Question about Husqvarna Partner Gas Powered Cut Off Saw K960 16"
My husqvarna k960 won't start I have spark on the sparkplug but i whant start
  • 90 Answers
I know you would like a simple solution. these saws are not simple. check gas for water, clean air filter, check exhaust. take carb off and clean all jets. spark, gas in, exhaust out. fuel line clear? i have seen these **** up so much dust it plugged the breather. hope this helped.
Posted on Aug 30, 2010
Change plug an won't start
Make sure you have the correct spark plug for your maching. and Make sure the gap is correct on the spark plug. Look in your owners manual for the correct gap. Check inside the spark plug wire end that connects to the spark plug and make sure the metal part is still in there to make the connection to the spark plug.
Jun 10, 2014 | Husqvarna Partner Gas Powered Cut Off Saw...
Husqvarna power cutter model k960 s n 08 2100025
The Husqvarna K960 has a single peice goverened ignition system, if it has no spark try diss connecting the earth cut out wire from the unit and try for a spark again, if still no spark replace the ignition unit part no. 544047503 set the air gap at 0.3mm
May 26, 2013 | Garden
What number of spark plug do I use for z5426
Sparkplugs/Gap: Champion RC12YC .030"/0.75mm
You can download the owners manual free of charge from their site:http://www.husqvarna.com/us/support/
Apr 10, 2012 | Husqvarna Zero Turn Mower Z5426
My husqvarna chainsaw wont start
Try bypassing the switch by connecting the two wires together. If it starts then you know what the problem is.
Nov 23, 2011 | Husqvarna Garden
How to tell if the coil is bad on a 345 Husqvarna chainsaw
best way is to see if the plug has a spark, by removing it, hook the wire up, and ground the plug on the cylinder,and pull the rope, look for a good blue spark.
also replace the spark plug if you can
May 17, 2010 | Husqvarna Chain Saw with 18" Bar
I have a Husqvarna 125BT blower. It runs fine but
GAP is the opening between terminals at the end of the spark plug ( on the threaded side of the spark plug) but spark plugs should come with the right gap from factory, as for your problem with to restart your blower it is ok just need to let cool down for 15 min or more.
If you need further help, reach me via phone at https://www.6ya.com/expert/gerardo_79638d1eac6a0a1f
May 15, 2010 | Husqvarna Forest & Garden 125bt Backpack...
Saw will not start Husqvarna 350
Hi
An engine needs three things to run(fuel and air mixed together in the correct proportions,compresion of the fuel/air mixture and ignition).Make carb adjustments,check the compression and the spark from the sparkplug.Priming the engine(put some gas into the sparkplug hole).Try to start the engine.If engine is running only the gas from the cilinder,the chain saw has a fuel delivery problem.Disassembly the carb and clean the inner parts.Check the fuel and air filters,fuel hose and gas tank ventil.
good luck!savumihai71
Dec 04, 2008 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Husqvarna Partner Gas Powered Cut Off Saw K960 16" Logo
1,171 people viewed this question
Top Husqvarna Saws Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
rlev_7
Level 1 Expert
sgtstrat
Level 1 Expert
Are you a Husqvarna Saw Expert? Answer questions, earn points and help others
