Question about Craftsman Garden
The accelerator pedal is not working properly. Especially when trying to go up hill. I have to keep pushing & letting go, pushing & letting go. even when it starts to move. Also, the right blade cuts lower than the right blade. It is a craftsman ys 4500 tractor.
  • 905 Answers
I am guessing that this was posted in wrong category.
You mention that you have to keep pushing / letting go of the accelerator. Is the engine RPM changing, or is the tractor surging, when you do this? What happens if you keep a steady pressure on the pedal? Isn't the throttle control via a lever on the panel?
Your uneven blade height can be caused by a multitude of issues.
1) If the spindles were changed, the wrong spindle may have been used on one side or the other.
2) The wrong blade adapter has been used on one of the spindles.
3) Mower deck has been bent
4) Mower deck is binding. Try raising it all the way up, and lowering all the way down. See if the uneven cut changes at both levels (all up or all down).
5) Blade is bent on one side, though this would usually cause such a ruckus and vibration it would be quite noticeable.
6) Belt is slipping. Yes, sounds strange, but if blade speed changes significantly, then the position where the grass is actually cut changes because the grass can "lean over" more.
7) Using a mulching attachment in tall grass can cause 1 blade to clog, and the cut grass that is swirling bends over other grass that needs to be cut.
8) Mower deck support bracket has been bent
9) Mower deck wheel has a bad bearing, and doesn't support the deck at same height as other side.
10) Mower deck is cracked / bent at a support location
11) You have lost a retaining pin at a support bracket and the bracket is loose.
12) A spindle's bearings are worn out, and the spindle is "jumping" as it turns.
If the blades are directly beside each other where they blades will overlap, it is normal for a small amount of height difference to occur. But, most decks have off set blades, one slightly in front of the other.
you should be able to raise the deck all the way, and pull the tractor's front wheels up onto something (landscape timber?) to get more access, then measure blade height in relation to bottom of the deck. If different, then you are looking at wrong blade / adapter or a spindle issue. If the blades are the same height, then you are likely looking at a deck support issue / binding in linkage.
Posted on Aug 25, 2010
My tdv6 disco 2005 is shutting down when going up hill towing a caravan when the revs are over 3000
could be , the old pedal may have been distorted so you were'nt getting full throttle when you pushed the pedal down , here's hoping
Feb 08, 2015 | Cars & Trucks
My 2001 oldsmobile alero is not accelerating right
Failed Transaxle
How can you not know that ??
Sep 30, 2014 | 2001 Oldsmobile Alero
Car slow going up hills
check the connection between the accelerator pedal and the pump as there are two different operations at work . The accelerator cable linkage may be loose and not giving full throttle where as the cruise control is getting full throttle.
Jan 09, 2014 | Dodge Ram 3500 Cars & Trucks
1989 Honda accord . Morning cold start is very difficult turns over but won't start right away . Drive 6miles to town it will on flat ground start spitting and sputtering and gets worse when pulling a...
When was last tune up? Plugs, wires, all fluids & filters? Especially fuel filter? I'd start there and run a good fuel system cleaner (Stp. Gumout, etc..) through it and avoid cut-rate fuel
Apr 04, 2011 | Honda Accord Cars & Trucks
I have a expert 2005 it has lack of power going up hills wit just has no grunt it has just had a conversion done from a dual mass flywheel to a solid flywheel i have check the ecu but no codes i have...
The setting for clutch are not proper hence clutch is either slipping too much or sticking too much to clutch plate causing the engine to overload for every single rev. Both will effect the efficiency of your engine's exerting power especially going up hills. Use the manufacturers specification for clutch force and adjestment of pressure plate.
Try this to find out the condition of your clutch system:
In first gear and push accelerator fully to drive upto 3500 revs and then suddenly move your foot away from accelerator. If you feels a sudden shock and your head tends to nag to windscreen with a force then clutch adjestments are not properly done (stifting force is more than recommended). Inversly clutch is not engaging fully.
Jan 15, 2010 | Peugeot Liberte Cars & Trucks
1990 Camry runs roughly when accelerating, especially up hills...
This could be a problem with plugs, wires, distributors, fuel filter or fuel injectors. Try changing the plugs and wires first, then the fuel filter. If you are changing the plugs and wires, make sue you use anti seizing compound and dielectric grease.
Jun 29, 2009 | 1999 Suzuki Vitara
Garden Logo
97 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
