Question about Nokia N95 Cellular Phone
If i have the slide opened the screen and image works ok but if i slide to close the keyboard, the screen goes dark with some glitchy images sometimes and then if i open it again and use the direction keys the screen goes normal again and remains that way until i close the slide again. Sometimes even if i close it remains ok but most of the times it glitches.
    President:
  • 1,561 Answers
There is nothing wrong with your screen, the problem is from the flex that connects your screen to the phone's main board. This flex must have worn out that's why your screen is not displaying any picture.
The problem is common with flip and slide phones. The flex gets worn out as a result of constant opening and close of the flip or slide phone.
I would urge you to replace the flex and I am assuring you that your screen will display picture again. You might also be lucky to find out that the flex is not well fix, that is, it may have loosed contact.
If you cannot change the flex yourself, maybe you should take the phone to a local repairer within your vicinity, so that the flex can be fixed/replaced.
Take care.
Posted on Aug 25, 2010
The projector keeps turning off the screen image but not powering down
The projector has a feature that keeps the screen dark when there is no slide in the projection gate. The light is blocked, but not turned off. There is a latch on the slide of the shutter that controls when it opens (slide in the gate) and when it remains closed (no slide in the gate). It sounds like the latch on the side of the dark shutter needs adjustment. Here is the website where you can get the adjustment procedure. http://www.kodak.com/eknec/PageQuerier.jhtml?pq-locale=en_US&pq-path=6499
Good Luck !!! Jim
Mar 11, 2014 | Office Equipment & Supplies
DVD player image goes dark regularly
As it was banged hard, I would suggest looking for a bad solder joint.
Jan 18, 2013 | Toshiba Televison & Video
My projector will not show the slide.Everything else seems to be working.
I'm assuming the lamp is lit, the light is just not coming through the optics. You didn't specify the model, but most later manufactured Kodak projectors have a "dark shutter". This feature keeps the blinding light off the screen when you arrive at a spot in your slide tray without a slide in it. It senses a slide dropping into the slide gate, and pops the shutter open. Otherwise the shutter stays closed.
One of 2 things has happened:
1. The spring that "pops" the shutter open has fallen off.
2. The "dark shutter" latch needs adjusting.
You can find the Kodak Service Manuals that will give you instructions for adjustment and or replacing the spring at:
http://resources.kodak.com/support/pdf/en/manuals/slideProj/carousel_ServiceManual.pdf
Good Luck!!
Jim
Aug 13, 2012 | Office Equipment & Supplies
The photos are coming our dark
Hi
Check the Following link for Enhance Image
HP ENHANCE Image
  1. From the application you are printing from, click Print , and then Properties . The Print Properties screen opens.
  2. Click the Paper/Quality tab.
  3. Select dpi (light to dark )
  4. Click OK .
Jan 04, 2010 | HP Photosmart 8250 InkJet Printer
Dell inspiron 6400 display goes off < 1 min after switch on time
Connect an external monitor to your laptop and power it up, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight.
If you see a very dim image or black screen or flicking image on the LCD screen it means you have a backlight problem.
The buzzing sound is most likely the inverter problem.
Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out www.lcdparts.net for parts, repair service and DIY info.
Mar 26, 2009 | Dell Inspiron 6400 Notebook
My Gateway mx7118 lcd flickers whenever screen is opened,closed,
Connect an external monitor to the laptop and power it up, if you see a clear image on an external monitor, this means your video card is OK.
If you see a dim image or flicking image on the laptop's LCD screen it means you have a backlight problem.
Mar 13, 2009 | Gateway MX7118 Notebook
I want to know if it is possible topause a slide show and save an image toa folder
Thanks for choosing fixya.com
Most slide shows will have buttons on the bottom to pause and resume. Others you can click them to pause. If none of those are available you won't be able to pause the slide show.
You can however get the images you want to save by using either the "Print Screen" button or a program like "camstudio" to record the screen into images.
I'll cover the "Print screen" button here since its much easier.
First off locate the "Print Screen" key on your keyboard, this is usually above the arrow keys and may only say "PRT SCR"
Now press print screen, open up an application like mspaint, photoshop, or gimp (Any imaging program will do).
Go to "Edit >> Paste" or press CTRL+V to paste the screen image.
You can then use the imaging applications crop or cut features to cut out the image you want to keep.
Hope this helps you out.
Jei
Dec 17, 2008 | HP Computers & Internet
No Display for samsang sgh a 800
my Samsung A800 also lost its inner display recently. When I open the phone, the inner display lights up but fails to show any image. Outer display is mostly OK, once it had trouble to "lock" the image and after opening and closing the phone a few times the outer display showed the image with light and dark bits inverted.
Switching phone off and on restores the inner display most of the time, but the image only lasts until I close the phone.
Jun 20, 2007 | Samsung SGH-x427m
Nokia N95 Cellular Phone Logo
119 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
