Question about Uniden Um625c Marine Radio Fixed Mount
Hello , when I turn the VHF I don't get anything on the screen for one . Number two the dial to change the stations will not change . Number three the weather alert doesn't work when touching the button . Basically , what ever you want the radio to do it does not do . The radio has never been submerged I keep my boat on a trailer . I am clueless what to do . Please help ! Plus I have a hand held that needs work as well do to a ding dong on my boat .Thank you bstencel537@gmail.com / 954-253-4964 fort lauderdale Florida USA .
I have just bought a pure radio Elan E3 when I switch on it says no stations found
FM radio settings
Note: You can only see the FM radio settings when you have selected ‘FM’ as the radio source.
FM stereo option
You can choose between stereo or mono reception when listening to FM radio. Mono may improve
clarity where stereo signals are weak.
To change between Stereo or Mono reception:
1. Press the Menu button.
2. Turn and press the Select dial to choose ‘Audio Setting’.
3. Select between ‘Stereo Allowed’ or ‘Forced Mono’.
FM scan
You can choose whether your Elan E3 automatically stops at the next available FM station or the next
available FM station with a strong signal when scanning for an FM station. To change the FM scan
setting:
2. Turn and press the Select dial to choose ‘Scan Setting’.
3. Select between ‘Strong Stations Only’ or ‘All Stations’.
DAB settings
Note: You can only see the DAB settings when you have selected ‘DAB’ as the radio source.
Full scan
You can use the ‘Full Scan’ (autotune) function to automatically scan for new digital radio stations and
remove inactive ones.
To carry out an autotune:
2. Turn and press the Select dial to choose ‘Full Scan’.The number of stations found will be
displayed during the autotune.
When the autotune has finished, your Elan E3 will tune to the last station that you were listening to. If the
last station you were listening to is no longer available, your Elan E3 will tune into the first station in the
alphabetical list.
Manual tuning
To manually check the signal strength of a known channel:
2. Turn and press the Select dial to choose ‘Manual tune’.
3. Turn and press the Select dial to choose the channels.
Nov 07, 2017 | Elan Audio Players & Recorders
What does RF CH mean?
What is the difference between a RF channel and a virtual channel? The RF channel is the channel that the TV station uses to broadcast its signal. Before the conversion to digital, TV stations were normally identified by their channel number, and most people knew that a particular network was on a specific TV channel. While analog broadcasting was being phased out and all TV stations were converting to digital broadcasting, it was necessary for the TV stations to continue to broadcast their analog signals on their original RF channels, and also broadcast their digital signals on a different RF channel. However, since the TV station used their broadcast channel as part of their identification, they wanted to keep using the same channel number. To allow this to happen, the new digital television broadcasting standards (ATSC) provided TV stations the ability to continue to use their original channel number and also tell the TV set to tune to the new RF broadcast channel when their virtual channel number was selected. The original channel number is called the virtual channel number, and it will be followed by a period and a second number (3.1, 7.1, etc.).
One of the benefits of converting to digital for the TV stations is that they now have the ability to transmit more than one program at the same time on the same RF channel. The number of additional channels they can broadcast is determined by the resolution of the program (SD vs. HD, text only, music only, etc.). The second number in their virtual channel number indicates that one of the additional programming sources from the same TV station is being viewed (10.2, 10.3, 10.4, etc.).
When selecting an antenna, it is important to understand the difference between the RF broadcast channel and the virtual channel. Antennas are designed to receive specific ranges of RF channels, and the antenna needs to be selected for the RF channel you wish to receive. TV stations broadcast in two broad frequency ranges, called VHF and UHF. RF channels 2 through 13 are considered VHF, and RF channels 14 through 51 are considered UHF. In order to pick up the channels, the antenna has to be designed for the correct frequency range. It is very common today to find that TV stations using virtual channels 2 through 13 are actually using RF broadcast channels in the UHF range. Although not as common, some TV stations using virtual channels 14 through 51 are actually transmitting in the VHF range. An antenna designed for only UHF channels will not work effectively for RF broadcast channels in the VHF range, and an antenna designed for only VHF channels will not work effectively for RF broadcast channels in the UHF range.
Apr 09, 2015 | Televison & Video
Okay, here I am again, wanting to know how to add cable channels to my Hitachi C21 F800S TV. It currently only shows one channel, BET. Please help! Thanks!
1 Press menu button to enter the menu screens for the following optional adjustable settings.choose
2-tune
3-AUTO SEARCH (Activate to auto search & preset receivable broadcast stations)
-if it don't work change this
4Press menu button to enter the menu screens for the following optional adjustable settings.choose
5-tune
6-BAND (change the band system for tuning (i.e. VHF-L,VHF-H or UHF).
if VHF-L don't work try VHF-H or UHF and restart all over
good luck
Oct 05, 2014 | Televison & Video
I just got an Orbit 4 Station Sprinkler Timer with Easy Dial from the landscaper who did my sprinkler system a week ago, he set the timing at 6:30 AM I changed it to 5:45 and SET it and now its running...
You don't program each station. You only program one start time that begins the cycle that consists of the three stations.
Remove all start times but the first one and make that 5:45.
Set the station times to whatever you want, 12 minutes.
At 5:45, station 1 starts.
at 5:57, station 1 shuts off, station 2 starts.
at 6:09, station 2 shuts and station 3 starts.
at 6:21, station 3 shuts.
Your FixYa Texpert,
Gary
Aug 26, 2011 | Garden
I have forgot my phone lock password.
Hello.
Don't Worry just Dial this code on your Dial-screen.
*2767*3855#
Note: Don't forget to remove your sim and memory card before dialing this number. It'll reset all your factory settings.
Good-luck.
Apr 25, 2011 | Samsung Star GT-S5233 Cell Phone
HOW TO CHANGE LOCK COMBINATION IN A SAMSONITE LUGGAGE OYSTER GL
I forgot my locker combination and my luggage is locked.How can I open it??
Nov 13, 2010 | Samsonite Silhouette 11 Hardside Spinner
Cannot set my VHF & UHF stations on my 9 in Panasonic tv set from
hello there i have a link for the manual below please rate me if you find this info usefull thanx
http://service.us.panasonic.com/OPERMANPDF/PVV4022.PDF
Jan 27, 2009 | Panasonic PV-V4522 VHS VCR
D1232 Panasonic - Removing Long distance restriction
Changing the Class of Service COS of that extension to "1" will allow it to dial anything.
In a TD system, that is a 2-step process, because you have to find where the extenion jack is located in the system.
Go into programming and dial 003. If you press the SP PHONE button, it will step you through all the ports in the system and give you extension numbers. To start 01-1 will be 101 01-2 201 02-1 102 etc. Since you're in a motel, it should be renumbered to match the rooms and if you started with 100 or eliminated 113 your whole plan may be different.
Once you find the jack number for your station, press the HOLD button and dial 601 SP PHONE and the 2 digit jack number from above. You will be looking at your extension COS. Dial 1 STORE and it will turn off that extension's toll restrictions.
Please rate this solution and let me know if you had any problems following this instructions.
Carl
Dec 11, 2008 | Panasonic KX-T7453 Corded Phone
Hello
Volume + power resets it - making the player turn off lets you know that the reset work
Will it play non-radio music files fine?
Once again, when you change the radio station, you must press the play or right-pointing arrow button, or it will just continue playing the last radio station that you had it turned to
If it still won't change, then autoprogram the unit and select presets like it suggests in pp.32-35 of the manual
Jun 13, 2008 | Philips GoGear HDD6330 MP3 Player
Hello
Push "Dial-I/U" and hold for 1 second.
May 10, 2008 | Radio Communications
Uniden Um625c Marine Radio Fixed Mount Logo
62 people viewed this question
Top Uniden Boating Experts
Steve
Steve
Mike Marcotte
Mike Marcotte
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you an Uniden Boating Expert? Answer questions, earn points and help others
