Question about Porter Cable 7812 Wet/Dry Vacuum
Changing porter cable 7812 vaccumm power cord
I have the porter cable 10 gallon tool trigger drywall vac why is it that the bags keep braking. Have had it for years and it's only been about the last two years they rip open way before they are half...
Need some more information, are you vacuuming dry wall dust or wet dust or saw dust ? The reason I ask is sometime their are "upgrades" available for the newer models of vacs you may not be aware of, when I worked at the Big Box H D tool rental center the vac we rented out used a water filtration set up instead of bags U might wont to check newer model for any changes, like you ,I had Craftsman for over 15 yrs. and when it died the replacement vac had a new mod for the filter that I always thought was needed. Good luck , Bret
Sep 28, 2014 | Porter Cable 7812 Wet/Dry Vacuum
VACUUM FAILED TO AUTOMATICALLY START AFTER PUTTING ON A NOTHER POWER TOOL
did it start and run for a second before you tryed pluging the power tool in
Feb 18, 2013 | Porter Cable 7812 Wet/Dry Vacuum
Why does the motor start, then shut off?
Check for a stuck or binding float switch
Jan 31, 2013 | Porter Cable 7812 Wet/Dry Vacuum
Where can I buy replacement bags ?
Porter Cable is a professional tool store product. Look at a Porter Cable dealer,or online nowhere else
Oct 27, 2009 | Porter Cable 7812 Wet/Dry Vacuum
Our Dyson upright vaccumms beater bar wont move. the vaccumm will **** up air but the bar underneath wont move. The gears are not working property.
It could be the clutch that's causing the problem or the belt. Bring your vacuum to a local repair shop and have it look at, but it sounds like it could be either one of those problems.
Sep 08, 2009 | Dyson DC07 Animal Bagless Upright Cyclonic...
Burnig smell when vaccumming
check the turbine controlling the brush. else the bearing might be blocked,damaged and burnt.
Dec 25, 2008 | Kirby Vacuums
Porter Cable 7814 vacuum
Possibly a faulty power cord, replace the power lead to the machine or check for damage to the cable.
Check that machine is not blocked, motor may be overheating due to blockage, if you have good suction this indicates machine is not blocked.
Nov 09, 2008 | Vacuums
Craftsman compressor
They put this under vacuums, relist it in the right place.
Dec 16, 2007 | Porter Cable 7812 Wet/Dry Vacuum
Porter Cable Roofing nailer rn175a
Replace the O Rings and the trigger valve assembly. 9/10 sticking rods on the Porter Cable guns is caused by a faulty TVA.
Nov 08, 2007 | Vacuums
Porter Cable 7812 Wet/Dry Vacuum Logo
44 people viewed this question
Top Porter Cable Vacuums Experts
Are you a Porter Cable Vacuum Expert? Answer questions, earn points and help others
