Question about Focus Electronic Focus FK 9200 (FK-9200) Keyboard
Where can i find replacements for my fk9200. are any out there used or new?
  • 10,515 Answers
Unfortunately, this model is not available anywhere. Even sites like ebay do not have this specific model. There could be 2 options :-
1. Either wait and keep an eye on ebay if someone might sell their used keyboard or refurnished one by few dealers.
2. Look for an alternate programmable keyboard. There are many other models in the same series. If interested, get back with any model you wanted to take and i could tell you the place to buy.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Aug 25, 2010
How much will also hoover washer dryer HW130M cost me new and second hand please reply as have broke a friends and need to replace
its unfortunate that the owners blame u for breaking it? usually it will not break from one time use even if improperly used? Machines just break down all of a sudden, anyway as for new vs, old used, new is much to expensive to replace an old used one. and used should be around 100-150.00 some friends u have if u ask me, why are u replacing what may be easier to fix ? whats wrong with the old one?
Mar 28, 2015 | Hoover Washing Machines
Best way of replacing a caliper on 1999 dodge durango
jack the truck up , secure it so it can not fall down or roll away etc.
remove the wheel.
remove used caliper,
secure the used caliper to the strut spring with a wire or coat hanger..
hang the new caliper on the rotor.
remove the brake hose to the used caliper and apply to the new caliper.
Make sure brake fluid is full and cap is off of the master cyl. reservior.
open the bleader valve on the new caliper and let it gravity feed the fluid until full/overflowing.
place the brake pads on the new caliper and replace the caliper securely on the truck and replace the wheel.
bleed the brakes of any air.
Nov 28, 2011 | 1999 Dodge Durango
Mouse died, replaced batteries, led lit then immediately goes out.
Make sure that the batteries you replaced are new. Dont ever use batteries that are used up together with a new one. Try and replaced again the batteries and see how it goes.
Good day.
Jun 19, 2011 | Dell Wireless Keyboard Optical Mouse w0147
Camera says replace batteries even when fresh ones are installed
Sir/Maam,
Have you tried using new batteries? How long have you been using the old batteries? As far as i know, the longer you use a rechargeable batteries, the shorter its life(compared to the first time you used it).
Try using new batteries, if the problem is still there, the camera my have the problem. But if the camera works fine, then your old battery is defective.
Keep me update, hope i helped you. Thanks.
Feb 27, 2010 | Canon PowerShot S3 IS Digital Camera
The motor blew up, need to replace it. new or
A new motor will cost you 1000s . A used one will do if you are short on money. Places that sell used motors usually have a limited warranty on the motors they sell. They do a check up on the motor and refurbish it. they give you time to take it back in case it fails or anything else.
Nov 27, 2009 | 2001 Ford Windstar
My 99 gmc suburban has brake fluid leaking from the reservoir.Looks like its coming from under the reservoir. Does the res push in to the orings or are there screws holding it in
Most of them push in. It sounds as if the reservoir may have a hole or crack in it. If you replace this always use a new one not used. A used one could be contaminated and cause more problems than it repairs.
Aug 31, 2009 | 1999 GMC Suburban
Full ink cartridges reading as emty on cx5700f
Did you purchase new cartridges from the vendor of the printer (e.g. Lexmark, Canon, Epson or HP) or are you using refilled or third party cartridges?
If you are not using factory new cartridges, Please replace them with factory new ones and let me know if that corrects the problem.
If you are using factory new cartridges, contact the vendor and tell them you need defective cartridges replaced.
Don
Jul 14, 2009 | Epson Office Equipment & Supplies
Toshiba E-Studio 202L cartridge does not match manufacture
Did you replace the waste (used) toner cartridge or the empty toner cartridge? These copiers have 2 "cartridges" .... one is waste (used) toner, the other is "new" toner for copying / printing etc. Some newer copiers have All in One units....Drum, New Toner, Waste (used) Toner. If you replaced the Waste Toner container (or dumped it) that should reset the code or error message.
Jun 23, 2009 | Toshiba e-Studio 202L Copier
HP Photosmart 3310 printer shows all ink cartridges need replaced
If you ran the ink cartridge refill routine, from your desktop using the utility supplied by HP, this should not occur, so try running the head cleaning and alignment routines and see if this clears up the problems.
I am assuming that all your cartridges are relatively full and trouble free and that the printer has been successfully and recently used, prior to your replacement of the one new cartridge.
Sometimes, if the printer has been idle for some time without use, the ink will dry on the heads of perfectly good cartridges, causing the problem you cite.
Use alchohol based cleaner with the kind pads supplied with a new cartridge to regularly clean the heads of your ink cartridges, according to instructions in your manual and CAREFULLY, so as to not damage the heads.
Apr 07, 2009 | HP Photosmart 3310 Printer
A new motherboard for a old compaq presario 5240
You will need a new case and a new power supply. I would replace the memory as well.
Compaq had a tendency to make cases to only fit their boards back then. Youre better off building a new unit and starting over again.
Jun 14, 2008 | Compaq Presario 5240 (353200-003) PC...
Focus Electronic Focus FK 9200 (FK-9200) Keyboard Logo
Top Focus Electronic Computers & Internet Experts
David Payne
David Payne
Are you a Focus Electronic Computer and Internet Expert? Answer questions, earn points and help others
