SOURCE: Year
Find the model production year, usually found on the same plate as the vin. Then add one year. For instance if the bike was produced in 2001, then its a 2002 model.
SOURCE: Oil
drain the fuel, locate the float bowl drain screw, lowest screw on the carb and loosen it to drain the carb. replace the fuel with proper pre-mix, replace the spark plug and it should be fine
SOURCE: front fork oil capacity
Hi
You can download the whole workshop service manual that has this info and heaps more from here. Hope this helps Thanks for using Fixya.
regards
robotek
SOURCE: 1993 yamaha yz 250 bareel damage
there's a company called Langcourt (www.langcourt.com) that specialize in barrel repair. i just had mine done there. i've also got a 1993 yz 250 stripped for parts if you're interested in anything else, unfortunatly i've already sold the barrel.
SOURCE: where can i download a free manual for a yamaha yz 426
Clymer, or Hayes make them, but a good one is the factory version from Yamaha. Maybe used from e-bay, but a dealer will have it.
