Question about Vacuums
I need a manual for a Hampton Bay fan model S18P3. Would like to download it.
  • 377 Answers
SOURCE: My Hampton Bay ceiling remote
First, be sure you did not change one of the dip switches in the hand held unit while changing batteries. You would have to see if the switches in the hand held unit match the switch positions in the fan receiver.
This is one of the many sites you can go to for remotes:
http://www.lightinguniverse.com/fan-accessories_84.html
Hampton Bay fans are sold exclusively by Home Depot. I would check on line or stop by one of their stores to see if you can pick up a HB remote. Once you get a new remote you have to again make sure the dip switches are in the same position. Paul
Posted on Oct 11, 2010
GodBlessU
  • 3513 Answers
SOURCE: Receiver on Hampton bay the
First you need to check the housing mounted to the ceiling as the transmitter is there. Next you have to try and match it to a new remote or look for some number on the transmitter. However you can usually buy a new remote and transmitter for 30 bucks and just swap out the transmitter. This will be helpful in case you cannot match the numbers. They come labelled and r pretty easy to install. Please accept the solution if it's helpful. Do get back to us for any further query.
Thanks for contacting fixya.com
Posted on Oct 31, 2010
GBELECT
  • 23 Answers
SOURCE: I need to replace the
You can buy a fan remote at Home Depot, Lowe's,or Menard's basically any one of the big box stores. If they do not have the one used with your fan,you buy a universal remote. Follow the instructions in the box make sure you shut the power off as you may get shocked or burn up he control
Posted on Feb 01, 2011
Testimonial: "."
jim4984
  • 797 Answers
SOURCE: Reinstalling a hampton bay ceiling
The black and blue wire should conncect to the black wire in the electric box and the white wire should connect to the white wire in the box. This assumes the wiring was correctly installed.
Jim
Posted on May 12, 2011
mark24354
  • 776 Answers
SOURCE: changing frequency on a remotely
Remove battery from remote and you should see 4 small switches. Write down the pattern they are in now. Then move them to a new pattern. Then take the bezel off of the fan (where the fan connects to the ceiling). Turn the bezel counterclockwise if you don't see any screws holding it on. Now look for a set of switches that look the same as the switches in the remote. Write down their current pattern. Now Set the switches to a similar pattern as you set on the remote. If the remote doesn't work after adjusting, set them back to original positions from the notes you kept. Good luck
Posted on Jul 18, 2011
Trying to find a replacement globe that is transparnt or translusent for a hampton bay 31133-22
Hampton Bay (Home Depot) has a toll-free number for you:
(877) 527-0313 (Monday - Friday 8 a.m. to 6 p.m., EST)
Mar 02, 2011 | Vacuums
I need to replace the remote control (UC7083T) of my Hampton Bay Sidewinder 54 Ceiling fan. Could you pls tell me where to buy one? Thanks
Feb 01, 2011 | Vacuums
My Hampton Bay ceiling remote model no. UC7030T does not work. How can I get another one. My fan will not work without it.
Oct 11, 2010 | Vacuums
I have a 11 yr old Hampton Bay ceiling fan with light kit. The pull chain to operate the fan broke (evidently inside of the fan) and I cannot figure out how to fix it. Do I have to take off the light...
I'm unfamiliar with your exact model but your description makes it very similar to the "King of Fans" branded models I fitted in my house twenty years ago and have fixed a few times. It might even be that yours are made by the same company as Home Depot source their Hampton Bay range from a variety of manufacturers including KoF.
You are entirely correct that you can access the pull chain once you have removed the lamp assembly. If it's just the chain which has snapped then it's normally straightforward to remove the short piece from the switch and install what's left onto the switch, but if your chain is the typical ball and link type and is more than a few years old then replace it with a new one if you can obtain the right size easily. They're not expensive, and the old one will have wear and tear making another failure highly likely. If either of the switches has failed (the pull switch or the fan direction switch) then they're also usually easy to obtain from any electronics store at low cost or you can contact Home Depot regarding spares, also check here and here. Your total repair cost should therefore be no more than a few £'s, $'s or whatever else you use locally: far cheaper and quicker than fitting a new fan.
I hope that my reply has been of use to you and saves you a lot of time and money. Please take a brief moment to rate my answer.
Oct 07, 2010 | Vacuums
How to remove a Hampton Bay Cameron Plus Blue Ceiling Fan?
Hi.
Take the screws out of the sides of the top cover plate...drop it down, then unhook the wires and remove the screws holding the mounting plate...
heatman101
Aug 29, 2010 | Vacuums
Change direction of rotation?
Some fans have switch on the side or on the top by the ceiling.Steve
Jun 06, 2010 | Vacuums
Vacuums Logo
118 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
