Question about Kelvinator KFS220RHY Freezer
Left the door open for 2 hours - Kelvinator KFS220RHY Freezer
  • 15,935 Answers
The evap coil is likely frozen over from running 2 hours straight.
Defrost it for 24 hours, and re-try. Inspect that the evap fan is operating properly.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Aug 26, 2010
Door was left opened for sometime and freezing is not good now, what I should do
If the only fault was the door left open, switch off and defrost completely for 24 hours. Clean condensor coil. Restart and run for 12 hours before checking.
Aug 07, 2012 | Woods 201 cu. ft. Upright Freezer V2003RW3
I left the door open a crack for over 12 hours. A few things thawed partially. After closed the door, it sounds like it is running but nothing is freezing.
Turn it off for 1hour and restart, the reed valve got hot and wont open, do it and get back to me urgent or you will lose the lot. Russ
Aug 22, 2011 | Frigidaire Freezers
Left door open, closed next day, but only blowing cool air now
You will need to turn the unit off and let it completely unthaw. There is frost that builds up in the ducts and behind the panels when the door is left open that will cause the unit to not cool or circulate where needed.
May 10, 2010 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
Door was left open for 2 hours after closing and leaving shut for 8 hours the temperature is not as cold as before. the outside walls are warm to the touch
the compressor must be on heavy load. try switching off for some time and then try, it might work. if not, try to get the service guys
Aug 10, 2009 | Frigidaire 20.6 cu. ft. / 583 liter...
Won't freeze after door was left open
Having the door open has introduced an excess of humidity and therefore condensate/ice into the freezer coils. The coils are therefore iced over. You have choices depending upon your skill level. You might: allow the unit to sit unplugged with the door open until the excess ice thaws out and wets the floor underneath, which may take from 6 to 24 hours. You might: do this, adding some heat source in the freezer to accelerate the process. You might: locate the defrot timer, advancing the timer until a click is heard indicating the unit is in defrost, and repeat after about 15 minutes to defrost the unit with it's own heater. You might: let it recover just as it is but it will take a couple of days to clear itself.
May 19, 2009 | Hussmann Freezer 12 Facing Straight Glass...
Whirlpool model EV201NZRQ, stoped freezing,lights are on, compres
in leaving the door open you may have over heated the compressor and not it is not pumping enough freon anymore
Dec 11, 2008 | Whirlpool 19.6 cu. ft. Upright Freezer...
Kenmore upright freezer
reason is that the evaporator is blocked with ice and hence no air circulation.
either
switch off for 24 hours with doors open
or
remove back panel inside freezer and melt ice off with a hairdryer
Oct 16, 2008 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Freezer door left open
if the alarm is sounding its probably trelling you the freezer is at too high a temperature. plug it in and leave it plugged in, it can take several hours to re freeze
Sep 16, 2008 | Kenmore 20.3 cu. ft. / 575 liter Upright...
Kelvinator KFS220RHY Freezer Logo
Top Kelvinator Freezers Experts
Mike Squire
Victor Nwachukwu
Victor Nwachukwu
Are you a Kelvinator Freezer Expert? Answer questions, earn points and help others
