Question about Dryers
My dryer heats intermittently. I am unable to determine when the dryer will work. I have tried it on all the cycles and the problem still persists. Sometimes the dryer heats up and on completion the clothes remain damp and the dryer is cold as if it never worked. What can I do. I've had this dryer about six years now.
  • 5,911 Answers
<div class="solution-text"><span id="ctl00_ctl00_MainColumn_CenterColumn_ThreadSolutions1_Repeater1_ctl00_lblSolution"><span>If your ELECTRIC dryer is still running, but does NOT produce heat, the following two links can give you advice on how to troubleshoot an ELECTRIC dryer with a no heat problem:<br /><br /><a rel='nofollow' href="http://www.fixya.com/support/r3576548-dryer_runs_but_does_not_heat" target="_blank">http://www.fixya.com/support/r3576548-dryer_runs_but_does_not_heat</a> <br /><br /><a rel='nofollow' href="http://www.fixya.com/support/r3574266-thorough_dryer_advice" target="_blank">http://www.fixya.com/support/r3574266-thorough_dryer_advice</a><br /><br /><br />IMPORTANT NOTE: Your problem may or may not be related to a heating element problem as there are numerous factors that can cause a dryer not to heat. The heating element has protection devices that are designed to regulate the heat and internal temperatures. If the dryer overheats the Thermal Cut-Out (TCO) typically will blow BEFORE the heating element. The replacement kit is much cheaper than purchasing a new heating element that may or may not be the problem.<br /><br /></span><br /><span>Begin by unplugging the dryer and verifying the voltage at the wall receptacle. You should read 220-240VAC across the two Hot terminals (left and right slots). If the voltage is incorrect, check to make sure you don't have a breaker tripped. Some homes use 2 separate 120VAC breakers to provide power to the receptacle vice using one 240VAC breaker.<br /><br />If the voltage IS correct, leave the dryer unplugged and remove the cover plate on the terminal block in the back of the dryer (this is where the power cord is installed). Plug the dryer back in and take a voltage reading across the two hot (RED and BLACK) wires at the terminal block. You should read 220-240VAC. If the voltage is good, you have an internal heating problem. If the voltage is bad at the terminal block, but good at the receptacle, you have a bad power cord.<br /><br />NOTE: If the wires at the terminal block are not color coded, the outer two wires (left and right) are the hot leads. The center conductor is neutral or ground.<br /><br />The reason a dryer will still run if the input voltage is incorrect, is because the drive motor only uses a portion of the 220 service. The motor runs off 110-120VAC, while the heating circuits require 220-240VAC. So, if you are missing 1/2 your input voltage due to a tripped breaker or bad power cord, your dryer may exhibit these symptoms.<br /><br />If you determine the problem to be internal, the heating circuits will either be located in the rear of the dryer on the right hand, or under the dryer drum on the right hand side. Usually, an easy way to determine is by the location of the lint screen filter. If the filter is on top of the dryer, the heating circuits are in the back of the dryer. If the lint screen is in the door, the heating circuits are located under the dryer drum. If the model number you have listed is correct, your heating circuits are behind the rear panel on the right-hand side.<br /><br /><br />If either the TCO or Hi-Limit Thermostat are determined to be bad, replace BOTH components at the same time. That is why these components are commonly sold as a set. Failure to do so may result in premature failure of any parts you replace.<br /><br />Replacement parts (if required) may be found at the following websites:<br /><br />searspartsdirect.com<br />pcappliancerepair.com<br />appliancepartspros.com<br />repairclinic.com<br /><br />The average cost of these components varies, so shop and compare. The first three websites I listed have helpful exploded view parts diagrams that can help you locate and properly identify any parts you may need. The heating components are usually listed under the "Bulkhead" section.<br /><br /></span>If this is a GAS dryer, heating problems are most commonly associated with either a failed igniter on the burner assembly, or a blown thermal fuse.<br /><br /><span>If you have any questions, please post back with your MODEL NUMBER and let me know. I hope you find this information helpful.<br /><br /><br />NOTE: If your model number is not listed on some of the websites, use the part numbers from the Sears website and use that as your search criteria. Some model numbers will not reference on some sites, but the part numbers will.</span></span> </div>
Posted on Aug 25, 2010
  • Jeff Rockwell
    Jeff Rockwell Aug 25, 2010
    I apologize for the formatting errors. Reposting comments here to make it easier to read:
    http://www.fixya.com/support/r3576548-dr...
    http://www.fixya.com/support/r3574266-th...
    If either link fails to work, cut and paste them to your web browser.
    repairclinic.com
Intermittent heating on different cycles?
After a 12-year service life it probably is time to retire your Maytag dryer.
Feb 23, 2014 | Dryers
Error code Ad
Hello Rachael, thank you for your inquiry!
Typically error code AD indicates that the Auto Dry option has been selected. Typically when using no heat in any Auto Dry cycle will result in long drying times and/or wet loads at the end of cycle. I would suggest selecting another option or resetting your dryer. You may either unplug it or flip the household breaker off for approximately ten minutes. Turn your dryer on then select a normal cycle. Your appliance should resume normal operations. If this problem persists, your dryer may possibly have a faulty heating element, blower assembly or a communication problem with the control panel. This is not a normal DIY job. You may want to connect with a local servicer to determine the exact diagnosis. I hope this helps explain the error code you are receiving.
Nov 28, 2013 | Frigidaire GLEQ2152ES Electric Dryer
Kenmore dryer model 110 does not stop during automatic cycle
Make sure the small orange wire is connected to the 250 limit at the base of the heater assy. That is what powers the motor on auto cycle.
Nov 27, 2013 | Kenmore Dryers
Amana ned7200tw10 intermittent heating problem. New heating coil installed but dryer does not always run through heating cycle. Codes that come up are 2 and 10 when in diagnouses mode.
Sensors may be coated with waterproof wax from dryer sheets. Wash them with windex. The dryer not sensing moister it THINKS them clothes it dry. Cleaning the sensors works. Try it. The sensors will be behind the filter wall just below the filter on most sensor type dryers.
Feb 14, 2013 | Amana NED7200TW Electric Dryer
My dryer takes a long time to dry the heater kicks on and off intermittantly
A dryer is supposed to kick on and off intermittently as its dries. The heating circuits are regulated by a thermostat that will turn the element on or off as the cycle progresses. It also works in conjunction with a humidity sensor (if equipped with an "Auto-Dry" feature) to increase or decrease the heat depending upon the moisture level in the drum.
If your dryer is STILL heating, but you are experiencing longer dry times and/or poor drying efficiency, the following link can give you some items to check before you assume there is a malfunction with your dryer:
http://www.fixya.com/support/r3578821-dryer_takes_too_long_to_dry
The number one cause of dryer heat related problems is poor exhaust ventilation. If not vented properly, a dryer will not dry efficiently, will take longer than required to dry, and will cause the heating circuits to overheat to the point of failure. The dryer will actually seem hotter as the heating circuits begin to overheat. This is also the source of many fire hazards if not resolved. Read through the link provided and review some of the potential causes.
If you have any questions, please post back and let me know. Please include your MODEL NUMBER, so I can determine how your dryer is configured. I hope you find this information is helpful.
Jan 13, 2010 | Dryers
Dryer heats intermittently clcles off heat then
Try vacuuming lint and dust out of the burner intake and exhaust ports. Hope this helps!
Dec 05, 2009 | Kenmore 73952 Gas Dryer
Why dosent my dryer get heat
There is a sensor for detecting airflow. If the dryer is unable to exhaust properly it will shut down the heat for safety reasons. Be sure the exhaust vent is not obstructed, and that there is good exhaust air flow. If there is insufficient exhaust, find and correct that condition.
Hope this helps.
Mar 28, 2009 | Whirlpool LGR5636L Gas Dryer
Electric dryer intermittently doesn't heat
If your dryer has a timer with quick connects which easily plug into it then you can possibly fix this problem. Yank both connects off the timer and remove the timer. Take the 2 motor screws off and remove the plate carefully. Clean the contacts on each leaf switch with a file. Put it back and retry. Sounds difficult but it isn't. Remember only the timer with the 2 quick connects.
Dec 21, 2008 | Dryers
Dryer lights, heats up some but wont relite
Replace the coil packs on the gas valve this fixes 90% of gas dryers lighting intermittently. The bracket comes off and they are sold seperately from any appliance parts retailer.
This worked for my dryer.
Feb 06, 2008 | Whirlpool LGR5634L Gas Dryer
Dryers Logo
189 people viewed this question
Top Dryers Experts
