Question about Telestar Meade Telescope
Where to buy parts for Meade Telestar 60az-s?
I need to find a user manual for a telestar by meade modle # 60AZ-A please and thank you.
You can download and print the instruction manual in PDF format by clicking this link.
Adobe PDF Reader is required to view this manual. Download Adobe Reader
Hope this helps. Kindly let me know if you have any difficulty in downloading the manual.
Thanks for using FixYa.
Apr 27, 2011 | Meade TeleStar 60AZ-A Telescope
BI need to replace some of the eyepieces...what did the 60AZ originally come with? and where can I purchase them?
You can buy eyepieces from many on-line retailers. Eyepieces come in 3 sizes .965, 1.25 and 2 inch sizes. The .965 size is harder to find. Measure the HOLE in the focuser or the diagonal and buy the correct size.
Here is one on-line retailer that sells eyepieces:
http://www.agenaastro.com/
Mar 30, 2011 | Meade TeleStar 60AZ-A Telescope
I need to find an Eyepiece for my grandsons TeleStar 60AZ-A
Most telescopes use a standard size for eyepieces (one and a quarter inches outside diameter) and if that is the size of the mount in your scope, you can use any that fit. If you do a search on Amazon, you will find hundreds in this size, many of them branded Meade. The other dimension specified will be focal length. 5mm will give high magnification (but dimmer and harder to use) while 20mm will give lower magnification with brighter image and less fiddly focus.
Nov 15, 2010 | Meade TeleStar 60AZ-A Telescope
I think i am missing parts. what connects the diagonal mirror to the focuser drawtube?
The diagonal simply slips inside the hole at the rear of the telescope. A small thumb screw secures it. The eyepiece then goes into the diagonal.
Sep 06, 2010 | Meade TeleStar 60AZ-A Telescope
I need the Eyepiece, Diagonal Mirrot and Focus Draw Tube for a Polaris Model 60AZ D=60 MM.
Contact Meade's customer service department here:
http://www.meade.com/support/index.html
Jul 03, 2010 | Meade TeleStar 60AZ-A Telescope
TeleStar 60AZ-A Telescope: need eyepiece holder...
You mean a DIAGONAL??? Like this:
http://www.agenaastro.com/GSO-1-25-90-deg-Mirror-Telescope-Diagonal-p/odia-gs-gsst.htm
May 18, 2010 | Meade TeleStar 60AZ-A Telescope
Meade telestar D=130 mm F=1020 mm
rosores: make sure that the DEC clutch is not locked, and that the screw on the side bar is loose.
before pointing it upwards. or damage may occur.
STH55
Sep 04, 2008 | Meade TeleStar 60AZ-A Telescope
Telestar Meade  Telescope Logo
349 people viewed this question
Top Telestar Toys Experts
Adam Fjeld
Adam Fjeld
Andrew Taylor
Andrew Taylor
Are you a Telestar Toy Expert? Answer questions, earn points and help others
