Question about Boating
Have a 2000 yamaha XL700 waverunner. Will not start, after running great. battery fine, all connections clean.
If the waverunner has an electronic "key" lock, it could have gotten tripped. We had this problem happen in the past where everything was fine, then it was tipped over and quickly back up... suddenly it wouldn't start. Used the remote and unlocked it - then it started!
Posted on Oct 01, 2010
    Problem Solver:
  • 19 Answers
Check for spark, If you have spark then it is a fuel problem
Posted on Aug 26, 2010
99 yamaha waverunner 1200 xlt starter stays engaged and powered on even after stop is pressed and kill switch is pulled.
The start stays engaged the entire time? I would guess it's a bad ignition switch -- it would be sending power to the starter (through the solenoid) regardless of if you switched it off.
Maybe it could be a bad starter, too. I'd start with the switch.
Mar 10, 2016 | Yamaha Jet Ski Pwc Watercraft Cover...
Yamaha 1200XL PWC won't start
hi there could be corrosion on the switch gear and kill switch check and clean as well as the wires going tostarter soliniod,corrosion on these electrical connections are always a problem cheers pete
Jun 11, 2013 | Yamaha Waverunner Xl 800 / Xlt 1200 Jet...
2001 Yamaha XL700 Waverunner bogs down after running for 30 min
did you replace all diaphrams in carbs and fuel pump ? balanced the carbs ?
Jun 07, 2012 | Yamaha Boating
Xl700 waverunner will lose throttle power after a good start
THIS HAS WORKED FOR ME MANY TIMES ,,,, RATHER THAN CLEAN YOUR CARBS THERE IS SOMETHING YOU CAN USE TO DO IT FOR YOU ITS CALED SEAFOAM,,, ITS A FUEL ADITIVE AND IT WORKS TO CLEAN THE WHOLE INGINE ,,,TRY THIS YOU CAN GET IT AT ANY PARTS STORE ,,,LET ME NO IF THIS WORKED,,THAKS.GOOD LUCK.
Dec 26, 2010 | Boating
YAMAHA WAVERUNNER 2000 XL 800, WILL NOT RUN PAST 12 MPH
Have you done a compression test on all cylinders? My guess is you have a dead cylinder (no oil to one or more cylinders causing loss of power). If the compression test passes (all cylinders equal and higher than 100-110 psi) you have a restricted exhaust from a failed catalytic converter that has broken apart.
Apr 05, 2010 | 2003 Yamaha YZ 250
Waverunner will not start
Check the fuses under the front in a round cover, 1 fuse is for the starter,but the cover must be on after checking the fuses.
Jun 30, 2009 | Sport & Outdoor - Others
Boating Logo
1,116 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
