Question about PK Nextgrid BlackoutBuster B6U2 UPS System
Very old unit,I inherited from my brother 9 years ago and have used it without data cable (never even realized it had one til I started reading up!).Just quits working,no alarm,seems to be warmer than normal,resumes working after cool down.Moved from within desk compartment to top of desk for better air circulation.Still failed with no alarm.Is it my battery? Fuse looks good. Thank you Rebecca
  • 27,725 Answers
Try cleaning your computer out of dust either blow the dust out using a compressor make sure there is no moisture coming through or vacume it out your CPU will have dust all over it making it get hot
Posted on Aug 25, 2010
I have a Meade ETX-70AT scope that I inherited from a neighbor years ago. It came with two eye pieces (9 and 25 mm), a tripod, and an Autostar which I believe is the #494 model. On the bottom of the...
The hand controller cable is probably defective-- right at the connector that plugs into the scope. Any computer network "wizard" can replace the connector. The wires must be in the exact same sequence when he repairs it.
If this simple fix does not work and you KNOW that the batteries are good-- then the hand controller is defective and will need to be replaced.
Jul 04, 2011 | Meade 494 AutoStar Telescope Control Unit...
Tip
Unable to clean Error 46
Here's the instruction for ALL brother inkjet printers (mfc/dcp is equal) when printer shows unable to clean (error 46)
You need a new ink absorber box which can be purchased from a brother service partner near your home.
Search the brother homepage of your country:
www.brother.com (choose your country)
If you have got the spare part (ink absorber box) you have to open the printer:
http://www.hstt.net/refill-faq/inside.html#Brother_mfc215c
(use google for translation german)
Do NOT clean the old one! It cant be cleaned: The felt wont take up ink anymore and will stain the machine from inside and the furniture beneath the printer.
After replacing the eeprom of the printer needs reset:
(dcp: use arrow-up and set key to choose the digits. e.g. arrow-up til 8 then set arrow up til 0 then set
mfc: use the fax-number keys.
Stop-button will always go back to maintenance, if you have done wrong)
press menu then start bk-copy then fourtimes arrow up quickly after another.
machine will switch to maintenance mode and light(s) will flash.
press 8 0
press start bk-copy until PURGE 64xx
press 2 7 8 3
Purgecount will be 0000
Press stop
press 9 9 to leave the maintenance mode.
After the mfc/dcp comes up again in normal state the error has disappeared
on Apr 23, 2008 | Brother MFC 210C All-In-One InkJet Printer
My DP-48 CD Player is erratic. Sometimes it plays and can search, memorise, replay and do all I ask of it. Other times, it cannot even play the first track but keeps revolving over and over. Please...
same thing is happening with mine, its old asf and won't play a CD without skipping the entire way through, I recommend you just reset it by unplugging it for a day with the power button on, that might help reduce any static buildup in the ribbon cables. Anything from over 20 years ago will have many ribbon cables, which build up static causing electrical errors in the unit. I usually just turn it off for a few hours and then it works fine. But if that doesn't work, it's probably the spinning mechanism, since it's so old, the motor probably needs lubricating, if it's rusted or bent, then it is unfix able. I only recommend this if you didn't plan on taking it to a professional AV repair store. I hope you get to read this as I realize your post is from 7 years ago. good luck.
Dec 30, 2010 | Kenwood Audio Players & Recorders
I have inherited an old 'Brother' sewing machine with no manual
i have an old brother machine maybe back in the 60s-80s and the thread keeps coming out of the needle and i dont know how to do anything with the bobbin.i have no idea how to use the machine at all.i would love to learn any help.cant find any thing online to help.
Jul 07, 2009 | Brother LS-2125 Mechanical Sewing Machine
Clean unable 46
www.brother.com
press 8 0
press 2 7 8 3
Press stop
May 14, 2009 | Brother DCP 130C All-In-One InkJet Printer
Laptop monitor shutting off after after a few minutes
I have exactly the same problem though I have a toshiba laptop, after 3 years of intensive use i think the lcd is gone, cos it has nothing to do with os as it did the same even when entering setup. btw i used to let it 247 on like you did !
Jan 01, 2009 | Dell Latitude D600 Notebook
SONY DVD RW AW-Q170A not working....
one reason may be that your writer may be old and the lense must have died.
another is that the lense require cleaning.
the last one is that you need to upgrade the drivers and firmware for your sony writer which you will get here.
http://sony.storagesupport.com/models/21
If all the above things dont work, replace it.
Jun 30, 2008 | Sony (1-796-293-13) Plug-In Module DVD...
Brother Model DCP-117C Printer - Display Reads 'unable to clean see troubleshooting and maintenance chapter in user's guide'
you need a new ink absorber box which you can buy from a brother service dealer near your home (see brother homepage of your country). when done so open printer:
(use google translation german)
you have to rest the eeprom parameter, too
press menu then start bk-copy then fourtimes arrow-up quickly after another. machine will switch to maintenance mode. press by help of arrow up and set : 8 - 0. press start bk-copy til PURGE 64xx appears. press the sequence of 2 -7 -6 -3 (arrow up and set). PURGE will reset to 0000. press 9 - 9 to leave maintenance.
Apr 23, 2008 | Office Equipment & Supplies
Printer head cleaning
Sometimes a cart doesnt work well because of mal manufacturing. Put in another brandnew black cart and do the cleaning cycle again. Its an advantage to use genuine brother carts! If you dont have any success try this: press menu then start/mono (b/w) then four times arrow up. maintenance should be displayed and the printer beeps. press arrow up til 7 is displayed. press enter. press arrow up til 6 in display. press enter. Display: Cleaning_All. press arrow up til 3 then enter: power_p all. Press start mono. machine starts power cleaning. After maintenance is displayed press arrow up til 0 (zero) then enter then 9 then enter. machine prints print quality sheet. In case there are only a few blocks in black repeat the above procedure. If you doesnt see neither any blocks in bk nor text after the second try be sure that your printhead is clogged and cant be cleaned anymore. This happens due to thirdparty ink which has pigmented ink instead of dye ink. Use only dye ink for brother printers!!!
Sep 18, 2007 | Brother DCP-110C All-In-One InkJet Printer
Not printing too well
Do use genuine brother ink for testing: If you're lucky the filter in front of the nozzles (which is part of the printhead) is not clogged. Do the power cleaning twice: power up. push menu then start mono then four times arrow up. machine will display maintenance. push arrow up several times til 7 is displayed then Enter then arrow up til 6 is displayed. Push Enter. push arrow up til 3 then Enter: P cleaning_all Push start/mono. After machine has finished maintenance will be displayed. push arrow up til 0 (zero) then enter then puh arrow up til 9. machine will print a test sheet. Repeat procedure above if no good result. After three times without success the printhead is clogged due to wrong ink. ...and do use dye-ink only for brother printers (pigmented ink will clog the filter!)
Sep 14, 2007 | Brother DCP-315CN All-In-One InkJet...
PK Nextgrid BlackoutBuster B6U2 UPS System Logo
51 people viewed this question
Top PK Computers & Internet Experts
David Payne
David Payne
Are you a PK Computer and Internet Expert? Answer questions, earn points and help others
