Question about Audiovox FPE2706 27 in. LCD Television
The picture comes on fine, but suddenly, no audio from the tv speakers. Any suggestions?
  • 11,361 Answers
<span style="mso-bidi-font-family: Arial">Let verify first to narrow down to where the problem can be. First, make sure the MUTE function is not activated, and then check the on screen sound set up menu to make sure the speakers are not set to OFF. If the setting is OK, then attach the powered PC speakers to the Audio Line out RCA jacks (Red and White) to see if you can get the sound there, if you do, then the problem can be in the power amp circuits, if you do not get the sound at RCA jacks, then the problem can be in the sound processor circuit. Please post back what you find.</span><br /> <span style="mso-bidi-font-family: Arial">Parts: <a rel='nofollow' href="http://www.shopjimmy.com/">www.shopjimmy.com</a></span><br /> <span style="FONT-SIZE: 10pt; FONT-FAMILY: 'Arial','sans-serif'"><a rel='nofollow' href="http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide">http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide</a></span><br /> <span style="mso-bidi-font-family: Arial"><a rel='nofollow' href="http://s807.photobucket.com/home/budm/allalbums">http://s807.photobucket.com/home/budm/allalbums</a></span>
Posted on Aug 25, 2010
Testimonial: "Thank you, so much. I followed your advice to the letter. No sound with PC speakers. Turned "tv speaker" on, but no sound. "
  • Bud Martin
    Bud Martin Aug 26, 2010
    That means the main board will have to be replaced, not sue if you can get the replacement or if it will be worth it, just to be sure, you are not getting sound on all the sources , I.E. DVD games.
I have a Samsung LN-T1953H TV and the sound suddenly stopped working. We were watching a DVD and suddenly no sound. The TV picture still works fine but there is no sound. on any of the connections or...
It sounds like the main board has gone out. The only audio components are the main board, wiring and speakers. Since audio is missing from external speakers as well, that tells you that the main board is at fault. The cost of the board could be from $150.00 to almost $300.00 depending on the version # of your unit and dealer mark up. You can call 1-800-samsung for nearest service center.
Mar 18, 2010 | Samsung LN-T1953H 19 in. LCD HDTV
No sound
Sounds like a loose connection that has finally failed in the audio out circuit
Jun 04, 2008 | Hitachi 61HDX98B 61" Rear Projection...
No sound great picture
Are you connected to a Cable box? then make sure cable box is not on MUTE and audio cables are attached.
From MENU check to see that speakers are not disabled on your TV.
Good Luck
N Sabre
Nov 07, 2009 | Mitsubishi WD-57734 57" HDTV
Distorted audio
Audio amps on original set are fubar.
Jun 20, 2017 | RCA F36695BC 36" TV
Proscan TV
Maybe, but I would first go into menu and look at audio settings and make sure speakers are on internal and not external or turn off.
Also just unplug for an hour and restart unit. Lastly, it may be cheaper to just attach a 100.00 surround sound system for audio.
Craig www.classtorations.com
May 27, 2008 | Proscan PS32500 32" TV
No Audio, picture fine
this is a very common problem just unplug tv for 5 minutes it
should fix it . simple fix most of the time with rca and proscan.
If that does not do it go into menu scroll down to audio and then press on .
thanks doctor video leading edge electronics
Apr 28, 2008 | Proscan PS36800HR 36" TV
Television
please check if no audio is there. 1 speaker & its wire for loose. 2 check supply to audio section 3 & also check for loose contact in audio section. 4 signal coming to ic from sif section. 5 audio ic. good luck.
Sep 28, 2007 | Televison & Video
Have a beautiful picture but no sound
your problem is in sound section only. 1 signal line for sound coming from vif section 2 supply to audio section. 3 component fail in audio output section. 4 loose contact in audio section 5 speakr & its connecting wire.
Sep 27, 2007 | Sylvania 6427TE 27" TV
No Sound on TV
I did not answer the original question you posed but the SAP is the acronym for Separate Audio Program and is used to provide spanish for instance on a show which is broadcast in both english and spanish. The problem is not all stations have audio on the SAP. If your audio processor is set to SAP and you switch to a channel which has nothing on SAP you loose audio. I'm guessing someone suggested this prior to this post. If you checked your TV and it is not on SAP that eliminates that. I would look at the audio circuit for problems. Either no power to the audion circuit, bad solder joints, blown output IC or possibly a blown speaker. I know the last one is remote but it does happen and it never hurts to check the simple problems first. Besides you aren't embarrassed later when you find out it was something simple. If you are going to check these issues out remember safety. Good luck.
Jun 08, 2006 | Philips TS2746C TV
Audiovox FPE2706 27 in. LCD Television Logo
54 people viewed this question
Top Audiovox Televison & Video Experts
Jaime Hernandez
romy sibug
romy sibug
Are you an Audiovox Televison and Video Expert? Answer questions, earn points and help others
