailed one I can find on web... I, too, have the same model of GE frige (gss22wgpdww), I have the same problem that freezer does not defrost. I replaced the heat element, but it still does not work. After I read your suggestion, I tred to jump the blue wire with the third wire(s) as instructed (bypassing the circuit board), On the circuit board, the connector connecting to the blue wire is marked as "defrost", and the third wire is marked as "line". Once I pluged in the power, it burned out the new heat element right away. I put in a second one, it burned out, again. I was hoping that by jumping the blue wire, it will light up the heat element, so this will indicate that the thermistor is a problem. Any uggestion is appreciated. thanks.
  • jking206 Aug 25, 2010
    It is Frige, not a microwave.....
    jking206
    thanks for your reply.
    I did get a dual heat element kit from sears. But since it requires spicing, and the heat element are the same as the old one (G7102), I decided avoiding any spicing and just replaced the old one with a new one...
    Is that possible even both old heat element and new heat element are labeled as G7102, but they have different resistance?
    could the burning out heat element mean that I have a faulty ground? There is a green grond wire clip on the board that covers the coil. The board is screwed on the frame of the coil. To make things more accessible before the problem is solved, I did not put that board back. And I clipped that green ground wire directly onto the coil frame.... But I really do not see this could be a problem, since the board was screwed onto the coil frame as well.....
    thanks.
    Jking206
  • 17,970 Answers
Could find very little info on this site but did see that the defrost element is now a dual element. I believe it comes in a kit and you have to splice it in. They run two elements so it supposedly last longer. You may want to give the parts side of this site a call.
The heater should be able to take 120 volts for a lot longer than what you described so I am at a loss as to what would cause it to blow so quickly. There was nothing touching the glass so perhaps a fault, direct from the factory.
The glass type heaters are **** and always will be so instead of replacing it with a decent ceramic type GE in their wisdom put in two of them. Oh well I guess that it is better than nothing.
You have to use both heaters and follow the instructions in the kit, That's your problem. By removing one of the heaters, you are changing the resistance value and burning out the heater, so you need to order the heater again, and install correctly
Hope helps.
Posted on Aug 25, 2010
  • ZJ Limited
    ZJ Limited Aug 25, 2010
    If you have one new device and all the connections are good, then may any grund there or the mainboard keep any internal fault.
I have GE JVM1190 and it has just quit and I want a replacement but just a microwavw only not a convention
May 24, 2017 JVM1190 - - What are your symptoms?
I regularly repair the controllers for these microwaves and details are here.
It's best to follow up with me directly. (FixYa does not notify us directly when follow-ups are posted, so we have to log in to the site to see them.)
If you are determined to replace it, ask GE Customer Service if they have a direct replacement for your model. They are here: http://www.geappliances.com/ge/service-and-support/contact.htm
- William E. Miller, AS-EET
pupista@gmail.com
http://www.microwavecontrol.com
Microwave Oven Control Panel Repair Nationwide
"Recycling by repairing since 1982"
Apr 17, 2017 | GE Microwave Ovens
I want to defrost my GE chest freezer but i do not know where the drain is
Since you did not include a model number this is my best guesses:
http://manuals.appliancesonline.com.au/kcm2100wc/kcm2100wc.pdf (Page 1 w/pic)
and
http://www.appliancesdirect.com/InstallationPdf/49-60442.pdf (page 7 no pictures)
For Complete Defrosting
Turn the temperature control to the
OFF position and unplug the freezer.
Remove all food and place it in
corrugated boxes, insulated bags,
picnic coolers, etc. Use towels and
newspapers for insulation as needed.
With the door/lid open, use pans of
hot water to speed loosening of frost.
Remove large pieces before they melt.
Chest models have a defrost water drain
at the front.
NOTE: Water may drip from the back flange of
the lid cover during defrosting. This is normal.
Ice builds up in the lid insulation when the lid is
open for adding or removing food, and melts
during the defrosting operation.
Sponge excess water from the bottom
of the freezer as it collects to prevent
overflowing.
After defrosting, clean the inside of the
freezer (see Care and Cleaning).
Replace the drain plug inside the
cabinet and the cap on the defrost
drain. Fold over and dry the gasket
on the hinge side of the lid.
Plug in the freezer. Return the
temperature control to its previous
position and return food to the freezer.
Hopefully with this information you can find the drain. If not go to www.ge.com and click on service and support to download your manual. (Model number required)
or contact them here:
800 GE CARES
(800.432.2737).
Thanks for choosing FIXYA,
Kelly
Jul 24, 2011 | General Electric Microwave Ovens
Hi my microwave will not heat anything
read the info on the below link, it was posted by me
http://www.fixya.com/support/r7088553-microwave_oven_not_heat_hear_loud
I hope this helps.
Good luck.
Jan 14, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
Have model jvm1740sm1ss ...keypad has shorted ...cant seem to find parts for this model even on ge site
This should be the correct parts listing for the model number you have provided:
http://www.pcappliancerepair.com/model.php?mn=JVM1740SMSS01&man=&mid=&brand=GEH&pmid=0
Here is another part listing which is a slight variation of your model. The part numbers are still the same, however:
http://www.pcappliancerepair.com/model.php?mn=JVM1740SM2SS&man=&mid=&brand=GEH&pmid=0
I believe the model number should read "JVM1740SMSS01". If you have any questions, please post back and let me know. I hope this helps you.
If these links do not work, go to pcappliancerepair.com.
Here's another listing available at appliancepartspros.com:
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5218277
Here's another listing available at searspartsdirect.com:
http://www.searspartsdirect.com/partsdirect/part-model/GE-Parts/Microwave-Parts/Model-JVM1740SMSS01/0432/0123370?searchedModel=jvm1740sm&blt=
Oct 28, 2010 | GE Microwave Ovens
GE spacemaker xl 1800 died while cooking,has power to outlet, no display or lights, won't work at all.
Hi and welcome to FixYa. I am Kelly
When a micrwave quite during use it does have a tendancy to make the user wonder just what happened. There are several components that can cause this symptom.
1. The High Voltage Capacitor
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5227571&diagram_id=22974428#d22974428
(item 49)
2. The diode in the diode cable has failed
(Item 50 in the link above)
3. An open thermostat (Item 110) of above link (there are 2 of them)
4. A failed Magnatron (Item 73) This is pretty rare that a magnatron fails... It is usually something else.
Since you do not have any lights or appearance of power the fuse is probably blown.
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5227571&diagram_id=22974429#d22974429
(Item 47)
It can also be the duct thermostat item 27 but again this is a rare failure.
Usually what happens is either the HV Cap or the Diode in the Diode wire fails.
IF you even attempt repair... make sure to short across the HV Cap terminals at least 3 times. The first time if the cap is good it will really make a bang and spark.
To test the diode wire... "unhook / disconnect one end of it and use a meter to read it using resistance. One direction it should read. Reverse the leads and it will appear open.
There are a few other things like interlocks, HV transformer and control panel board that can cause this but again the instances of failure are pretty slim.
Replace the 20A fuse in the fuse holder. IF it blows again either the diode or the Cap is most likely the problem
An informational note... IF someone opened the door slowly without pressing pause / stop it can via the door interlock switch blow the fuse.
Hopefully this give you a clue as to what has happened and what to look for as far as repair and expected expenses.
Thanks for choosing FixYa.
Kelly
Jun 27, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Hi, I have a GE JVM1440 & the plate won't spin
This is commonly caused by a turntable motor that has worn out and needs replaced. The following link explains how to access and replace one:
http://www.fixya.com/support/r3555716-replacing_a_turntable_motor_on_a_microwa
If the model number is correct, the part number is WB26X10038. You may also consider replacing the turn table shaft (coupler), part number WB06X10138. You can purchase replacement parts at the following websites: searspartsdirect.com pcappliancerepair.com appliancepartspros.com repairclinic.com The first three sites listed offer helpful exploded view diagrams to assist you in parts location/identification. If you have any questions, please post back and let me know. I hope this helps you.
Dec 09, 2009 | GE JVM1440 Microwave Oven
How do you install a charcoal filter in a ge spacemaker microwave? we have the grill off and the door open and it seems to not fit. I checked to see if it is the right one and it is. Is there a trick I'm...
The owner's manual will give you the procedure for your model.
You can download GE owner's manuals and installation instructions here.
NOTE: The FixYa system is not currently notifying me when folks reply to my posts, so please contact me directly with your brand, model and symptoms for more FREE help & do-it-yourself advice.
Please include this URL, too:
http://www.fixya.com/support/p126566-ge_spacemaker_jvm1640sj_microwave_oven/solutions
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Sep 12, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
GE Profile Spacemaker Microwave - won't heat
Thanks for making your post very detailed and including the model number. That really helps! :)
With the symptoms you have, I would most strongly suspect a shorted high voltage rectifier diode or a bad magnetron.
The diode is a fairly easy & cheap do-it-yourself fix, and the mag will cost more.
If you or someone you know decide to look into it, we have critical safety information and disassembly information at our site, and our link is at our listing here on FixYa.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Here are some links you or someone you know can use for test help, but read their safety warnings first:
http://www.gallawa.com/microtech/diode.html (if it's not shorted, it's probably okay)
http://www.gallawa.com/microtech/mag_test.html
http://www.gallawa.com/microtech/xformer.html
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
Dec 10, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
What is a FixYa thread and why can't I find it so read your response? I did get one response that it was a malfunction in teh microwave. How do I go about contacting GE for a replacement since this...
A thread is simply a discussion subject and all its subsequent replies.
When you post, people follow up, then you can go back to the thread to read the reply and the entire discussion is there to preserve context.
When you post, always look for a check box something like "Notify me when this question changes" or "Notify me when some replies" and be sure to check it.
GE Customer Service is at http://www.geappliances.com/service_and_support/contact/
We're happy to help and we appreciate your thoughtful rating of our answer.
Jun 05, 2008 | GE Microwave Ovens
Microwave Ovens Logo
27 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
