Question about Kenmore Refrigerators
Model; 253.51392105. No water from door and no water to ice maker. what are the likely causes?
  • funk_herman Sep 02, 2010
    Thanks but no thanks. I figured it out.
  • 1073 Answers
SOURCE: Ice maker leaks water into Ice bend. When it cycles I can watch it drip water from the ice maker.
not familuar with the brand but sounds like one of 2 issues
if it is overfilling making ice cubes larger than normal, adjust the ice maker fill time if it is possible
icemaker fills and cuts off but water valve seeps water after the fill causing the water overfill
one of the 2
Posted on Jun 24, 2008
kevin000
  • 1847 Answers
SOURCE: Ice maker problem.
http://www.kitchenmanuals.com/manuals/mfg/kenmore/kenmore_refrigerator_product_list.html
hope this link will help.
Posted on Jun 26, 2008
SOURCE: Ice maker not working
I have a whilpool Model # ED5FHXC001A side by side Energy Saver refridgerator. It was purchased late in 2006. It's not making and dropping ice. Any ideas what the problem may be? Thanks
Posted on Jun 28, 2008
  • 52 Answers
SOURCE: Ice Maker
Likely that the water supply tube to the icemaker is frozen. It will be a white rubber tube on the right side of the icemaker. Warm it with a hair dryer, remove it from its aluminum tubing, and make sure there is no ice all the way back to where the supply tube comes from the water valve. After thawing, your icemaker should start working again.
Now..... why did it freeze? Most likely, there is a restricted airflow to the back of the unit, which is need to keep that aluminum supply tube just warm enough to assure all the water flow OUT of it into the icemaker, and doesn't freeze up on contact. Make sure your coils and the airspace under the fridge are completely clean (vacuuum them well) and it should cure the problem.
Posted on Jul 17, 2008
duby1990
  • 370 Answers
SOURCE: ICE MAKER NOT WORKING
Check to make sure you freezer is at 0 to 5 degrees. If it is not the water valve to the ice maker will not even open.
Posted on Nov 20, 2008
I have a GE Refrigerator that the ice maker keeps getting frozen up, I have changed the ice maker and the water valve out and it has started doing it again now...works good for a couple weeks maybe???
check the ice chute door,where the ice comes out of the door,sometimes the door doesn't close or it's broke,warm air gets up into the freezer and will start icing up everything the air hits,or the door gasket has a tear in it but if it's not water leaking from the ice maker then it's an air leak causing this issue.
Nov 02, 2017 | GE Refrigerators
Frigidaire professional refrigerator
Sounds like you have a problem with water valve/triple solenoid assembly. It controls the flow of water to the door and ice maker. I believe it comes as a complete unit.
Dec 28, 2013 | Refrigerators
Water overfilling the freeze tray on Whirlpool conquest ice maker
The overfilling is most likely caused by defective water control valve on the ice maker side. The replacement for your model is a=> W10408179 Water Inlet Valve
The water fill adjustment can be found in the Ice Maker Troubleshooting Service Manual These settings can cause too little or too much by turning the set screw so use caution. I will be here should you have questions or comments, Thanks Sea Breeze
Mar 08, 2013 | Whirlpool 25.6 cu. ft. Side-by-Side...
Ge refrigeration model 20-25 icemaker not making ice
Fill ice maker with tap water and allow the water to freeze. If when the ice maker cycles and drops ice into ice bin it chooses not to refill with water at end of the cycle. That would point to the dual water control valve. If ice maker does nothing when filled with tap water that will indicate a defective ice maker. The model number you listed does not appear to be correct. Look around the fresh food section door frame and see what you have. This could be the ice maker or the dual water control valve causing this problem. Thanks Sea Breeze
Nov 16, 2012 | GE 20.3 cu. ft. Bottom Freezer...
Ice maker will not make ice,have water but no ice.
Many people see this as a problem but if you take a look you have two separate controls for the ice and water system. So what's next? Look for a model number around the fresh food section door and sometimes your model number you may have looked at it every time you open the door and did not realize that is what that is. Locating Your Model Number or lets go to Maytag=> HERE and in the pull down choose if your model is a side by side or other than a side by side. Neat Tool! So now back to your ice maker and being the way most ice makers are they have a side to the water valve on their own somewhere near the water control valve on back of your refrigerator and near floor on most. The ice maker in most cases tells that water valve when the ice maker needs water again so many times it is the problem anyway. If your ice maker has cubes in it and still will not drop the cubes then it is the possibly the ice maker causing the problem but if you fill the ice maker with tap water and it freezes and then dumps cubes into the ice bin then the problem is the water control valve on the back of your refrigerator. Here is a short clip below. And here is a search for=> Maytag Refrigerator Water Control Valves and a search for=> Maytag Refrigerator Ice Makers I hope this has helped, Thanks, Sea Breeze
Here is how to=> Replacing The Water Valve on my Refrigerator
Apr 19, 2011 | Maytag Refrigerators
I have a Frigidaire side by side refrigerator, model # FRS26LH5DQ5. When the ice maker fills with water, water also comes out of the water dispenser on the front of the left door. What is causing the...
HI, TO ME LOOK THAT YOUR REFRIGERATO HAS A BAD ICE MAKER, BUT IF YOU REFRIGE IS OVER 5YEARS OLD REPLACED THE ICE MAKER AND SELENOIDE WATER VALVE ,100%PROBLEM REPAIR..
Feb 21, 2011 | Frigidaire Side by Side Refrigerator 26...
I have a side by side model ACD2238HTS SN#13640707LJ. The ice dispenser door spring seems too strong and you have to reach up with your fingers to pull it open so the ice can come out.
Maybe excessive water dripping from the ice maker that cause the door to "lock-up" a bit. May need to adjust the water flow to ice maker. If that doesn't work, maybe the tempt is set above recommended level and causing the door to stick.
Feb 04, 2010 | Refrigerators
Ice maker sequence is out of syncronization
I believe your ice maker is the reason for the problem. If you have a model number it is possible that parts are avaiable. Sometimes the complete ice maker will need to be replaced because the controls are electronic in some model ice makers. Could you send the model number of your Whirlpool Refrigerator? Thanks, Sea Breeze
Aug 13, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Kenmore Ice Maker
Sounds like a water valve problem to me. Force the ice maker to cycle. (turn it off and let it get cold for at least an hour then turn it back on). Test for voltage on the ice maker side of the valve. The valve is usually in the back near the floor. Just follow the water line. Another solution. switch the wires on the water valve. then try the water dispenser and see if it makes the ice maker fill up. See if when the ice maker cycles water comes out the door. If the ice maker causes water in the door , replace the valve, If door switch causes ice maker to fill up replace ice maker again.
Jun 27, 2008 | Freezers
Fridge freezer door ice maker
the ice maker controls the seloniod the icemaker wire arm must be all the way down .just because the seloniod test good doesnt mean the valve seat isnt stuck the water valves open by your house water pressure if your filter is dirty this can also lower the pressure if the icemaker module is bad this also can cause it if you pull the front of the ice-maker off you will se a bunch of holes if you get a piece of 10 Gage house strip about 1/4 inch off either side and insert it into the holes marked t and h that will test cycle the ice maker they will be close together don't get shocked if the ice maker cycles and doesnt fill and the ice maker fill tube isn't frozen replace the water valve if the ice-maker doesn't cycle replace the brown motor module
Jan 09, 2008 | Jenn-Air JCD2389G Side by Side...
Refrigerators Logo
32 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
oldblindman
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
