Question about Maytag Atlantis MAV6000 Top Load Washer
Spin cycle won't work. Works when the load is lighter, no towels, and I manually move it around first. The hoses are not kinked.
    Problem Solver:
  • 5 Answers
Well, I only 12 and the mind of a 40 but not in these things. But I think that you should read the manual and if it still doesn't work then get it checked out or call the company to complain,maybe they'll send someone to fix it.Hope I helped.
Zohha Saeed
Posted on Aug 26, 2010
Cycle with towels keeps going 'OE' and it's locked so cannot unlock it, trying to rewash when I could get it open only adds more water to cycle and goes back into OE mode
Hi Donna.
It sounds like the machine is not draining.
This can be because the pump is jammed with something (like lint) or that something is blocking the drain hose or the hose is kinked (Common cause)
Check that the hose isn't kinked. If the hose allows water to run freely when you lower it to the floor it indicates that there is no blockage, in which case the problem is likely in the pump.
Not a big job for a repairman with the right tools.
Good luck
Nomess
Dec 29, 2014 | Washing Machines
Spin cycle incomplete
sounds like you may of had an unbalanced load. It will not spin if it can not balance the load.
Dec 27, 2013 | GE Washing Machines
My Defy Automaid DAW285 only works when you put in a small load of washing
It seems that the "start" winding of the motor is defective or the capacitor is defective
Peet
Nov 15, 2011 | Washing Machines
Too much water after was is finished
your drain pump is probably clogged or the main drian hose is kinked
Jan 12, 2010 | Kenmore 44072 Front Load Washer
Water is in the drum after a complete washing cycle, you can't see the water but you can here it slushing around and leaves a foul order when not used for several days.
Make sure that the outlet hose is not blocked and the filter is clear.
If this is OK then the following from Maytag may be helpful. If not call a repair man for service.
Is the Delicate or Hand Wash cycle selected?
Spin speeds can vary by the cycle that is selected. Your washer is designed so that in certain cycles, such as the Delicate or Hand Wash cycles, the spin speeds are slower. In these cycles, more water is retained in the load at the end of the cycle to protect the delicate fabrics from shrinking and wrinkling. Select the appropriate cycle based on the fabric being washed.
Was Max Extract selected?
Ideal for heavy loads such as towels and bedding, Max Extract removes more water from loads during spin.
Were you washing one bulky item, such as a rug or large blanket?
Consider adding more items to help balance the load during spin. Select Drain/Spin or Spin Only cycle and restart the washer. Your washer is designed to detect an unbalanced load and automatically lower the spin speed. Unbalanced conditions are more likely to occur with a single, bulky item.
Are excessive suds present?
Use only HE High Efficiency detergent. Using non-HE detergent or more than the manufacturer's recommended amount of detergent can cause excessive suds. The excess suds can cause the washer to run at a reduced spin speed, which will result in very wet loads.
See also: Why HE High Efficiency detergent is required
Is the drain hose kinked or is the drain clogged?
Make sure the drain hose is not kinked. Straighten the hose for adequate water flow. Remove any blockage from the drainpipe or utility sink. Use the U-shaped drain hose form or hose retainer on the drain hose, and secure the drain hose. See the Installation Instructions for details.
Is the end of the drain hose more than 96" (244 cm) above the floor?
The drainpipe (standpipe) height requirements are: 96" (244 cm) maximum and 30" (76.2 cm) minimum. Your washer will not be able to adequately pump the water out of the washer if the drainpipe (standpipe) exceeds 96" (244 cm). In this case, the water may flow back into the washer. See the Installation Instructions for details; find them by entering your model number in the Manuals and Literature search below.
Is your outlet voltage low?
Check the electrical source or call an electrician.
Sep 10, 2009 | Maytag Neptune MAH5500B Front Load Washer
The unit is balanced and when it goes into the spin cycle it vibrates and moves to the wall. What gives?
You need to ballence your load's. Run heavy itims such as towels and jeans together and lighter itims together also.
Aug 24, 2009 | Maytag MAH8700A Front Load Washer
Water pumping out at a trickle. stops in mid cycle
The timer seems to have gone out on you. Try to manually set it on spin and if that works then the timer is out.
Jun 30, 2009 | General Electric WSSH300G Front Load...
Flashing F2
“F02” (Drain Problem)
Select PAUSE/CANCEL twice to cancel the cycle. Unplug
washer or disconnect power.
Check the following:
Is the drain hose kinked?
Is the drain hose frozen?
Is the drain hose clogged?
Is the drain hose more than 96" (2.4 m) above the floor?
After running this check list, plug back up and try a complete cycle using cold water and no detergent. Sudding can mimic a drainage issue as well. make sure you are using the correct HE detergent to prevent over sudding.
Feb 22, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Clothes come out soaking wet
Is the Delicate or Hand Washables cycle selected?
Spin speeds can vary by the cycle that is selected. Your washer is designed so that in certain cycles, such asDelicate or Hand Washables cycles, the spin speeds are slower. In these cycles, more water is retained in the load at the end of the cycle to keep delicate fabrics from shrinking and wrinkling. Select the appropriate cycle based on the fabric being washed.
Was an Extra Low, Low or No Spin option selected?
Select the highest spin speed for the fabric being washed. If extra low spin or no spin was selected, the washer may not remove enough water from the load.
Consider adding more items to help balance the load during spin. Select $FL-drainspin cycle and restart the washer. Your washer is designed to detect an unbalanced load and automatically lower the spin speed. Unbalanced conditions are more likely to occur with a single, bulky item.
See also: Why HE High Efficiency detergent is required.
Make sure the drain hose is not kinked. Straighten the hose for adequate water flow. Remove any blockage from the drainpipe or utility sink. Use the U-shaped drain hose form on the drain hose, and secure the drain hose. See the Installation Instructions for details; find them by entering your model number in the Manual and Literature search below.
The drainpipe (standpipe) height requirements are: 96" (244 cm) maximum and 30" (76.2 cm) minimum. Your washer will not be able to adequately pump the water out of the washer if the drainpipe (standpipe) exceeds 96" (244 cm). In this case, the water may flow back into the washer. See the Installation Instructions for details; find them by entering your model number in the Manual and Literature search below.
Check electrical source or call an electrician.
Dec 13, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Maytag Atlantis MAV6000 Top Load Washer Logo
18 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
