Question about Microwave Ovens
Low coffee flow or low pressure on Delongi magnifica coffee maker. It is 4 years old. I have cleaned it and could not find a restriction. Could the pump be weak?
  • 3,083 Answers
It is possible that the heat pump is sticking, dragging, and failing, but more likely the feed tube is still partially blocked. Did you clean the water feed tube? If not, try running a solution of about 50% white vinegar and water through it to ensure cleaning the tube, then run a couple of pots of plain water to clean the vinegar out. Here is DeLonghi's web support page, which includes a number you can call:
http://www.delonghi.co.uk/guarantee.php
Good luck to you, hope this helps, and thanks for using FixYa.
Posted on Aug 25, 2010
Just put in a new moen kitchen faucet, why does it have hardly any water pressue?
You might have a clogged aerator screen. Remove the aerator from the faucet and see if the flow is normal. You can rinse the aerator off if it's clogged. It's also possible the stops (shutoff valves) aren't open all the way. Sometimes, if they're old, they don't turn on fully again after you shut them off to put in the new faucet. If you still have low pressure after removing the aerator, you may need to replace the valves.
I don't know if the instructions mentioned it, but it's good practice to remove the aerator and run a faucet to flush the water line after installing it. There's usually a lot of debris that comes through at first. That's usually why you'll have low pressure in a new faucet.
Jul 14, 2011 | Microwave Ovens
My B30 is stopping up in 4 days after it is cleaned with white Vinegar. Is there any other cleaner?
There are many coffee pot cleaners on the market, but white vinegar will normally do the job, if you do it thoroughly. If might take 3-4 passes through for all the minerals to be removed and then a once a month cleaning would be enough to keep it free flowing.
Jun 30, 2011 | Microwave Ovens
Lost directions - how to descale keurig ?
Hello, Here is a tip i wrote, see if this helps you.
Have you ever wondered, 'how do I descale my expresso machine?' First lets us understand what is exactly is scaling. The build up of minerals inside the hot parts of your coffee machine or espresso machine is commonly called lime scale. When lime scale builds up inside the Espresso machine, it slows down the water flow, reduces the boiler capacity and can prevent your coffee machine from working properly. To keep your Espresso machine operational at full order, it is important to descale it every three months. The time intervals between descaling depend upon many factors. Quality of your water and the amount of water running through the machine are the two main factors that decide the frequency at which you should descale your Espresso machine. The more you your machine, more often should you descale it. In some cities, in conjunction with a water filter you can use your coffee machine for a year or more without descaling at all. If you use less water by drinking espressos you'll need to descale less often than if you make cappuccinos.
Descaling products are widely available from stores that sell coffeemakers and espresso machines. Be sure that the product you buy to descale your Espresso machine is intended for this specific use only. Before you descale your Espresso machine, always unplug it and make sure that it is cold. Also, never immerse the appliance in water and nor should you use abrasive cleaning products or scouring materials on any part of your Expresso machine. In case your Espresso machine does not come with a instruction guide or booklet, then use a proper citric acid based descaling solution designed for espresso machines. This should be mixed and prepared as per the instructions on the bottle or packet. Once your Espresso machine has been descaled properly you would not be left wondering, 'how do I descale my expresso machine?', treat yourself to a great cup of coffee. Some popular models of Espresso machines are Krups EA8080 Espresseria Automatic, DeLonghi Magnifica EAM3200S, Krups Nespresso CitiZ & Milk XN 7106 Fire-engine red, DeLonghi Perfecta ESAM5400, DeLonghi PrimaDonna ESAM6600, DeLonghi Magnifica ESAM4200S, DeLonghi Perfecta ESAM5500 and Magimix Nespresso Citiz M190.
Jun 29, 2011 | Microwave Ovens
We have a 12 cup Mr. Coffee about a year old. We put 4 scoops of coffee in and the appropriate amount of water. Every day, the filter overflows and grains of coffee get into the pot. How do we keep this...
Because I own a espresso company,I believe I can help you. There is several things that can cause a coffee machine to over flow. 1, putting to much coffee in, where water can not drain through filter. 2. The grind of the coffee, if it is ground to fine, like ground for espresso, will not allow coffee to flow through filter , drip machine that are not under high pressure like espresso machines have to have ground more course. 3, wrong type of filters, not fine enough for water to flow, or made for high pump pressure machine such as espresso machine . 4, putting to much water in, is not an issue on a mr coffee, because even if you fill it to full cup line, it would have nothing to do with filter over flowing, besides the coffee grounds always absorb some of the water anyway. In conclusion, my positive professional diagnose is Grounds of coffee to course, and 4 scoops seem a bit to much for a filter of a mr coffee machine that holds only 12 cups. To test this is make a pot same way and use only two rounded scoops and see what happens, if does not over flow that solves that. But your saying I want it stronger, believe me I know. I too like my coffee strong and a flavorful . I have that solved too. Go to a good walk in espresso shop, like a star bucks, tell them you want some good strong blend and have it ( Ground for Drip) and then still only put two rounded scoops, it takes less do to the blend and kind of coffee. Please let me know if my advice worked, thanks mike. oh notice my screen name of mc1 bean, now you know, I know what I am talking about :)
Jun 07, 2011 | Microwave Ovens
How do you go about "descaleing" the coffee maker? The water does not flow through the coffee capsule very well.
I know that most grocery stores sell a "cleaner" or two next to their coffee filters/coffee makers/kitchen appliances section. These are usually heavily acidic, and will do a great job of cleaining your coffee maker. I've always been wary of acid in my coffee though, so I just use white vinegar. It'll do a decent job of cleaning out the coffee maker. Run a 1:1 mix of water and vinegar through your coffee maker, drain it, then run water through at least twice.
Scaleing/deposits building up in a coffee maker are signs of imperfections in the water. All tap water has it, but if you don't want to worry about it, use bottled or filtred water in your coffee pot. Plus, your coffee will taste better!
Mar 16, 2011 | Microwave Ovens
What am I doing wrong. Cusinart 1200 less than a year old. Takes an hour to brew. Took out permanent filter and use paper #4 filter. Has been slow since I bought it. Please advise. Other than that,...
Try cleaning it with vinegar. Sounds like you need alot of help on this one run a full pot of vinegar through the machine. with a paper filter in the basket. then run two to three full pots of just water. this should help decale the coffee pot.
Mar 09, 2011 | Microwave Ovens
We live in a house built in early 60's. Re; Plumbing to kitchen sink and dishwasher. On vary rare occasion the sink faucet will have decent water pressure. We have changed the water faucet with a Moen. As...
if this is the only place in the home where water pressure is a problem then the lines may very well be the issue. if you have low pressure throughout the home then there may be a problem with the main water supply in the home. if the lines are galvanized pipe then they may be restricted due to rust or other deposits forming on the inside of the pipe. unless you are good at plumbing then i would suggest having a professional come out and assess the condition of the lines.
Feb 25, 2011 | Microwave Ovens
The gas flame on my 4 burner Chambers stove top is very low. When we try to adjust the air flow the flames increase for a moment but then return to being low. What could the problem be and how can we fix...
I had the same problem after a melted butter accident... I shut off the gas under the stove by a valve. Then I took the burners off and cleaned every orifice I could find. Still no luck. Then I cleaned out the main orifice right out of the controls for the burners, it was tiny and had to get a very small pipe cleaner made for an air brush gun. That did the trick! But now I have soaring flames and I'm trying to figure out how to adjust them back down.
Jan 11, 2011 | Microwave Ovens
Our Magimix 11400 (less than 2 years old) heats normally, the vapour nozzle fonctions too, but our problem : when the coffee selection switch is put on the motors starts up, seems to fonction properly but...
Hello Pat, You have a common occurring problem. Your tubing in clotted. The least expensive solution is to use regular vinegar instead of water for several cycles, no coffee grounds. The clot will dissolve and water flow will return to normal. Cycle just water until no taste or smell of vinegar is present. Have some HOT COFFEE.
Oct 12, 2010 | Microwave Ovens
Microwave Ovens Logo
80 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Microwave Oven Expert? Answer questions, earn points and help others
