I lost the manual for my healthometer model HDM562Cd-18. I need to reset and start my weight goal again. Thanks
SOURCE: weight
There's no straightforward way, but thee are some workarounds, like changing the date to the deadline, etc.
The easiest workaround, I think, is to force your wii into thinking you've made the deadline early. I put in that I wanted to gain, instead of loose, 2 lbs, so I'm going to fake out the wee into thinking I've gained that 2 lbs already, by either holding something that weighs an additional 2 lbs or adjusting the clothing weight to compensate.
Once the wii registers that I've passed the goal and allows me to make a new goal, I'll re-do my body test with my regular weight. My faked weight will be erased, but my new goal will remain.
Posted on Apr 26, 2009
  • 50 Answers
SOURCE: Lost owers manul
You can get the manual to your Monitoring Scale right here: http://www.healthometer.com/manuals/HDM575-18_English.pdf
Posted on Sep 24, 2009
Testimonial: "This was very helpful and now I have the pages I need to start my goal to better health..."
dontbother10
  • 2220 Answers
SOURCE: Need manual for Remington Limb & Trim 8, Model
I tried the numbers you provided and none crossed.
I went here:
Remington.com
http://www.desaparts.com/index.htm
  • Type "YourModelNo" into the "Model #:" window, then click search.
  • Click the YourModelNo - Remington Electric Chain Saw "View Model" link.
  • Click “View Owners Manual” or "View Illustrated Parts Breakdown" link.
The most complete owners manual is "M15012US (and several others)" viewed as explainewd above. Page 9 discusses oil weights. Standard bar oil is 30 weight non detergent with addatives to help it adhere to the bar. That would be my recommendation. HTH
Lou
Posted on Jan 16, 2010
SOURCE: im trying to reset my weight goal on wii fit plus,
It has been suggested to change the present date on the Machine to the goal date. Then after goal has ended change it back? I haven't tried this yet myself.
Posted on Jan 23, 2010
SOURCE: Healthometer Bathroom Scale
http://www.healthometer.com/Manuals.aspx
Posted on Aug 23, 2010
Just replaced battery - trying to reset the scale to 0.0
PDF]Instructions for use of ThinnerĀ® Bathroom Scales
www.conairscales.com/catalog.php?product_id=428&ib=en
Scales for the way you liveĀ® ... Tap on the scale and wait until "0.0" appears; press Set button, ... button to change the goal weight if necessary, once the ... NOTE: 1. When the scale traps zero error, "Err" will show. Please try again. 2.
How to Set a Digital Health O Meter Scale to 0.0 - Livestrong ...
www.livestrong.com > Weight Management
Aug 12, 2015 - The scale may not register at 0.0 when starting out... ... The Differences Between Balance Beam Scales & Electronic Scales ... 10 High-Tech Health Tools toTry This Year; Are You in Need of a Digital Detox? How to Start Doing Parkour. References. Healthometer.com: FAQs; "Health o meter User Manual" .
Jan 05, 2016 | Health & Beauty
Need owners manual for Healthometer BFM588DQ-81
I have not found a manual for Model BFM588DQ-81anywhere currently because the manual is no longer on Health-o-meters website, only the current supported scale. However, I have one and can tell you what I know on how to operate it.
First Remember you ALWAYS have to tap (slightly touch the middle of the scale to initiate it to calibrate ON to ready to take your weight) the scale and you then wait for the little lines at the top and bottom to flash on and off, and then show a 0 on the scale where the Weight will be once you have stepped on the scale. However, make sure your feet are slightly moist (if you just woke up and your feet are dry wipe them with a moist cloth first) for a good contact on the pads that will send the small signal through one leg and back down to the other to measure your body fat and hydration levels.
For those having problems with false readings or Lo readings after changing batteries (Lo means the batteries are low and to change if you haven't done so), make sure batteries are good even if you just bought them by checking them in a Battery Output checker, which you can get at the store...or check the expiration dates on the battery, things can sit around at the store for a while some times especially at small grocery or convenience stores.
Then if you are still getting false or Lo readings, you need to do a Factory Reset by flipping over the scale and look toward the top where you will see a small hole with raised letters, not colored, that show RESET under the small hole. Get a tooth pick or some about the same diameter and put it in the hole and press the little button. You can feel it when you get the toothpick--- or whatever you are using---in the middle of the button and it slightly depresses. Hold it down for at least a count of "One Thousand one to One Thousand ten," which means ten seconds. That should do it.
Then you need to make sure your settings are set by holding down the number on the front end that you will use to save your data, and hold down the Set/Save button on the top front at the same time. When it starts flashing the 5 for Feet in the Height either change that with the History button by pressing it until you get the correct number or leave it by pressing Set/Save button again. Use the Set/Save button to Save and Move to the next item to Set/Save and the History button to Change the number or item such as Gender from Female (the Default is 5Ft 3in Female who is 18 years of age and the Goal starts out at 100 but you can save a Goal Weight or not by choosing YES or NO then set the Goal if you Choose YES).
The Date and time are set by just holding down the Set/Save button until it flashes in the little yellow box in the bottom left of the screen. Then use the buttons the same way as you did above.
By the way when you see H with numbers after you have weighed Saved (To Save: hit Save while the numbers are on the screen) and once they disappear you just press your number again hit History to Scroll through your history... the H stands for Hydration percentage.
Hope this helps.
Oct 25, 2011 | Health-O-Meter Health o Meter BFM588DQ-81...
Weight Watchers bathroom scale, Model WW60X
I got it! Press "set". You should see "start goal" in the bottom right. Press the user # you want to save as and press "set" again. The display will blink then display "0.0". Step on the scale to get your current weight. Once it's read you current weight, press "set". A goal weight will display. Press "User 1" to make your goal weight go up and "User 2" to make it go down. Press "set" when the display shows your goal weight. That's it. Now all you have to do is press your user # and wait for "0.0" to display before stepping on the scale.
Apr 24, 2009 | Conair WW60 Weightwatchers Scale
I have no manual or warranty
Mar 21, 2009 | Conair WW60 Weightwatchers Scale
Can I reset the scale?
This link allows you to ask questions and request a users manual....I hope this helps. http://www.conair-store.com/cc_contactus.asp
Dec 31, 2008 | Conair WW60 Weightwatchers Scale
Conair weight watchers ww37gd scale
To set
1. Push the set button, you will get ------
2. Push the user
3. Push set again the user number will blink 3 times and show 0.0
4. Get on the scale- when it shows your weight push the set button. This is your start weight
5. Then it will automatically take 10% and show your goal.
6. Push the set button again this will set the goal
To Weigh
1. Push the user number that you set up the P-? number will blink 3 times and show 0.0
2. Get on the scale it will show in this order
a. your weight now
b. your weight since the last time you weighed
c. The total loss toward this goal
d. Total needed to reach your goal
Mar 18, 2008 | Computers & Internet
Computers & Internet Logo
49 people viewed this question
David Payne
David Payne
