Question about RIM BlackBerry Bold 9000 Smartphone
Blackberry 9000 smartphone - says bluetooth disabled - and when go into options to enable bluetooth - the screens says enabling bluetooth but nothing further happens
  • 277 Answers
Hi, reset phone after resetting phone if nothing happens,Go to blackberry sites for update.
There are three main types of Reset that apply to the Blackberry. These are listed in order below. Instructions for Blackberry Pearl are slightly different - see bottom section of the Tip.
1) Soft Reset - simply press the ALT+RIGHT SHIFT(CAP)+DELETE keys.
This reset stops all applications that are running on the Blackberry and will help if you are having problems connecting the device to computer. This reset will not erase any information from your device.
2) Double Soft Reset - this reset is almost equivalent to a full hard reset. First perform a Soft Reset as outlined in Step 1.
As soon as the screen is no longer black - repeat the steps once again exactly as before.
This takes you to another screen showing an hour glass. Allow the device to reset. This helps if the device has suffered a more serious error. Be aware you may loose some information from your device. A backup is advised prior to proceeding if at all possible.
3) Hard Reset - this is the full blown reset and will fully reset the device to help resolve critical errors with software or hardware. Again back up important information before proceeding if possible.
Note: For RIM models 850, 857, 950, or 957, you must insert the end of a paperclip or similar blunt object into a small recessed hole on the back of the unit and depress the switch inside. The device will reboot and be hard reset.
Other Models: With the device turned on - remove the battery for 30 seconds or more. Now replace the battery. The device will reboot and be hard reset.
Blackberry Pearl: To reset to factory defaults enter 'Options' from the main menu. Scroll to Security Options and press the trackball. Choose 'General Settings'.
Press the left soft key, then scroll to "Wipe Handheld" with the trackball and press the trackball. To initiate the factory reset, your phones security code may be required in order for the process to complete. Your phone will now be restored to its original settings on leaving the factory.
A hard reset can be achieved with the Pearl in the same way as outlined at Step 3 by removing the battery.
Be aware that resets such as these may erase data, such as contacts, ring tones, pictures, text messages and stored Internet files and emails. Make sure to back up important information beforehand if at all possible. You can obtain software to back up the device to your computer directly from Blackberry right here.
Hope this Tip helps. If so please do leave a vote for the solution.
Thanks.
Posted on Aug 25, 2010
I have a blackberry 8520 and I downloaded yahoo messanger on it but when I try to sign in it sayd this service is not enabled for this handheld. Please what do I do to make my yahoo messanger work
Hello go to the instance message icon look for the yahoo message see if you have downloaded on your phone. You need to hit the blackberry key you should get a menu that has options on it. In the options folder you have to enable the yahoo message by hitting enable . You may need to be walk thru the proess. The options menu should give you full menu on it. ok HOPE THIS HELP
Nov 06, 2010 | RIM BlackBerry Bold 9000 Smartphone
Tip
How to turn Bluetooth on and off on a BlackBerry Tour
The BlackBerry Tour comes with Bluetooth capability, but in order to connect to a Bluetooth device, you have to enable the Bluetooth functionality. When you're not using a Bluetooth connection, disable Bluetooth to avoid other devices from connecting to your BlackBerry.
- To turn Bluetooth on:
From the main home screen, press the BlackBerry button (to the left of the trackball) to go to your Home folder. Scroll down until you see the antenna icon for Manage Connections and click on it. A pop up list will appear; find Bluetooth on the list and click it to put a check in the box next to it. "On" will appear next to Bluetooth, and the Bluetooth icon will be displayed in the upper right corner of the screen. Your BlackBerry is now in Bluetooth mode, where it can connect and pair with other Bluetooth-capable devices.
Bluetooth can also be turned on from the Options folder, under the Home folder. Select Bluetooth from the list and when the screen comes up saying "Bluetooth: Disabled," press the BlackBerry button and then select Enable Bluetooth. If you've previously paired your Tour with other Bluetooth devices, the list of those devices will appear.
- To turn Bluetooth off:
From the home screen, press the BlackBerry button. Scroll down to Manage Connections and select it. In the list that appears, click Bluetooth to uncheck it and disable Bluetooth functionality.
You can also turn Bluetooth off by clicking Options in the Home folder, selecting Bluetooth from the list of options, then pressing the BlackBerry button and choosing Disable Bluetooth.
on Jan 14, 2011 | RIM BlackBerry? Tour 9630 Smartphone
Yahoo messenger not enabled in blackberry bold 9000 "service not enabled in this handheld".
Hello.
The way out to solving this problem is that you should contact your service provider and also check your phone setting .
Good luck.
Mar 12, 2010 | RIM BlackBerry Bold 9000 Smartphone
I have blackberry 8110 and it ask me for a passkey
Blackberry 8110
Bluetooth technology troubleshooting:
Common Problems
I cannot type a passkey on a Bluetooth enabled device
If you cannot type a passkey on a Bluetooth® enabled device, the passkey might already be defined.
On your BlackBerry® device, in the Enter passkey for <device name> field, try typing 0000.
My list of paired Bluetooth enabled devices does not appear
Try performing the following actions:
• Verify that Bluetooth® technology is turned on.
• Verify that you have added Bluetooth enabled devices to the paired Bluetooth enabled devices list.
I cannot pair with a Bluetooth enabled device
• Verify that your BlackBerry® device is compatible with the Bluetooth® enabled device. For more information, see the documentation that came with the Bluetooth enabled device.
• Allow the Bluetooth enabled device to discover your BlackBerry device. In the Bluetooth setup application, click Allow another device to find me.
• Turn off encryption for Bluetooth connections between your BlackBerry device and the Bluetooth enabled device. In the device options, click Bluetooth. Click a Bluetooth enabled device. Click Device Properties. Change the Encryption field to Disabled. Press the Menu key. Click Save.
I cannot share contacts with a paired Bluetooth enabled device
• Verify that your BlackBerry® device is paired with the Bluetooth enabled device.
• Verify that, in the Bluetooth options, the Address Book Transfer field is not set to Disabled.
• Verify that your BlackBerry device is connected to a Bluetooth enabled device that supports the Handsfree profile or the Object Push profile. For more information about supported profiles, see the documentation that came with the Bluetooth enabled device.
If you found this information helpful, please give me a big thumbs-up when you rate my answer. Thank you.
Feb 01, 2010 | RIM BlackBerry ® 8830 Cellular Phone
Data connection refused
After cancelling the data plan with the wireless service provider, the message Data connection refused appears at the top of the Home screen on the BlackBerry smartphone instead of the branding of the wireless service provider.
This is caused may be you were previously subscribed to a data plan through a wireless service provider, and the BlackBerry smartphone is still configured to attempt to access the data network.
To resolve this issue, you need to turn off the Data Services feature on the BlackBerry smartphone. To perform this, you need to complete the following steps:
  1. From the Home screen, open the Options menu.
  2. Click on Mobile Network or Network.
  3. Set the value of the Data Services field to Off.
  4. Open the menu and select Save.
  5. Return to the Home screen.
  6. Turn the wireless transceiver off and then on again.
To enable (turn on) the wireless transceiver on the BlackBerry device, go to the Home screen and select the Turn Wireless On icon or open Manage Connections and select the wireless connection to be enabled. Once enabled, the icon will display Turn Wireless Off .
To disable (turn off) the wireless transceiver, go to the Home screen and select the Turn Wireless Off icon or open Manage Connections and select the wireless connect to be disabled. Once disabled, the icon will display Turn Wireless On.
I Hope it helped you.
Thank you for using ' Fixya ' and have a nice day!!
Nov 17, 2009 | RIM BlackBerry 7290
How do i connect bluetooth
Please try this simple steps
1. From the BlackBerry smartphone home screen, select the Options icon.
2. Select Bluetooth.
3. Highlight the Bluetooth and press the Menu key enable it.
4. Select ADD devices option and then connect..
I hope this information is helps
Nov 10, 2009 | RIM BlackBerry Curve 8310 Smartphone
How can i set the em227pk bluetooth up for pairing? plz help.
In order to pair a BlackBerry smartphone with a Bluetooth enabled device (e.g. a Bluetooth enabled headset), the Bluetooth enabled device must be in pairing mode. Most Bluetooth enabled devices are not set to pairing mode by default. Refer to your Bluetooth enabled device manual for instructions on how to set the Bluetooth enabled device to pairing mode.
To pair the BlackBerry smartphone with a Bluetooth enabled device, complete the following steps:
1) On the BlackBerry smartphone, click Options > Bluetooth. If you cannot find the Bluetooth option,
2) Open the menu and select Add Device. The Select Device list appears and lists Bluetooth enabled devices that are in range and available to be paired.
Note: Only BlackBerry smartphones enabled with Bluetooth technology that are in range and in pairing mode will appear in the available Select Device list.
3) Select the Bluetooth enabled device with which you are pairing. The Enter passkey dialog appears.
4) Type the passkey to authenticate the Bluetooth enabled device. Most Bluetooth enabled devices contain a hard coded passkey. See your Bluetooth enabled device manual for the passkey.
Note: 0000 is the universal passkey for pairing any Bluetooth enabled device with a BlackBerry smartphone.
Note: Once a Bluetooth enabled device is paired, it appears in the Paired Devices list. The Bluetooth enabled device will no longer appear in the Select Device list.
Bluetooth devices are manufacturer specific. Please refer user manual for instructions on how to pair with other devices.
Oct 24, 2009 | RIM BlackBerry Storm 9530 Smartphone
Cannot play Blackberry 9000 mp3 files on Bluetooth devise
Complete the following steps:
1) Use a search engine or a dedicated download site to find and download a third-party conversion tool. The tool must have the ability to convert the format of the audio or video file to a file format that the Media application can read.
2) Install the third-party conversion tool and follow the program instructions to convert the audio or video file to a format that the Media application supports. Refer to the following tables for optimal settings in the Media application.
Optimal settings for the Media application on the BlackBerry 9000 series smartphones:-
For video setting's
a) Video format: MPEG-4.
b) Video file extension: .avi
c) Resolution (4:3): 240x180
d) Resolution (16:9): 320x180
e) Video bitrate: 400 Kbps
f) Frames per second: 24
For Audio settings:-
a) Audio format: MP3
b) Audio bitrate: 128 Kbps
c) Sample rate: 44 kHz
d) Channels: 2 (Stereo)
Transfer the audio or video file from the computer to the BlackBerry smartphone using one of the following methods:-
1) Using BlackBerry Desktop Manager.
Note: BlackBerry Desktop Manager 4.2 must be installed on the computer.
  1. In BlackBerry Desktop Manager, open BlackBerry Media Manager.
  2. Use the Media Manager tool to transfer the audio or video file to the BlackBerry smartphone using a USB connection.
  3. Copy the files to the appropriate folder (either \blackberry\Music or \blackberry\Video) on the media card, or directly to the internal BlackBerry smartphone memory.
Note: Files larger than 3 MB cannot be transferred to internal BlackBerry smartphone memory.
2) Using the BlackBerry smartphone as a USB mass storage device:-
  1. On the BlackBerry smartphone, go to Options > Advanced Options > Media Card.
  2. Make sure that Mass Storage Mode Support is set to Enabled.
  3. Connect the BlackBerry smartphone to the computer and follow the prompts on the BlackBerry smartphone.
  4. Open the My Computer folder on the computer. The media card should appear there as a Removable Disk.
  5. Copy the files to the appropriate folder (either \blackberry\Music or \blackberry\Video) on the media card.
Using a media card reader
  1. Make sure that the media card reader is connected to the computer.
  2. Insert a media card into the media card reader.
  3. Open the My Computer folder on the computer. The media card should appear there as a Removable Disk.
  4. Copy the files to the appropriate folder (either \blackberry\Music or \blackberry\Video) on the media card.
  5. Insert the media card into the BlackBerry smartphone.
Oct 24, 2009 | RIM BlackBerry Bold 9000 Smartphone
Bluetooth doesn't reconnect to my Jaguar handsfree
This might solve your problem; go on your blackberry and check in your bluetooth device list for your Jag's handsfree once you've found check the properties of it make sure it says "yes" under the trusted option now if that doesn't work then you need to check in the same properties if "encryption" is enabled if not enable it and you might not have to manully enter it all the time now if it already says enable you could try to disable encryption just to see if that helps. If you have any more questions or more information on this situation just post back and I will gladly help you some more.
Cheers,
Kyle
Jul 08, 2009 | RIM BlackBerry Bold 9000 Smartphone
Blackberry 7100g cell phone
i don't remember how i connected mine, check directions that came with the bluetooth. i think i turned the bluetooth on first, then add device. i know you need a # from the bluetooth to put into the bb. usually 0000 or 000 (cant remember) for motorola.
Feb 16, 2008 | RIM BlackBerry 7100G Smartphone
RIM BlackBerry Bold 9000 Smartphone Logo
Top RIM Cell Phones Experts
Computer Repairing
Computer Repairing
Longtime User
Jason
Are you a RIM Cell Phone Expert? Answer questions, earn points and help others
