Question about True TD-50-18 Beverage Cooler
My True beverage fridge is freezing the beverages on a temperature setting of 3. The dial goes up to 10. What could be the issue and how much approximately to fix?
    Novelist:
  • 112 Answers
Sounds like a bad thermostat. Normal setting is 3 to 5, with 5 being colder, and in my experience, more common. Prices vary but a thermostat is $50 - $75 labor should take no more than two hours - (less if you have the unit completely empty and warm when the tech arrives). The sensor goes into a sheath on the coil so if its cold there can be ice jamming the sensor from coming out or the new one from going in. The thermostat can be calibrated sometimes but it will generally cost the same with less reliable results.
Posted on Dec 12, 2010
Can i use a beverage air mt27 as a freezer
doubtful but if you turn the dial to highest cold number what is the temp only you ca tell that
Mar 22, 2015 | Beverage-Air MT27 Beverage Cooler...
If the dial is labled 0-9 what nimber is the coldest?
0 is warmwst,9 is the coldest.set it at +2C so that wine/beer dont freeze.beer is best served at 2c.
Dec 31, 2010 | True TBB-2 Beverage Cooler
What is the temperature for the thermostat settings?
i usually set mine at 38 or 40 that way things wont freeze but stay cold.
Dec 17, 2010 | Beverage-Air MT27 Beverage Cooler...
Can i freeze food in a matsui mini fridge freezer with ice compartment?
You can do so but the freezing temperature may not be as good on a standard fridge specially for frozen foods as the mini is mainly meant for emergency foods and beverages.
Sep 25, 2010 | Refrigerators
True cooler frezzing kegs of beer
If I am not mistaken, the True line-up of coolers have a temp control on them that is labeled 0-9.
This particular type of temp control is a coil temp control. I measures the temperature of the coil rather than air temperature.
Always set the control to the warmest setting and move it colder by one number at a time until your product reaches and holds designed temp. Do not go by cooler air temperature as there will be a great swing in temp especially if the doors are used frequently. Always temp the product. In the case of beer, your ideal holding temp is between 35-38°.
If you set the temp control to the warmest setting and the cooler is still freezing product, you will need to have the cooler serviced be a refrigeration tech. It will most likely be a bad control but there may be underlying problems.
Jan 08, 2010 | True TBB-2 Beverage Cooler
The beverages in my True refrigerator are frozen
Definitely a thermostat problem. Make sure that it is set on #3, make sure you have something in the box to provide a constant load (if you are worried about product freezing just put several gallons containers of water in there), set a thermometer on a shelf and let it run for several hours. Temperature should run 35-40f If it still freezes I recommend changing the thermostat. Not the easiest job on a True but the only real option. If it is too warm then raise the setting to #4 and run for several hours more and double check the temperature. It is normal for these box temperatures to "swing" quite a bit especially if empty. The thermostat actually senses coil temperature and not unit air temperature. Typically it cycles off when the coil reaches around 14f and then back on when the coil gets to around 38-40f.
Jul 01, 2009 | True GDM-23FC-RF Refrigerator Commercial
Replacing temperature control on a True beverage cooler
Remove the doors, then the evaporator cover. Just be careful.
May 20, 2009 | True GDM-7 Beverage Cooler
KF48 Beverage Air Freezer permently stuck on "defrost."
Unplug the fridge overnight and defrost it completely. Ensure the thermostat is properly set.
If it does not restart normal function after you plug back, then there may be a fault concerning the digital control, in that case call the number listed on the owner manual.
Jan 06, 2009 | Beverage-Air 44.9 cu. ft. / 1271 liter...
Beverage-Air DD50 Commercial Keg Fridge Not Cooling
The starting components on the compressor could be going bad. You need to turn off the thermostat and then after about five minutes turn it on while listening to the compressor to hear if it kicks in, if it doesn't then you might have faulty starting component, more likely the overload.
Jun 26, 2008 | Beverage-Air DW49 Stainless Steel Beverage...
True freezer gdm 35f to cold
you just have to change the temperature control. I recommend using a white rodgers part no. 1609-105 set the cut out to about 33 cut in at 38 or 39 you might have to set defrost time to less minutes about 5 or 6 if coils dosent frezze with the setting i gave you. the bulb of the temperature control can be placed on the border dof the difusser.
Apr 14, 2008 | True 49 cu. ft. / 1388 liter Commercial...
True TD-50-18 Beverage Cooler Logo
952 people viewed this question
Top True Refrigerators Experts
Dennis Boxerman
John Tripp
John Tripp
christian nielsen
Are you a True Refrigerator Expert? Answer questions, earn points and help others
