Question about Maytag Dryers
Something is wrong with my dryer and the the dryer won't spin or dry anything that it has in it. What could be the problem.
  • Maytag Master
  • 43,501 Answers
<span style="FONT-FAMILY: 'Trebuchet MS'; FONT-SIZE: 10pt; mso-ansi-language: EN" lang="EN">Hi,</span><br /> <span style="FONT-FAMILY: 'Trebuchet MS'; FONT-SIZE: 10pt; mso-ansi-language: EN" lang="EN"><br />There can be many reasons why your dryer will not start or<span style="mso-spacerun: yes"> </span>turn...</span><br /> <span style="FONT-FAMILY: 'Trebuchet MS'; FONT-SIZE: 10pt; mso-ansi-language: EN" lang="EN"><br />The most common causes are the belt breaking or jumping off, or the motor going bad...<br /><br />Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...<br /><br />Dryer Repair - The Dryer is not Turning<br /><a rel='nofollow' href="http://www.fixya.com/support/r4422207-dryer_repair_dryer_not_turning" target="_blank">http://www.fixya.com/support/r4422207-dryer_repair_dryer_not_turning</a><br /><br />Dryer Repair ? The dryer will not start<br /><a rel='nofollow' href="http://www.fixya.com/support/r4460438-dryer_repair_dryer_will_not_start" target="_blank">http://www.fixya.com/support/r4460438-dryer_repair_dryer_will_not_start</a><br /><br /><br />heatman101 <br style="mso-special-character: line-break" /><br style="mso-special-character: line-break" /></span>
Posted on Aug 25, 2010
Electrolux dryer getting 'stuck' at times
the belt is frayed and catching at times. mine was split in half. right down the middle.gets caught on tention pulley as it goes around,,,sometimes
May 10, 2014 | Dryers
Aeq6000 won't turn off
This has to do with the control board failure. The control board runs every aspect of the dryer and will need to be replaced. Here is the new control board.
Oct 20, 2012 | Frigidaire AEQ6000ES Electric Dryer
Kenmore Heavy Duty Plus Dryer 86273100 drum won't spin
How could the belt be in working order if the drum doesn't spin? Check to see if the belt has come off the motor. If the motor runs but your dryer doesn't spin, the belt is off. If the motor runs with the belt on but it still won't spin then you'll have a lot of black smoke because your drum is jammed. In other words, there are a number of things that could be wrong, but not very many.
Dec 22, 2011 | Washing Machines
I have a may tag performa gas dryer. When I start it, it spins and heats but it spins very slow. I opened the top and checked the belt and it was tight and does not appear to be slipping. Is the motor...
  • There are a number of different problems which can occur with models of Maytag dryers resulting in them not heating and drying clothes properly. A variety of parts could have broken or been worn out over the course of the time you have been using your dryer or something could just malfunction, as appliances tend to do from time to time. Check warranty information before trying to repair the Maytag dryer yourself.
  • Bad Heating Element
  • Most clothing dryers heat up and dry clothes with a heating element inside the appliance's body. Maytag dryers are no different and sometimes these heating elements break down or burn out, making the dryer cease to get hot. Make sure the dryer is unplugged and the breakers that run the dryer are switched off before inspecting so you don't electrocute yourself. The heating element is in the bottom panel of the dryer and is often a silver part which heats up when the dryer is on. Sometimes the heating element will be cracked or burned out, which means it is broken. Other times it won't look damaged but may not be working. Replace the heating element if this occurs, to see if this is the main problem.
  • Broken Motor
  • Maytag dryers have motors which turn the dryer drum, tossing the clothes so that air and heat can help dry them out completely. When the dryer drum is not turning it means there is something wrong with the motor or that the motor is not getting power. Unplug the dryer and take it apart to inspect the motor. Once you have found the motor, plug the dryer back in and use a meter to see if the motor is getting power. If it is, and isn't working, then there is something wrong with the motor and how it is operating. If the motor isn't getting power, then there is something wrong with the circuits or fuses which disperse power to the motor itself.
  • Bad Switch
  • When Maytag dryers won't tumble or heat the clothes which have been put inside of them, this means there could be a number of different things wrong. However, sometimes there's a simple solution to this problem: The switch on the door of the dryer itself may be faulty or not making the electric connection it should to allow the dryer to run. This is a cheap fix and worth troubleshooting before tearing your Maytag dryer apart. Remove the switch and inspect the two leads to make sure they haven't broken or are still transferring electricity. If they aren't you will have to replace the switch.
  • please stay how helpful it
    Dec 21, 2010 | Dryers
    Dryer stops working after 2 minutes into cycle
    If it is new, is it not under warranty?
    does it run ok on air dry? Is there good air flow?
    post your answers in comments
    May 14, 2017 | Whirlpool WED9500T Electric Dryer
    Heating problem with stackable washer/dryer combo
    check the duct work going out of the house if it is clogged the clothes wont dry. Birds love to build nest in a open dryer vent and if you have any bends lint will build up get these clean and it should get you drying again
    let me know what you find
    bill
    Jan 08, 2009 | Kenmore 98702 Stacked Washer/Dryer
    Won't Dry
    Try taking off the duct from the dryer, it has to be something blocking the air flow, check if the end of the dryer is trowing out air, if it is not, then you have to take it apart to see if there is an obstruction inside of it
    Dec 17, 2007 | Kenmore 62872 Electric Dryer
    Drum is hard to turn
    does your dryer have a plastic glide on the drum or is it on the felt if some one gave you the wrong one that would make your problem worse there is two different types for that dryer
    Jan 16, 2007 | Kenmore 83042 Electric Dryer
    Dryers Logo
    12 people viewed this question
    Top Maytag Dryers Experts
    Dan Webster
    Dan Webster
    Tim Whalen
    Are you a Maytag Dryer Expert? Answer questions, earn points and help others
