Question about HP DeskJet 932c InkJet Printer
All of a sudden my hp 932c printer started printing funny in color. I was printing pictures and the prints came out like a heat resolution type picture. I then got new ink cartridges, it did not fix the problem. I have not used the printer in a while and I went to print just black and white ink and the ink cartridges move across the page like it is printing, but only a faint line here and there. I reinstalled cartridges and the check page was incomplete in print but all of the checks were as if everything was ok. I would appreciate any help.
    Sergeant:
  • 223 Answers
Quite often inkjet heads will dry up and clog. try a clean heads sequence in the printer properties panel. do this until it prints the clean nozzle page properly. If the ink cartridges have the print head attached to them (some dont) you can dab them on a paper towel with windex or vinegar until they show a nice clean line when dabbed. if you cant get the print heads out , then you just need to continue running the clean nozzel application until it prints the test nozzel job properly. This is the reason I will not buy any more inkjet printers. only Toner based machines. cheers.
Posted on Aug 25, 2010
Color cartridge runs out even though I'm only printing b&w typed scripts. Any way to shut it off? Only have use for color printing once in a blue moon Hewlett Packard HP DeskJet Printer #932C
Even though you print a b/w document... unless you say 'black cartridge only' in your printing preferences, all the colors get used.
Find 'black cartridge only' in your printing preferences, or 'print in greyscale' and then print your document. You must specify this for your printer to know that it must use the black only.
Jul 23, 2010 | HP DeskJet 932c InkJet Printer
I have a Deskjet 932c and it won't print in color black and white is fine though. I just bought a new cartridge and is still doesn't print color. Is it shot??
I use a small diameter silicone tube tocarefully "prime" stubborn new carts by sucking a drop of ink out ofthe tiny print holes in the printhead part of the cart. Ink can dry at the headand since these carts work by electrical excitation, there needs to be liquidof each color at the holes. Slap a drop of water with your finger on the holesto start easy hesitant ones. Do not get the contacts wet.
May 13, 2010 | HP DeskJet 932c InkJet Printer
I have just installed a new color cartridge into my HP Deskjet 932C. The only colors printing is pink. What can I do to solve this problem?
will you get to change the print color and by doing that you have look for the ink then when you fing go get ride of and put now one or I get any other way let me thing..
Apr 22, 2010 | HP DeskJet 932c InkJet Printer
I have an Hp deskjet 932C and it is printing VERY slow (a page every 6 or 7 minutes). It is also printing only in blue. I have changed both the color and the black ink, and I don't know what to do. Can...
I use a small diameter silicone tube tocarefully "prime" stubborn new carts by sucking a drop of each color ink out ofthe tiny print holes in the printhead part of the cart. Ink can dry at the headand since these carts work by electrical excitation, there needs to be liquidof each color at the holes. Slap a drop of water with your finger on the holesto start easy hesitant ones. Do not get the contacts wet. Slow printing can be port sharing or software conflicts, so try switching ports or switch from serial LPT1 cable to USB.
Apr 16, 2010 | HP DeskJet 932c InkJet Printer
One color does not print
Turn off printer and allow print carriage to park. Unplug printer. Using a cotton swab and rubbing alcohol gently clean the interface gold looking ribbon where the ink cartridges plug in. Allow to dry. Test printer with a test sheet. If that doesn't work, replace the control board. It might be just as cost effective to replace.
Aug 07, 2009 | HP DeskJet 932c InkJet Printer
My printer has an almost full black cartridge but will not print.
Check the ink lines, the printer head might be clogged, If thats not fixing anything then check your printer settings on the computer and remove the color option. Changing it to black and white can somtimes just be from color, not just black.
May 31, 2009 | HP DeskJet 932c InkJet Printer
Not printing color
Loks like there is a "well" under the "docked" position of the heads (at the right end of the unit, facing it - under the control buttons.) In my unit, ink had built up in this well to the point that some of the mechanical bits were scraping the top of the built-up ink pile. After I carefully removed about two TootsieRoll's-worth of old dried ink with a long scewdriver (using a flashlight to illuminate the area), the color printing seemed to be doing better. Can't tell yet if this has completely resolved the problem, as I have not yet printed enough pages to prove the point...
Nov 05, 2007 | HP DeskJet 932c InkJet Printer
HP DeskJet 932c InkJet Printer Logo
73 people viewed this question
Seeker5211
Seeker5211
