Dell V505w will not print from computer - Computers & Internet
  • r_campbell33 Aug 25, 2010
    Dell v505w will not print from computer, I was talking with virtual about this can I talk to him
  • 4,472 Answers
How long have you had the printer? Have you ever had it working on your computer? If you have the printer installed I would delete it from the printers folder and reinstall with the latest drivers found at the following link, just select your OS and download the driver:
Thank you,
Lee
Posted on Aug 25, 2010
  • 4,281 Answers
First make sure usb cable is working fine. Then uninstall printer driver from control panel and uninstall all usb drivers from device manager then it automatic install all usb drivers. Then download driver for your printer from below link. Click here Click on above link and download driver and patch update then install in computer then it will work again. Let me know if you need further assistance. Thanks for using FixYa.
My Dell V510 printer will not print. I have checked the cables, I have checked the ink cartridges, I have unplugged the power supply, I have re-started the computer and nothing helps. Items in the print...
Try running Delete Print Jobs to remove any stuck print jobs in the queue.
Can you copy a document under the glass? B&W and color?
What is the correct model of the printer? V505 or V515? Dell does not have a V510.
You can try reinstalling the printer using the instructions located at...
Dell V505 & V505w All-In-One (PRODUCT) RED™ Printer owners thread (W7)
Dell V515w Wireless All In One Printer - (RED) owners thread
Virus programs and firewalls will block communications.
Rick
Apr 19, 2011 | Dell AllinOne Multifunctional (v515w)...
Tip
How to remove the tape from the ink cartridges? Received this error code after...
Procedures for clearing clogged inkjet cartridges and printheads
The following information may not apply to all inkjet printers, but it will sometimes save your cartridges, and might salvage the printer also.
Here's a trick I've used with some success. Depending on the cartridge, this is for carriage mount styles like HP, Lexmark, Canon (current models) and others. Remove the cartridge and soak the printhead portion, where the tiny jets are located, in a small shallow dish with clear alcohol. Try swooshing it around a bit, and you may start seeing a discharge of the ink color you're using. You may need to repeat the process more than once. Let it soak some more, dry it off and reinstall.
If the old ink is dissolved, then the cartridge may start printing, and it will be a little "weak" until the alcohol is mostly evaporated or used up. This is not a guarantee to work all the time, but it's worth a try. The "tank" style cartridges like Brother uses are another story, since they are reasonably priced containers with no printhead.
They have a tubular system feeding ink to the printhead on the carriage. Either the printhead nozzles or the tubes could become clogged, and require factory service, or a pretty elaborate set of disassembly procedures to clear the blockages. I have had mixed results, refilling an empty cartridge with alcohol, and allowing that cartridge to try feeding the tubular system, and dissolving the dried ink. If it succeeds, then simply install a new or known good cartridge, and the problem may be solved.
I hope these tips will give you a chance to get your printer and/or inkjet cartridges operating again.
Regards, Bill
on Oct 20, 2010 | Dell V505w All In One RED All-In-One...
Hooked the printer up via wi-fi and network but I can't get anything to print. router page says its there and the network page says its there, how do i get it to print wirelessly?
1 make sure you have installed printer drivers on your computer
2 your Dell printer should be set as deafult (Start -> Control Panel -> Printers -> right click on Dell printer -> "Set As Aeafult"
Mar 08, 2011 | Dell V505w All In One RED All-In-One...
I keep getting a message that says "wireless
The printer has the capability of making a "wireless" connection to your wireless router,
so that you can print to the printer from any computer connected (either with an Ethernet cable, or wirelessly) to your router.
Trouble with Dell printer V505w working with HP pc. Documents unable to print from printer.
go to printer and devices and ensure you have your dell printer set as default printer
Feb 07, 2011 | Dell Office Equipment & Supplies
I have a dell V505w red all in one printer. Keep getting a message alignment problem. Please remove tape from cartridge or check troubleshooting. There is no tape on cartridge.
print a test page, then place the printed test page on the scanner glass and press the scan button to align the catridges and see how it goes when you try to print again.
Nov 15, 2010 | Office Equipment & Supplies
I have Dell V505w wireless printer. It has worked fineuntil I replace my router with a new one. Now I can't scan anything to my computer. The orange light on printer blinks, indicating the printer is...
Either set the new router to the old router's IP, SSID, channel, key, etc. Or set the print server to the new router's network, SSID, channel, key, etc.
Feb 05, 2010 | Dell Computers & Internet
Computers & Internet Logo
46 people viewed this question
David Payne
David Payne
