Question about General Electric Profile PGCS1PJX Bottom Freezer French Door Refrigerator
Freezer at 50 and refrigerator at 45 the unit does not seem to be cooling. Service rep from GE cleaned out the back of unit he said it was dirty. Refrigerator worked fine for one day then got even worse.
SOURCE: I purchased a new GE bottom freezer refrigerator
If the panel temperature reads 0 F 0 F it is in the "DEMO" mode. This is normal if you purchase a floor model. To bring it back to normal mode press ENERGY SAVER & ADJUST FREEZER together for 3 to 5 seconds until it beeps. Then unplug the referidgerator for at least 30 seconds. Then plug it bck in. That will reset the stupid computer and get it back to normal operation.
Posted on Apr 24, 2009
Maytag317
  • 1136 Answers
SOURCE: The door handle on the freezer of my GE Profile
Hi, Please get me the model # from the label inside the refrigerator and I will look this up for you. Most handles have a set screw that tightens down.
Vic
Posted on Jul 11, 2009
  • 7 Answers
SOURCE: refrigerator no cooling,ice forming on back of
The refrig is freezing up. I suspect the defrost timer isnt working. The timer activates a heater in the coils which allows them to warm and be self defrosting. If the timer isnt working this wont happen and freezer becomes an iceball. Take the panel off inside the freezer side and you will see the coil froze up. Defrost these with a hairdryer then replace the defrost timer inside the refrigerator behind the light and place where you adjust temp. If that dosent fix it it could be the heater itself but the only way to know is try that first. Easy fix should be inexpensive
Posted on Feb 22, 2010
heatman101
  • 43501 Answers
SOURCE: My GE Profile PSCS5RGXSS refrigerator is heating.
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator
Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Posted on Mar 11, 2011
carmin77
  • 113 Answers
SOURCE: The freezer temperature on my GE profile side by
Start with the easiest possible problem to solve. Clean it. Not the inside, not the front door; clean the outside, the underside, the back side, the compressor area.
A fridge does not produce cold. It moves heat from the inside to the outside. Step one is to make sure that heat can be released into your kitchen verses sitting in a layer of insulation.
:o).
Posted on Jun 04, 2011
Slow to cool. bought used only got to 45 in frig. reset on 9 and in 24 hours stay at 38 to 40. But moved to 7 and it is at 45. GE tfh22 PR. Thanks for your input.
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
heatman101
Sep 15, 2011 | GE (PSS26MSRSS) Side by Side Refrigerator
The refrigerator is not getting cold enough even at a top setting. The freezer seems to be fine as ice cubes are still solid. The problem seemed to come on with hot weather. This unit is kept in the garage...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
heatman101
Jul 06, 2011 | GE J Series 18.2 cu. ft. Top Freezer...
My GE refrigerator does not cool, both freezer and fridge. The fridge is side-by-side. After turning off and cleaning out the unit for a little over a day, it began working again, however the problem came...
heatman101
Jul 04, 2011 | GE Refrigerators
Freezer does not seem to be cold and frost on the back wall
heatman101
Mar 20, 2011 | GE Refrigerators
GE PTS22LCR (top freezer) will periodically stop cooling almost entirely. Leaving it unplugged several hours then plugging back in seems to fix the problem, at least for several weeks to a few months....
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
heatman101
Nov 26, 2010 | GE PTS22LCR Top Freezer Refrigerator
I have a GE profile arctica refrigerator and the fridge is staying about 45 degrees, Freezer is staying about 23 degrees, can't get it to cool down on either side. Have taken the back of the thing and the...
heatman101
Nov 18, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
I have a ge profile bottom freezer fridge model PDS22MCR. It's making a loud humming noise & the fridge & freezer are getting progressivley warmer. fridge is up to 45 & frezzer 11 in a matter...
The compressor is not starting every time and later it will start again...replace start relay and capacitor...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then checkout the last two tips.
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
heatman101
Sep 17, 2010 | GE Refrigerators
Freezer not worknig.
As the weather is getting warmer for many people their freezer2_bing.gif and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator2_bing.gif Condenser Coil Cleaning Refrigerator Repair
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
Refrigerator Troubleshooting2_bing.gif Refrigerator Compressor
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Jun 05, 2010 | GE GSS25JFM Side by Side Refrigerator
Freezer not cold 50 degrees and rising
heatman101
34qgarhsg
May 23, 2010 | KitchenAid KSCS25FKSS Side by Side...
GE Monogram freezer side working but refrigerator side is not.
Did you clean the condenser?  Is the unit FULLY defrosted?   Defrost fully!!!!!!
Did he check the amount of gas in the unit?  If your unit has low gas...it is in need of more.  R12 is expensive.
Check gas level:  Shut unit for at least one hour.  View compressor.  Several pipes...we're looking at the largest.  Start the unit.  This pipe will begin to frost.  If it does not clear to dry, ice or wet...stays frosted...it is low.  Get the repair guy back ... but ask how much he'll charge first.
Dec 12, 2008 | Refrigerators
General Electric Profile PGCS1PJX Bottom Freezer French Door Refrigerator Logo
Top General Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Shehu Pro
Shehu Pro
Are you a General Refrigerator Expert? Answer questions, earn points and help others
