Question about EliteGroup 865G-M8 (V1.0) (MB865GM8) Motherboard
Does a 865G-M8 motherboard support high density ram?
    Sergeant:
  • 203 Answers
Try using Crucial.com, if this Motherboard is still in your tower, allow Crucial system scanner tool to operate, so you can see what Ram is suited to your Motherboard. Hopefully on that site you can find out if you can use High Density,
if any joy with this please give me thumbs up thanks Ytee
Posted on Aug 25, 2010
Compatible video card for my motherboard ?
please download your driver to this url : http://download.driverguide.com/driver/865G-M8/Elitegroup+Computer+Systems/d1506465.html
Feb 20, 2011 | EliteGroup 865G-M8 (V1.0) (MB865GM8)...
Hi, I don't know if I should get single or double sided ram for this mother board, and is low density ram ok? Thanks, Wayne
This mainboard uses DDR400 memory
A High Density module is by far much slower than Low Density module at the same speed rating say PC3200/DDR400. High density modules are FAR CHEAPER, less than half the price when compare with low density modules and hence high density modules will NOT work on 90% of today's PC chipsets. LOW DENSITY modules have 100% compatibility with ALL systems and ALL chipsets. HIGH DENSITY modules only have 10% compatibility and are VERY SLOW.
So AVOID those 'High-Density - 128Mx4 config 1GB modules which is usually UNBRANDED and is NO NAME!
With this in mind it is far better to use low density Ram. Most RAM cards today are double sided, it all depends on the capacity of the RAM card.
Please rate this solloution as it it much appreciated.
Thanks.
Oct 31, 2010 | Gigabyte GA-8S661FXM-775 MATX MBD SIS661FX...
I am looking for driver motherboard intel 865g-m8
Check out Intel's Support page HERE.
If you check towards the middle right you can also use the Autodetect tool which works great ;)
Oct 28, 2010 | EliteGroup 865G-M8 (V1.0) (MB865GM8)...
I have 865g m8 board and wants to upgrade it to w7 how can i do thid
If you want to install win 7 you should be able to do it with just one problem. As old as the motherboard is you most likely will have a hard time finding drivers for onboard sound/modem and such. Windows should try to install some generic drivers to patch things up but that would be shaky at best.
Personally, I'd recommend a better system before worrying about Win 7. The 100 bucks or so that you would shell out for the os would set you well on your way to a better mobo/processor/ram setup.
Mar 21, 2010 | EliteGroup 865G-M8 (V1.0) (MB865GM8)...
What type of RAM is used in this..? either DDR1 or DDR2
ECS 865G-M8 (V1.0) supports:
DDR400/333/266 (DDR1) and supports up to 2 GB.
I hope it helped.
Jan 24, 2010 | EliteGroup 865G-M8 (V1.0) (MB865GM8)...
Planning to upgrade my RAM(motherboard K7SOM + V7.5C). Ram have high & low density. What is the difference? Which suit my motherboard? Thanks.
Look at the sticks of RAM -- "high" density means fewer chips on each side of the stick, i.e., newer technology and production methods have packed more bits into each chip, while "low" density usually means 8 chips/side, using older RAM chips.
Older motherboards do not expect to find "high" density RAM, and typically will only detect 1/4 or 1/2 of the RAM on the stick.
If you buy a new motherboard, it will support BOTH densities.
Oct 22, 2009 | EliteGroup K7SOM (K7SOM W/CPU) Motherboard
Km266-mnb Mother Board .... pc2100 ddr266 ram, will high density ram be compatible? Thanks
By this do you mean you want to increase the RAM on your computer?
I suggest you use PC2100 DDR RAM (same speed) and increase the total RAM to what your require but use the same RAM manufacturer if possible.
If you want to install more than 2Gb of RAM, check the motherboard specification for the maximum RAM that the motherboard can support.
Your motherboards may support more RAM with a BIOS upgrade.
Sep 06, 2009 | Azza Computers & Internet
Upgrade to ddr2 if it can done
no..
your board does not support DDR2 also called as JET RAM..
only DDR1 also called simply DDR SD RAM is supported..
Mar 21, 2008 | Computers & Internet
EliteGroup 865G-M8 (V1.0) (MB865GM8) Motherboard Logo
75 people viewed this question
Top EliteGroup Computers & Internet Experts
David
David
Matthew Spark
Matthew Spark
Jerry Umali
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
