Question about Dryers
My admiral dryer LNC7753A71 just stopped working. Turning the timer only produces a clicking noise but all else appears dead. I checked the 240V outlet and its producing 240V and 120V on each side. The door switch appears OK. I performed a continuity check for when the door is closed and opened and that appears OK too. The light does not come on when the door is opened. I checked the voltage at the light connector and got 35V with the door closed and 45V when it is opened. The bulb is a 120v bulb. Is this voltage at the light connector correct? What should I check next to get this dryer running?
  • JACK955 Dec 19, 2008
    MY LNC7753A71 HAS POWER BUT NOTHING WORKS?
  • VAUGHTS Apr 30, 2009
    I am having the same issue with admiral dryer LNC7753A71
  • 3 Answers
Your dryer is equipped with a thermal fuse located behind the drum seat on the heating coil.
http://www.applianceaid.com/la-1053.html
There are two white wires connected to the fuse. Pull those off and connect together. Your door light will come on if that is your problem. There might have been a problem that caused the fuse to blow. Check for kinked dryer hoses, dirty lint traps or anything that might have caused it to overheat. You must replace the fuse or you risk catching the dryer on fire.
Posted on Mar 09, 2009
My dryer want stop it dtys fine but runs continually what could be causing this
Most likely the timer is stuck and not turning, if it stops when you open the door then it's the timer.
Jan 02, 2015 | Admiral Dryers
How to rewire my admiral dryer from 3 wires to 2 wires 240v
Your 3 wire cable should have 1 live, 1 neutral and 1 earth or ground. I don't see why the dryer has 2 wire setup. Unless you are seeing where the ground goes? Get an appliance engineer to check it or get an owners handbook. Don't take chances with electricity.
Dec 05, 2014 | Admiral Dryers
Admiral dryer timer not turning and no heat
It could be the high temp fuse on the element and the timer not turning depends doyou have it on the auto dry because it will not advance if it is not heating because the sensors are not detecting a decrease in the humidity levels because the element not working.
Mar 14, 2014 | Admiral 3.4 cu. ft. Top Load Washer in...
Admiral Dryer Model #AGD4475TQ No Heat
This is very rare on a gas dryer but I have seen it. If you have already replaced all that other stuff I would say it has to be inside the timer. On one I worked on once I could remove that orange wire and the dryer would function ok so I ordered a new timer, they sent me a bad timer. Same problem. I finally got a working timer after going through a bunch of mess. That fixed it. So if all the other components are working it very well could be the timer.
Dec 02, 2013 | Admiral Dryers
Admiral Dryer clicking noise
check fan cage can wear and need adjusting
May 30, 2012 | Admiral Dryers
Intermittently Drying Problems, Electrical?
It could possibly be electrical, check for 240V at the supply side. The only other possibility could be plugged dryer venting, although it would be unusual for it to cause only intermittent problems. The reason the timer would stop turning (mechanical timer) or counting down (digital display), is because on any Auto-dry, (ones that use the moisture sensor) the dryness of the clothing dictates when the timer should count down or advance. Check for good airflow from the outside exhaust point, if that's ok, I would be possibly looking at the outlet for possible loose contact, look at the dryer cord prongs and see if there are dark marks on them, as this may point to a sloppy outlet causing arcing.
Nov 28, 2009 | Frigidaire Electric Dryer
KitchenAid Dryer Timer stopped working - won't stop drying
Timers cannot be repaired. The mechanism is a spring - once it weakens, or fails - a new timer is required.
CLICK HERE for your part.
It is $83.72 USD.
Here is a Buy-it-Now eBay auction for $34.99USD & Free shipping!!
CLICK HERE
Your part number for the timer is 3976570a
A used part would have to come from an appliance store that salvaged from an abandoned washer.... and it may fail shortly anyway.
The new timer will have a warranty, and give you 10 more years of service.
Well worth it.
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
May 05, 2009 | KitchenAid KEYS850LQ Electric Dryer
Kenmore Electric Dryer 66812 clicking not starting
I hate to tell you this, but it is probably the timer. The good news is that it is easy to replace and you don't have to have a tech to do it.
Jan 05, 2009 | Kenmore 659 Electric Dryer
Dryers Logo
664 people viewed this question
Top Dryers Experts
