Question about Motion Computing M1400 Tablet PC
It won't charge anymore, when it's on it just doesnt say that it's charging, but the light on the charger is on. When it's off, the orange light for charging is on, but it still doesnt charge anyway. I live in the Netherlands so getting it fixed here is hard
    Genius:
  • 1,098 Answers
Had this same issue, the batteries do not tend to last that long if left to go flat over a period of time, in my case it was approx two months as I was out of the country, they are a pain to buy as not many retailers offer them online, however I did get a replacement although not cheap
http://barcodexpress.co.uk/tablets-computers/tablet-pc-accessories/motion-f5-additional-replacement-battery-p3877.htm
Can't buy direct from manufacturer as I'd tried with no success
Posted on Oct 17, 2014
My pandigital novel is doing the same thing like yours when its off the orange light turn on but when its on it doesnt charge any help
Posted on Jul 16, 2012
The computers contact point for the charging cord is "VERY" sensitive for me. I had to try many times to actually see the charging "icon" light up before letting it charge. Many times the icon would go back to "battery" during charge and I would have to re-try the connection again... Very annoying. If the battery get so drained that you can't see the "charging" icon, then it's a guessing game as to whether it's charging or not. I needed to re-install the OS and it took me 3 days to get my battery charged that way.
Posted on Nov 18, 2010
Why want my tablet charge Where do I return my tablet it will not charge anymore
Most common cause of this is faulty charger, the metal connector at end of wire won't connect properly to device charging port.
Test it by putting plug back in Tablet charger port and very very gently wiggle it around very slowly, see if the charging light comes on or flickers. They usually make a beeping noise when successfully charging or the screen lights up. If you get intermittent charging then it's the charger and time to get a new one. Very common, most are USB connectors or small pin types.
If it's still under warranty then send it back to the place you bought it before you try testing it.
Oct 07, 2016 | Tablets & eReaders
Kindle will not shut off-goes to shut off or cancel but wont move. doesnt charge well-doesnt always hold charge
Patricia, Using the power switch, you can forcibly reset your Kindle device. This reset will shut down the Kindle without accessing the shutdown command from within the Kindle's operating system, a particularly useful tool when dealing with a frozen Kindle. To initiate a hard shutdown, Kindle disconnect from its charger, slide and hold the power switch for about 20 seconds. This will force the Kindle to shut down, now it can be restarted normally.
Check links below for charging problems.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Reset Kindle Fire When it Won Turn on or Charge
Troubleshooting Kindle Fire That Won Charge
Kindle Fire not charging
9 common problems with the Kindle Fire HD and how to fix them
Feb 25, 2016 | Amazon Kindle Fire HD
MY DREAM TAB I LOST THE INSTRCTION ON HOW TO CHARGE BATTERY
Plug the tip of the USB charging cable into the power charger port and plug the other end into the USB Power Adapter. Plug the USB Power Adapter into an electrical outlet. You will know that it is completely charged when the orange light on the charge indicator turns green.
Jul 23, 2015 | Tablets & eReaders
I replaced the screen on the Asus tf300 tablet. After reassembly it wouldn't charge. I replaced the internal charger cable because it had bad pins. Plugged in the charger and got two flashing orange...
Hi, it seems that battery is totally discharged, that could be the reason of dead table. It should be good if you could check the connectors where the internal charger cable is connected, maybe one or both are damaged too.
Oct 20, 2013 | ASUS Transformer Tf300t Tablet
Nextbook 7 will not turn on
my pad was charging. charger went hot pad did too then it wouldnt turn on anymore nor will it charge.
Oct 04, 2012 | Nextbook Premium 7 Capacitive Touch...
MotorOLA XOOM battery won't charge
Keri
Maybe a bad charger.
Mark
Motorola Support
Mar 15, 2012 | Motorola Mobility Xoom
AC adapter/charger is attached, but the battery will not charge. it doesnt even show that the battery is there
Ifthe laptop battery is more than 3 - 4 years old then the battery could be wornout. Rechargeable batteries have a finite number of charge and discharge cyclesand will lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up atall. ORThe battery shows a 100% charge but when the adapter is disconnected thebattery drops off to zero capacity in a very short time. Ifthe battery drops to an unacceptable charge level then the battery needs to bereplaced.
Jun 21, 2011 | Toshiba Portege M200-S838 Tablet PC
Laptop wont charge
Orange means it's charging or connected vs. green means fully charged.
At least that's the way my battery charger is on my kodak camera.
Jul 28, 2010 | Compaq Tablets & eReaders
Motion Computing M1400 Tablet PC Logo
782 people viewed this question
Top Motion Computing Tablets & eReaders Experts
jason
k24674
Chris Larocque
Are you a Motion Computing Tablet and eReader Expert? Answer questions, earn points and help others
