Question about Motorola Mobility RAZR V3
Bluetooth unable to power up
Trying to power up BT on my Razr V3, phone will try to power up for about 10secs. and then displays "Bluetooth power failed"....HELP
  • 71firewalker Aug 31, 2008
    I try to power up bt and it says bt power fail.Ive tried a master reset didn't help.I took the battery and card out for several days,didn't help.
The bluetooth module on the phone is broken or the phone has an invalid configuration that prevents it from detecting the bluetooth chip.
Try to reflash the phone, if that doesn't work, the main board need's to be replaced.
Posted on May 05, 2008
Transfer pics frm moto razr v3 to laptop using bluetooth
Check your bluetooth connection with the PC and use Moto Tools suite to transfer photos . Other option is to simply make a connection with your PC and send photos one by one or mark all , send all to PC via bluetooth connection
Jan 04, 2009 | Motorola Mobility RAZR V3
Mazda bluetooth connection
delete all bt devices in your phone then try again
Oct 01, 2008 | Motorola Mobility RAZR V3
Bluetooth won't talk to my new razr
you need to give more info:-
you just press and hold the power button on the BT Headset for about 5secs , when the phone stop blinking and ahve a constant light on put your phone to search for it..when it does then pair using 0000 as the passcode
Jun 10, 2008 | Motorola Mobility RAZR V3
Bluetooth pairing on Motorola Razr V3
try to check the setting of your blutoot, check te find me option.
Jun 05, 2008 | Motorola Mobility RAZR V3c Cellular Phone
Bluetooth
Check out for the BT settings
Power should be ON.
Before trying to connect select Discoverable for 60 seconds.
Jun 04, 2008 | Motorola Mobility RAZR V3
RAZR V3 WITH PLANATRONICS BLUETOOTH
try a master reset of the phone or delete all BT devices in your list....hopefully this corrects the issue
May 26, 2008 | Motorola Mobility RAZR V3
Bluetooth module not attached !
try this,., delete old pairing for ur bluetooth, and re- pair it again...gudluck
May 10, 2008 | Motorola Mobility RAZR V3
Moto Razr V3 + H500 bt 'unable to connect'
have the firmware downgraded on the phone and that should fix the phone.
Mar 04, 2008 | Motorola Mobility RAZR V3
I can't get my phone to connect with other peoples
I assume you are trying to connect to another phone via Bluetooth. It would help quite a bit to know what kind of phone you are trying to connect to, but here is what you need to have configured on your phone for Bluetooth file transfers:
1. Create a link between your Motorola RAZR Phone and any Bluetooth Accessory 1.0 and up, you need to turn the Bluetooth connection "on". This is how: Go into your phone "settings". > Then select "Connection" > "Bluetooth Link" > "Set Up" > "Power" > "On". The connection will stay on until you turn it off. We recommend to turn it off when not in use to preserve battery life.
2. To connect your RAZR to another Bluetooth hands free kit or headset, go into "Settings" > "Connection" > "Bluetooth Link" > "Handsfree" > (Look for Device). You phone will scan for available devices located within the range of the RAZR, approx 30 feet away. If your cell phone is already connected to a Blue Tooth headset, you must disconnect from it to find other devices. Once you have identified your bluetooth device, highlight its name and click on the "select" button.
3. The Bluetooth device will ask permission to connect. Select "yes" and press the "select" button; after that you will be prompted to insert a PIN code to initiate a secure connection. The PIN code is usually provided by the Bluetooth device manufacturer, not the RAZR (unless you are connecting to another phone). Once the connection is made, you should see the bluetooth logo displayed on the internal screen, while the external screen Bluetooth indicator will flash.
4. You can now "Copy" media files to the phones nearby that you have connected to. Copy is an option while browsing through the files.
Dec 14, 2007 | Motorola Mobility RAZR V3
Can't connect with other peoples phone
Motorola Mobility RAZR V3 Logo
117 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
