Question about Fuji FinePix A360 Digital Camera
Have just brought a 2GB memory card but i keep getting a card error message.I have tried to format but with no success.Is the memory caard size to big for the camera as the last size was only 64MB?
  • 6,831 Answers
Hello
OK, if the memory card itself is locked, you might sometimes get this error code. All you need to do is to take out the memory card and switch the lever on the left side to the unlock.
If the error is still displayed after you did the above, you might want to try the card in another camera.
If the card works in another camera . the problem is with your card reader in your camera.
If you open you sd slot and look inside with a sharp light , you should be able to see on the left side of the slot there is a little copper or spring steel lever switch. This switch work as follows:
1. When no card is inserted / no write protection , the switch is open and thus the protection is off.
2. When locked card is inserted , the tab is depressed and tells the camera that the card is lock.
Contrary to popular belief ,the little tab on the sd card is not an electronic switch and does not physically influence the card operation itself. If you put a locked card into a camera without a sd lock switch , you would still be able to use the card normally.
It is incredible difficult to fix this switch because of space limitations in the sd card. Look into the sd slot and if you can see the switch , use a needle to pull the little tab down toward the base of the camera by about 2mm or until it works being careful not to bend it.
If this does not resolve your problem , there might be a short in the switch circuit and the camera will need to be disassembled to resolve this error. This should cost no more than $50.
Please feel free to contact me if you need further information
Kind regards
Andrea
Posted on Aug 26, 2010
Memory card error
Make sure you're using SD cards. If the cards are larger than 2GB then they're actually SDHC cards. While they fit in the slot they are electronically incompatible and will not work. You need to use SD cards, 2GB and smaller.
Aug 05, 2012 | Pentax Optio MX Digital Camera
Memory card error
I have a sandisk 2gb micro sd card. I put it into my computer's card reader and it keeps saying it needs to be formatted. When I try to format it it says windows was unable to complete the format. I am...
The FORMAT process is trying to write data to the card, but that writing is NOT successful,
i.e., the memory on the card is damaged/defective, and so it "fails".
Responsibly recycle the card, and purchase a replacement memory-card.
Jan 30, 2011 | SanDisk 2GB microSD Memory Card
I need to get my photos in my memory card, if i connect to pc and when i open it so " please Format" how get my photo from memory card
The dread "not formatted" error message generally indicates memory card problems. This can occur for many different reasons including a computer virus, memory card problem, power surge, or problems with the operating system. If you receive this type of error message, it is important that you act carefully to keep your important data safe.
1. Do NOT click "Yes" to format this memory card in case that the formatting process makes things worse.
2. Do NOT attempt to write anything new on this memory card in case of any data loss.
3. Download a memory card data recovery freeware to help you out:
http://www.freeware-fix.blogspot.com/2013/03/memory-card-recovery.html
In fact, this freeware has ever successfully saved all the inaccessible data of my friend off from his camera. So, I believe it can also work successfully on your camera memory card, too.
Simply read more information of this freeware here:
http://www.freeware-fix.blogspot.com/2013/02/photo-recovery.html
4. Do not save or back up all the restored data on the same memory card in case of any data loss.
5. After the data recovery process, simply format this memory card to see whether it can work functionally as before.
In the future, you should learn a lesson to be more careful about your data and always back it up well.
Dec 18, 2010 | SanDisk 2GB microSD Memory Card
Hi there. i have a canon ixus 30 camera. i brought a brand new 4gb memory card for it. when i put it in the camera it says 'memory card error'. i read somewhere that formatting it helps but when i tried to...
Many people are unaware that the newer SDHC format cannot be used with most older cameras. Your camera was manufactured well before the SDHC format came out. I'm sorry, but there's no way that a 4GB SDHC card will work with your camera, it just doesn't understand the new format of the card. The max size card that you can use with your camera is a standard 2GB SD card. More info may be found at this link.
Nov 18, 2010 | Canon PowerShot SD200 / IXUS 30 Digital...
I brought a SD 2GB Memory card for my mobile phone but it asks me to format and when I click yes is says Error
This memory card is corrupted please change this memory card by dealer where u brought this card.
Nov 06, 2010 | SanDisk 2GB microSD Memory Card
My camera won't accept new 2GB SD card. Keep
Do you have pics on the internal memory? You must format the internal memory with no card in the camera. Then, format the card.
Jun 07, 2010 | Kodak EasyShare C310 Digital Camera
Error message on a brand new fuji camera memory caard
It's possible that your camera can't take the memory card. If it is one of the newer 2-4GB cards, some of the older camera's firmware limits their memory card size. You may check the Fuji website and see if you can download upgrade software for your camera. This will up the limit of the capacity you can use. You hook up your camera to your computer and use the Fuji software to upload the firmware update. Good luck.
Aug 05, 2009 | Cameras
Card Error Message
the error message is because the 2gb sd card is not supported (is too big for the camera)
try 1gb sd card and it should be fine
Jul 17, 2008 | Samsung Digimax 4010 Digital Camera
Sd elite pro 2gb
What is the error message you are getting?
Have you formatted the memory card?
Jun 09, 2008 | Canon MV730i Mini DV Digital Camcorder
Fuji FinePix A360 Digital Camera Logo
32 people viewed this question
Top Fuji Cameras Experts
Greg Cann
Greg Cann
Steven Wander
Steven Wander
Are you a Fuji Camera Expert? Answer questions, earn points and help others
