Question about Sony Cyber-shot DSC-W110 Digital Camera
When turning on, it stays on for 10 seconds then shuts off. Tried to replace the battery but still has the same problem. Bought it 1 year ago. I think there is something wrong with the camera.
  • 6,831 Answers
Hello
The problem is that the lens has become stuck in the barrel after dropping it. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair center for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
Hope the advise is useful.
Regards
Andrea
Posted on Aug 26, 2010
Can't turn my a/c off Or fan. I hit theoff button & just changes settings. Other than turn the car off itself, I can't figure it out. Earlier in the year rebooting the car'd work. No more.
Laptop not shutting completely (Power light and fan stays on ...
www.tomsguide.com/.../laptop-shutting-completely-power-light-fan-stay...
3 days ago - I have to hold the power button for 5 seconds for my laptop to turn offcompletely. ... I tried removing my battery completely, and started the windows with my A/C adapter and then shut it down ... when i shutdown my pc , my pc has get shutdown but the power light in my cpu tower ... Can't find your answer ?
Nov 19, 2015 | Computers & Internet
Sony kdf60655 green light blinking 37 times and pic goes off/on
I am having the same problem and we purchased the tv new in April of 2005 had the four yr warranty also. That's obviously passed and now we don't know what to do? What did you find out?
May 04, 2009 | Sony Grand WEGA KDF-60WF655 60" Rear...
My camera won't stay on..
Remove the memory cards if any and then switch it on. it must switch on . after that give the reset option from the menu and format the memory and insert it .
There is one more instance in which you will face this problem is if the firmware is damaged. if so you must contact the technician or you can make use of the warranty if you have ..
Regards
-Dileep
Jan 24, 2009 | Cameras
Occasionally while shooting in auto/portrait my shutter will stay open for 1 second or longer, for no reason
Have you tried to reset the camera and reboot the firmware? I had that problem with a friend's camera and it simply worked.
Other thing is: are you using the original battery or a third party battery? sometimes bad quality batteries are creating such a problems like shutting down the camera, shutter lags...
I hope it helps, if not let me know
Nov 03, 2008 | Canon EOS 40D Digital Camera
TV will not stay on
I would just return it and get another one, if they fuss about it, then ask for a discount on a new boxed model.
Mar 19, 2008 | Samsung LN-T3253H 32 in. LCD Television
WST1600 upright
Hi , check battery teminals might corroded need clean the post ,unscrew clean and try to charge , if does not full the battery have problem , need to replace.
Jan 21, 2008 | Westinghouse WST1600 Upright Vacuum
Keeps shutting down.
The solution is found! There's no need to format your HDD
So.
- Unplug the battery;
- Press and hold the reset button for 20-25 sec;
- Put the battery back to it's place;
- Charge your device (when you plug the cable in, it turns on (note that a blinking lightning icon appears on the charging indicator), then it turns off with it's "shutting down" message, dont pay attention on this, just let it charge for about 10-15 minutes (note that the CHG bulb won't be lit));
- Turn on your device. The CHG bulb is lit, Archos doesn't shut down
- Enjoy
Jan 08, 2008 | Archos 504 500870 Digital Media Player
Camera will not turn on
i have a kodak easyshareZ712 IS it is less than 2months old and it shuts off as soon as you turn it on. it comes on for about 1 second and shuts off. i have bought new batteries and it doesn't help
Nov 29, 2007 | Kodak EasyShare Z650 Digital Camera
Camera shuts off seconds after turning it on and battery is charged
I've had this same problem with multiple cameras.  Try purchasing a new battery.  The original batteries don't seem to hold a charge at all.  I've solved the problem by purchasing an external battery charger and two batteries.  When I notice one gets low, I switch and am all set...  My students usually give me a heads up when it's time too.
Mar 31, 2007 | Kodak EasyShare DX7440 Digital Camera
Sony Cyber-shot DSC-W110 Digital Camera Logo
Top Sony Cameras Experts
james laughton
james laughton
Are you a Sony Camera Expert? Answer questions, earn points and help others
