Durabrand rb-22j1a wine cooler----no power to unit at all after being plugged in, all fuses are good.
  • kgenovy Jul 04, 2008
    Where do I find the fuses to check it out?
  • darlin_2001 Sep 26, 2008
    Same problem....lots of problems, no solutions.
I had this problem, no power, no light. It was the power supply output fuse. It appears to not be blown, but a continuity check across the fuse shows an open. Unsolder and replace the 5A, 250V fuse with some locally available Radio Shack parts (holder - 270-739, fuse 270-1071). Access to the power supply board is on the rear, remove the screws on the plastic plate, including the one hidden under the QC sticker. While you are in there, clean the fan and the aluminium fins on the heat sink (cools the Peltier device).
If your fuses are not blown, look at the electrolytic capacitors (the black or blue round metal cans with the aluminium X on the top) to see if they are bulging. Replace any that are bad (a common problem in switching power supplies).
Hope this helps,
Andy B
Posted on Mar 06, 2009
My dual zone wine cooler stopped cooling. Power is good and fan is working.
Fan is wired separately from the cooling unit. you may have a wire corrosion issue. take put the shelves, disassemble the back of the unit from the inside and observe the wiring to see if there are broken or corroded wires/connections. R/R if necessary.
Dec 14, 2014 | Magic Chef Dual Zone Wine and Beverage...
Edgestar wine cooler blowing fuse on the left side circuit board
If you have replaced the circuit boards it's probably associated with a wiring short circuit or compressor failure. Suggest you get a professional technician to further investigate the fault. In the interim check for a short to the frame of the unit, an internal light or for moisture issues or a condensation issue from water.
Mar 25, 2014 | EdgeStar ES TWR325ESS-32 Bottle Dual Zone...
Just purchased and is not cooling at all
please see this steps and fix it. God bless you
1. Unit not running
Possible Causes Response a. Power cord unplugged
b. No power at all
c. If display lighting, temp setting high
d. If temp setting ok, sensors or control board bad
e. Compressor unit malfunctioning a. Check for power cord plug
b. Check receptacle voltage & fuses
c. Lower temperature setting
d. Call service for replacing sensors or control board
e. Call service for component check
Nov 27, 2013 | EdgeStar CWR361FD - 36 Bottle Built-In...
The unit is completely dead. no lights and no fan. Both fuses on the board are good.
If it is dead, and doing nothing at all, have you checked to make sure its not a power failure to the unit? Sounds to me that may be a problem if all is dead. You probably checked this first, but make sure. I repair wine coolers, walk-in boxes on a day to day basis, and if you have no lights or fan, and nothing at all is coming on, it is either a power failure coming in or the power cord its self has come loose to the control section. That's all it could be, you have lost power. Check for power at the board if you have power to the outlet. The reason I believe you have no power to the unit is you say the light and the fan are off, and nothing is working. Please check and let me know.
A/C, & Refrigeration Contractor
Jun 07, 2011 | Cuisinart CWC-1200 Wine Cooler
The whole thing went dead, even the digital tempurature display.
Since everything went out, I would first test the outlet. Get a lamp and plug it in to see if the outlet is still active. Take the appropriate action if there is no power (check circuit breakers)
(p.s. Circuit breaker ONLY TRIP when you exceed the current load for that breaker)
If the out let is good (the light turns on) then:
Based on the reading of the owners manual, I did not notice any incident or mention of a fuse or power protection. Due to the sensitivity of wines , I am nearly positive this is an omission in the manual.
If you can get to the back of the unit, look around the power cord area to see it there is a fuse port. If there is a rocker switch to turn it on, the fuse may be in the switch.
this is your manual:
Hope that helps
good luck and don't forget to vote!!!
Sep 30, 2010 | Danby Silhouette DWC512BL Wine Cooler
Power surge caused wine cooler to quit cooling
Power surges, spike and brown-outs are a nemesis to small refrigeration units. The capacitor for the compressor likey was affected and possibly the start components in general, especially if the unit was operating when the surge occured.
Jul 20, 2010 | Haier BC112G Wine Cooler
Durabrand wine cooler
I bought 2 of these wine coolers and both of them ****! You would be better off returning it if you can or putting it in the trash.Both of mine did not keep them cool. At first they worked for about a day and then they stopped. They refrigerate around 70 to 76 degrees and stay there.
May 17, 2008 | Refrigerators
Heating & Cooling Logo
518 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
