Question about MSI K7N2 Delta-ILSR (MS-6570-030) Motherboard
Dutchman05 has offered a new Solution for the K7N2 Delta-ILSR (MS-6570-030) Motherboard
I have downloaded the AC97 driver and install it but the problem is the same. Help me please
    President:
  • 2,351 Answers
Hello Damaco, let’s check in side of windows. Bare with me on this. (For you, some of this may be a repeat of checks).
Click the start button & slide up to & left click on control panel.
It should open. Double left click on the icon, Sound and audio devices. Click on the Audio tab. Listed under default device should be the name of you're sound device. Now click on the Voice tab, again under default device should read the same device. If not than you're sound driver software did not install correctly. (Not you're fault!). Close the sound window. Next double left click the System icon. System Properties window will open. Click the hardware tab, than click the device manager button. Scroll down to Sound, video and game controller. You should see a yellow ! point or an X, which means no software has been installed or you're sound controller is bad. You're MSI board uses a bundled set of software which install more than just you're audio software & driver.
MSI's web site link is listed below. (Click on the link).
http://global.msi.com.tw/index.php?func=downloaddetail&type=driver&maincat_no=1&prod_no=546
You're MSI board uses Realtek ALC650 6-channel audio.
Realtek's home page does not hold drivers for you're ACL650.
Mike
Go to, (NVIDIA nForce2 System Drivers for MCP2 of SB).
Please create a folder on you're desktop & give the folder a name, like (Driver NVIDIA nForce2).
Download the software for you're current operating system & save it in that folder. You will have to uncompress the .zip file.
This download is more than just the audio software. (You should be able to install all without a problem).
This nForce Win2K/XP driver package contains the below components:......
Audio driver 4.08 (WHQL)
Audio utilities 4.08
Ethernet driver 3.13 (WHQL)
GART driver 3.34 (WHQL)
Memory controller driver 3.38 (WHQL)
SMBus driver - (Known as chipset drivers) 3.38 (WHQL)
IDE In-the-box 2.70
If during install you receive a screen where you can uncheck drivers that will be installed, do so. Uncheck Ethernet driver, memory driver, SMBus driver & IDE driver.
Since most of the drivers above are all ready installed. It should not hurt you're OS re-installing all the drivers. If this download & install fails to give you sound, than you're intergrated onboard Realtek ALC650 6-channel audio controller is defective. You can disable it from within you're bios & buy a PCI sound card.
Suggested PCI sound card. Any of these will work for you.
http://www.zipzoomfly.com/jsp/ProductList3.jsp
& the next link.
http://www.tigerdirect.com/applications/SearchTools/search.asp?cat=2771&keywords=PCI%20sound%20card&mnf=
Posted on May 07, 2008
  • 487 Answers
OK here is the deal.
you have a ALlC650 realtek soundchip on this motherboard.
Fortunatelu MSI who makes these boards have an awesome support center.
Follow this link and click on support. Then goto latest driver download and let it search for your missing drivers.
This should help.
Otherwise you will have to google the codecs for realtek ALC650
you will find them in a lot of places.
Good luck with this
Esonic motherboard G31FCCL2 power swsw
Hello this picture will show you how to connect the wires:
Hope this will help you
Jan 11, 2014 | MSI K7N2 Delta-ILSR (MS-6570-030)...
Bios reset on ms 6570 k7n2 delta ilsr with jumper
Hi, you can download a manual here:
http://www.msi.com/product/mb/K7N2-Delta2-Platinum.html#/?div=Manual
Unzip the file before you can read it.
The bios can also be resetet by removing the cmos battery:
The manual shows how to do it with the jumper settings.
Sep 25, 2011 | MSI K7N2 (MS-6570) Motherboard
Dont know wer to plug in the power switch which comes from the case. wil be a great help if someone can temme wer to plug the power switch.. thanks
On the motherboard the pinouts on the front panel should be colour coded, and marked with letters like in this picture >>>>>
The connectors are also marked corresponding to where the connect on the motherboard, like in this picture >>>>>>
If the board is not colour coded then the motherboard will marked with the same letters, you may need a strong light and a magnifying glass to see the marks and they are usually at the bottom right of the motherboard.
Regards.
Apr 28, 2011 | MSI K7N2 Delta-ILSR (MS-6570-030)...
Hi, From where can I download a manual for the MSI-649T Pro VER 5 ?
Click here to download the Manual for MSI K7N2 Delta-ILSR from MSI Official Support
GoodLuck!
Dont forget to appreciate the solution if I could have been of any help!
CreativeTECH
Dec 06, 2010 | MSI K7N2 Delta-ILSR Motherboard
New sata hard drive fitted, now says no audio deviec ,so no sound
If you just added the sata and reformatted the drive with a new copy of the Operating System you will need to reload the sound drivers located at MSI's web site in there drivers and download section.
May 22, 2009 | MSI K7N2 Delta-ILSR (MS-6570-030)...
Audio sound
install the AC97 drivers from Realtek and than go to your sound mixer and open the volume
start
control panel
sounds
advanced settings in left corner
unmute all
move all levers up
and you will have sound
Apr 25, 2008 | MSI K7N2 Delta-ILSR (MS-6570-030)...
K7 mainboard
Here's where you can download all of the drivers for your motherboard in one place, from the Vendors site:
or here:
http://tinyurl.com/2w296m
If you load all of these drivers and the problem persists, it may be a configuration problem instead of a driver issue. Let us know.
Feb 22, 2008 | MSI K7N2 Delta-ILSR (MS-6570-030)...
I have lost mainboard cd.
Exactly what is it that you need from the CD?
You can always download the drivers from the internet using this page as a guide:
http://www.amdboard.com/msi_k7n2_delta.html
Dec 10, 2007 | MSI K7N2 Delta-ILSR (MS-6570-030)...
MSI K7N2 Delta-ILSR (MS-6570-030) Motherboard Logo
350 people viewed this question
Top MSI Computers & Internet Experts
vsri9
Alun Cox
David
David
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
