Question about Timex Expedition 40141 Wristwatch
Time off by 12 hours - Timex Expedition 40141 Wristwatch
How do I change from military time to civilian time?
After 12 noon take 12 hours off of Military time for hours in the pm
8 is 8am the 14 hours is 2pm
May 23, 2015 | Garmin Approach S1 Golf GPS Watch
12 hours early
Try this:-
First set the watch to 24 hour format rather than 12 hour format.
Nov 05, 2013 | Casio Wave Ceptor WV57HA-1AV Wrist Watch
My timex indiglo Ironman triathlon watchhas twelve hours of military time and then twelve hours of regullar time. HOW CAN I GET RID OF THE MILITARY TIME AND GET ALL TWENTY FOUR HOURS OF REGULAR TIME???...
Actually all the hours are military time. They are the same for the first twelve hours of the day. If you go through the setting procedure it will ask you if you want "12" or "24" hour time. Select 12. "24" is military
May 23, 2011 | Timex 27191 Wristwatch
Timex 1440 time from 24 hour clock to 12 hour
Hi bowingman,
To use 12- or 24-hour time for your watch, please follow the instructions below.
1. Press and hold the "Set" button for 2 seconds. The "Set" button is on the lower right side.
2. Press the "Date Advance" button on the upper right side. This will reset the seconds.
3. Press the "Change Mode" button on the lower left to set the hour. The hour will flash. Press the "Date Advance" button until the correct hour is displayed.
4. Press the "Change Mode" button again to set the correct 10s unit (first digit 1 or 0) for the minutes. Press the "Date Advance" button until the correct first digit of the minutes is displayed. Repeat this step to set the second digit of the minutes.
5. Repeat Steps 1 through 4 of this section to set the year, month, date and day and whether to use 12- or 24-hour time for your watch.
6. When finished, press the "Set" button (on the lower right) to return to the current time view and lock in your settings.
Hope it helps.
Thank you for using FixYa.
Oct 09, 2009 | Timex 1440 Nylon watch
Aquatech watch
press mode button 3 times untill you get into the time set mode - press lap/reset twice until the hours start to blink.
press start/stop and cycle thru all the modes depending what time you want to set - it will go thru 1, 2, 3, etc thru 24 H then 1, 2, 3, etc thru 12 A then 1, 2, 3, etc thru 12 P - depending on thte time you want to set the A is for AM and the P is for PM
hope this helps
jeff
Jul 23, 2008 | Watches
Timex Indiglo WR 30M
NOTE: 12/24 HOUR TIME IS SELECTED BY PRESSING RESET/LIGHT ONLY WHEN THE HOURS MARKER IS
FLASHING. THE “A” OR “P” WILL DISAPPEAR WHEN THE
WATCH IS SET TO 24-HOUR TIME.
Mar 10, 2008 | Timex 27191 Wristwatch
Date changes wrong time
thats because analog watches don't know the difference between AM/PM. First reset the time, moving the hour and minute hands another 12 hours will let you know exactly what mode its in (am/pm) first allowing you to set the date correctly.
Nov 12, 2007 | Watches
24 hour-12 hour time
Press Set - hold (top Left button) -When the sec start flashing go to the bottom left button press it 3 times -When the hour flashes press the bottom right button 1 time -Press the top left 1 once with
Jul 05, 2007 | Timex Fashion Classics 78587 Wrist Watch
Timex Expedition 40141 Wristwatch Logo
22 people viewed this question
Top Timex Watches Experts
Ansel Alberto
Ansel Alberto
Mark Schmit
Mark Schmit
Carol
Level 1 Expert
Are you a Timex Watch Expert? Answer questions, earn points and help others
