Question about Motorola Mobility H550 - Bluetooth Headset - Black/Silver Wireless Headset
How do i get the device into pairing mode? - Motorola Mobility H550 - Bluetooth Headset - Black/Silver Wireless Headset
    Sniper:
  • 123 Answers
Here is a link to a PDF of the manual...MANUAL
Posted on Aug 25, 2010
I want to reset my HBS 900 to my phone I have a ZTE from cricket how will I be able to do that
Your manual is here. You just need to go into the Cricket settings and go to Bluetooth and Pair. You don't have to reset the headset.
ENG
1) Easy Pairing a) Slide the Power switch to the ON position. b) If it is your first time pairing the device it will automatically enter pairing mode. If it has been paired but no paired device is in range it will enter pairing mode after 10 seconds. • The LED indicator will be solid blue. c) On the device you wish to pair, find the Bluetooth menu and search for or add new devices. d) Select LG HBS900 from the list of devices. e) If asked for a Pass/Pin Code enter 0000 (4 Zeros). f) Once the devices are paired, you will hear “Your headset paired.” • The HBS-900 will automatically turn off if not paired within 3 minutes. 2) Manual Pairing (pairing with another phone or re-pairing) a) With the power off, press the CALL button and slide the Power switch to the ON position at the same time for 2 seconds. b) When the headset enters Pairing Mode, the LED indicator will show a solid blue light. After the procedure repeat Easy Pairing steps c though f.
http://www.lg.com/us/support-product/lg-HBS-900#manuals
Sep 23, 2016 | ZTE Cell Phones
Tip
How to make a bluetooth headset pair with your phone or computer
1. All bluetooth headsets can be discovered by other bluetooth enabled devices (e.g. phone, computer) whenever they are in pairing mode.<br /><br />2. You'll know that it is in pairing mode by paying attention to its indicator light, which will always show a different configuration from the usual stand-by mode. On some of them, it will be steadily lit, whilst on others will flash rapidly, often in more than one color.<br /><br />3. You must ensure your headset is turned off, prior to putting it in that mode.<br /><br />4. Most bluetooth headsets, mainly the ones which are turned on by pressing and holding a Multi-Function Button (MFB, also called answer/end button) for a couple of seconds, enter the pairing mode by pressing and holding the MFB for much longer than the time required for them to be turned on (usually 6 to 10 seconds). Release the button when you notice it is in already in pairing mode (see rule #2). Other headsets, usually the ones whose microphone is in a boom, enter the pairing mode just by opening the boom, provided that either they have never been paired to other devices before, or, otherwise, those devices have their bluetooth radios turned off. <br /><br />5. Once it is in pairing mode, make the bluetooth application, on the device you want to pair it with, search for new devices. After a little while, your headset should appear on the device' screen. Select it and make it connect. If a pairing code (or PIN, or passkey, or pass code) is requested, enter either '0000' (four zeros, which happens to be the most commonly code chosen by manufacturers), or '1234', or '8888'.<br /><br />6. If the pairing process is successful, your headset will enter the stand-by mode. There might be some type of indication that a bluetooth headset is attached, on the device just paired with it too.<br /><br />7. You headset will stay in pairing mode for a couple of minutes only. If it happens to leave that mode before you are able to finish the procedure, turn your headset off and start it all over again.<br /><br />Hope these tips can be useful to you.<br /><br />Regards,<br />Carlos
on Nov 12, 2010 | Cell Phones
I can not pair my phillipson bluetooth #BCK08A to my blackberry curve. How do u pair them together?
Make sure you are in "pairing mode" by holding down the Multi Function Button (MFB) until the red and blue flashing alternately. When the device is off, holding down the MFB for about 5 secs will turn the device on; however, don't release the button and continue to hold until red and blue flashes. Then, you are in pairing mode.
May 06, 2011 | Philips Cell Phones
Can't remember how to pair my LG HBM-710 to my new phone - Samsung Fascinate. Can you help?
to pair a blue tooth device to a phone first you must turn the bt power on the phone to on,then you have to put your blue tooth device into discovery mode,now most manufactures use the power button for thisw feature.By holding down the power button on your device when turning it on for 6 to 10 seconds it usually puts the device into discovery mode.there should be a light that stays on on your blue tooth device.once you have the bt device into discovery mode you will be able to pair the device to your phone by search or add new device,once it pairs it will ask for a pin or pairing code.most manufactures of blue tooth devices use a 4 digit factory pin pairing code they aare as follows 0000,1234,9999,or 1111 once youve put tjhe pin code on they will pair ,i hope this helps
Feb 25, 2011 | LG HBM-710 Wireless Headset
Not discoverable by iphone
In order to pair it with your phone, it must be in pairing mode first. If it has never been paired to another device before, just by opening the boom, the indicator light should flash alternately in red and blue, thus indicating it is in pairing mode. Otherwise, in order to force it to go into pairing mode, press and hold the volume (either + or -) key whist opening the boom. It should flash alternately in red and blue. Only then, make your phone's bluetooth application search for new devices. After a little while, VMX100 should appear on-screen. Select it and make it connect. If a pairing code (or PIN, or passkey) is requested, enter '0000' (four zeros). If the pairing process is successful, your headset should enter the stand-by mode. You can pair your headset with other devices too (the VMX100 is able to pair to up to 4 different devices). If you wish to do so, make sure that all devices previously paired with it have their bluetooth radios turned off. Then, repeat the pairing process for each one of the new devices.
Hope you are able to sort your problems out soon.
By the way, if your headset's user guide happens to be missing, feel free to download it from this location.
Regards,
Carlos
Feb 24, 2011 | Sennheiser VMX100 Bluetooth Headset...
My blackberry 8520 wont pair with Ford audio
In order to pair a BlackBerry device with a Bluetooth device, the Bluetooth device must be in pairing mode. Most Bluetooth devices are not set to pairing mode by default. Therefore, refer to your Bluetooth device manual for instructions on how to set the device to pairing mode.
1. On the BlackBerry device, in the device options, click Bluetooth.
2. Click the trackwheel and click Add Device. The Select Device list appears and lists devices that are in range and available to be paired.
Note: Only devices that are in range and are in pairing mode will appear in the available device list.
3. Click the device to which you are pairing. The Enter passkey dialog appears.
4. Enter the passkey to authenticate the device. Most Bluetooth devices contain a hardcoded passkey. See your Bluetooth device manual for the passkey.
Best regards
Apr 26, 2010 | RIM BlackBerry Curve 8520 Smartphone
Cannot pair vmx100 with blackberry bold 9000
In order to pair it with your phone, it must be in pairing mode first. If it has never been paired to another device before, just by opening the boom, the indicator light should flash alternately in red and blue, thus indicating it is in pairing mode. Otherwise, to force it to go into pairing mode, press and hold the volume (either + or -) whist opening the boom. It should flash alternately in red and blue. Only then, make the other device's b'luetooth application search for new devices. After a while, the VMX100 should appear on-screen. Select it and make it connect. If a pairing code (or PIN, or passkey) is requested, enter '0000' (four zeros). If the pairing process is successful. Now, ot pair it with the other device (the VMX100 is able to pair to up to 4 different devices), make sure the previous device has its bluetooth radio turned off. Then, repeat the pairing process with the other device.
Regards, Carlos
Mar 07, 2010 | RIM BlackBerry Bold 9000 Smartphone
How pair bluetooth Jabra vbt2050 with a blackberry storm 2
Mar 04, 2010 | RIM BlackBerry Storm2 9550 Smartphone
How can i set the em227pk bluetooth up for pairing? plz help.
In order to pair a BlackBerry smartphone with a Bluetooth enabled device (e.g. a Bluetooth enabled headset), the Bluetooth enabled device must be in pairing mode. Most Bluetooth enabled devices are not set to pairing mode by default. Refer to your Bluetooth enabled device manual for instructions on how to set the Bluetooth enabled device to pairing mode.
To pair the BlackBerry smartphone with a Bluetooth enabled device, complete the following steps:
1) On the BlackBerry smartphone, click Options > Bluetooth. If you cannot find the Bluetooth option,
2) Open the menu and select Add Device. The Select Device list appears and lists Bluetooth enabled devices that are in range and available to be paired.
Note: Only BlackBerry smartphones enabled with Bluetooth technology that are in range and in pairing mode will appear in the available Select Device list.
3) Select the Bluetooth enabled device with which you are pairing. The Enter passkey dialog appears.
4) Type the passkey to authenticate the Bluetooth enabled device. Most Bluetooth enabled devices contain a hard coded passkey. See your Bluetooth enabled device manual for the passkey.
Note: 0000 is the universal passkey for pairing any Bluetooth enabled device with a BlackBerry smartphone.
Note: Once a Bluetooth enabled device is paired, it appears in the Paired Devices list. The Bluetooth enabled device will no longer appear in the Select Device list.
Bluetooth devices are manufacturer specific. Please refer user manual for instructions on how to pair with other devices.
Oct 24, 2009 | RIM BlackBerry Storm 9530 Smartphone
Motorola Mobility H550 - Bluetooth Headset - Black/Silver Wireless Headset Logo
73 people viewed this question
Top Motorola Mobility Radio Communications Experts
Lawrence Oravetz
Dennis
Are you a Motorola Mobility Radio Communication Expert? Answer questions, earn points and help others
