Question about Electric Health & Beauty
My mobility scooter is fully charged but keeps cutting out
SOURCE: no life at all in classic 4wheeled mobility scooter
Have you checked your fuses with a continuity checker, they all my look OK, but Looks can fool you especially with the new type of two prong square colored fuses!
Posted on Nov 27, 2008
gewiz
  • 1271 Answers
SOURCE: pride mobility scooter. turn key on it keeps
Are you sure that it not in FREEWHELL mode, lever at the back, Regards
Posted on Jun 13, 2009
gewiz
  • 1271 Answers
SOURCE: Battery fully charged, buzzing sound when i try to
check the FREEWHEEL LEVER at the rear of buggy to make sure it in the drive position, if you can push the buggy it not in drive mode.
  • 92 Answers
SOURCE: I have purchased new batteries for my mobility
The control seems to be the issue. I have rewired so many scooters. When you have power and it wont go, it is usually the control. If you cannot afford the part right away, you can rewire it or have it rewired direct
Posted on Apr 06, 2010
  • 177 Answers
SOURCE: electric mobility scooter says charge is full but won't run
Hi. Most chargers should be connected to the scooter first before plugging into the wall socket. The charger senses the battery voltage to regulate itself. Your other answer suggested the circuit breaker, and this might be correct. Sone times the circuit breaker blowing can mean there is other faults such as a faulty motor. Many mobility scooters have plugs and sockets on the battery leads, and most are too light to carry the high currents. I have removed these from many machines and connected the leads straight to the batteries.
The third pin in the charger plug is to disable the controller in the scooter while the charger is connected.Good luck. Neil.
Posted on May 27, 2010
Does anyone know what a two beep error code means on a shoprider scooter? It runs for a short distance and then cuts out.
Hi Sara ,what is the bleep code , bleep then a pause then bleep , how many bleeps before a pause? or is it continuous ?
Regards
Rob
Feb 04, 2016 | Shoprider Health & Beauty
It cuts out, the light flashes, switch it off and back on it will go again, it seems to be ok on a long run but plays up when you have to keep stopping and starting. Batteries are fully charged.
Ken;
The lights flashing are a flash code, count the number of flashes and consult your owners manual. or you can repost. Make/Model are needed to get the best answer. Or check My app for answers. Scooter Doctor App .
check tire air pressure, make sure the rider is not over the weight capacity.
P.S. hope this helps.
I’m happy to assist further over the phone at https://www.6ya.com/expert/bill_bcbb89783b08c489
Dec 31, 2015 | Health & Beauty
How do I know if my scooter is full charge
The charger will cut out when the batteries are fully charge. Look for the green led on the charger.
Oct 10, 2014 | Electric Mobility Merits Pioneer 3 Hd ...
How to change batteries in a Rascal
The Rascal 600/300, remove the seat, lift off the cover, unplug a battery, replace the old battery with a new one, putting the cable connections on the same way, red is +, black is -. Do the same with the next battery, reconnect the anderson plugs,reinstall the cover and seat and plug in the charger with the key on watch to see the needle raises up toward the full mark, allow to charge fully, overnight is good. keep the bats charged up not allowing them to drop below half way for the first 20 charges to break in the batteries. as a rule charge the scooter after every use!
Scooter Doctor App
Jun 29, 2014 | Rascal 300 Electric Scooter - Used...
How many miles can I get from a fully charged Freerider Ascot 4 mobility scooter? My scooter seems to run out of charge after a few miles.
11 miles on full charged new batteries, this is approximately as condition change max distance, like you weight, if you are going uphill, how even the ground is etc. if you need more you could get a spare battery pack for it, and swap them over when needed. but remember to keep them charged even when not in use once a week is the best way to keep them in good shape.
Sep 09, 2013 | Health & Beauty
My scooter will not fully charge
This could be the charger socket is worn and not making a good connection when charging or it could be the charger itself at fault. Now you have changed the batteries, I presume new and both the same type, you need to look at the charging side.
Apr 03, 2013 | Rascal 600 T Electric Scooter w Seat Lift...
Not charging flat batteries
hi, most mobility scooter charges will not attempt to charge below 10 volts,
the trick is to use a car battery charger to bring the voltage past 10 volts then you use the mobility scooter charger to fully charge.
However please be aware of a couple of points:
1. Car chargers will damage mobility scooter batteries.
2. Once a Gel or AGM battery voltage has dropped below 10 volts they may never fully hold the charge again if they do recover and that's a big if.
Regards
Robin
GeWiz.
Feb 18, 2013 | Health & Beauty
My father-in-laws gogo will be not used for several months while he's in florida. how should the battery be stored/charged while not in use?
Charge the batteries fully and remove the battery pack from the scooter. About once a month charge the battery pack. It shouldn't take long to charge since you are not using the scooter Don't overcharge when the light on the charger turns green turn it off and unplug it from the battery pack. This should keep the batteries fully charged and fresh when FIL gets back home. Hope this helps you
Oct 04, 2010 | Pride Mobility Products Go-Go Elite...
I just bought a new battery charger cable called (Sealed Lead-Acid Charger) to replace an older (Lead Acid battery charger). The New Battery charger will charge for about 2 to 5 minutes and then stop...
ismail the charger you bought should do the job. By stop charging do you mean the light on the charger turns from yellow to green? Your scooter has small batteries 12/12 and don't require along period of charging. Now the scooter has a heat sensor for the batteries and will cut off charging when temp of the batteries gets too high. The older charger could have overcharged your batteries and made them weaker instead of stronger. I would suggest you replace the batteries (2 12/12AH) and charge them with the new charger. Remember to reinstall the heat sensors on each battery when replacing. If you have a digital voltmeter set it to 200 v dc and put the leads into the 2 outer plugs in the charger port on the battery pack. You should read 24-26 volts dc when the batteries are fully charged anything less would mean weak batteries. Hope this helps you
Oct 03, 2010 | Pride Mobility Products Go-Go Elite...
Health & Beauty Logo
203 people viewed this question
Top Electric Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Colin Taylor
Are you an Electric Health and Beauty Expert? Answer questions, earn points and help others
