Question about Acer Aspire 4315 Notebook
When you turn on the laptop, the screen comes up black and white .. then it shows with broad lines of green and purple.
  • 734 Answers
Here's the best way to troubleshoot your problem.
1. Connect your laptop to an external monitor. If you don't have a desktop PC at home, ask to use a friend's monitor. If your laptop will display normally on the external monitor, then you know your problem is only the LCD screen or the Screen Inverter which is a small slender controller circuit panel connected to the bottom of the screen behind the bezel (the plastic frame covering the edges of your screen.
2. If the laptop shows the same problem on the external monitor as it does on the laptop's screen, then your video chip is failing on the motherboard, and you'll either have to send the laptop to a motherboard repair company (many are listed on eBay) or the motherboard itself will have to be replaced.
Note: Some comapnies on eBay have a flat rate of 125.00 or less for this repair. However, if they cannot repair it, they send your laptop back and refund the fee. If your laptop needs a new motherboard, you may have to make the decision to just purchase a new laptop if you find the cost of the replacement too high to make sense.
Good Luck!
Posted on Aug 25, 2010
  • tcandy69 Aug 25, 2010
    Thank you for your help .. am thinking now the laptop is shot .. ;(
Screen black or with lines/check
The camera has a system control board problem, this controls all the key operations of the camera. Unfortuneately cost to repair would not warrant the expence to persue the matter.
Mar 04, 2012 | Ricoh Caplio R6 Digital Camera
I need a wiring diagram for a pioneer deh-27mp cd player... thanks
red is 12 volt line that turns on with the key- the yellow is the 12 volt that stays on regardless of the key- the blue provides 12 volt to turn on an amp or to raise the antenna- the grey is the front right + speaker line-the grey with black right front speaker negative-white left front speaker + white/black is left front speaker negative- green is left rear speaker + green/black is left rear speaker negative purple is right rear speaker + purple/black is right rear speaker negative DO NOT GROUND THE SPEAKER NEGATIVE WIRES
Apr 10, 2011 | Car Audio & Video
Need Wireing diagram to hook up a Wire Harness to a Kenwood BT645U to a 2000 Jeep Grand Cherokee
2000 Jeep Grand Cherokee Stereo Wiring Constant 12V+ Red/White Switched 12V+ White/Red Ground Black Illumination n/a Dimmer Orange Antenna Right Front Front Speakers 6" x 9" Doors Left Front (+) Light Green/Red Left Front (-) Light Green/Green Right Front (+) Light Blue/Red Right Front (-) Light Blue/Black Rear Speakers 6 1/2" Rear Door Left Rear (+) Dark Green/White Left Rear (-) White/Dark Green Right Rear (+) White/Purple Right Rear (-) Tan/Dark Green
Kenwood Wires:
Red: Switched 12volt
Yellow: Constant 12volt
Black: Chassis Ground
Blue: Not used
Light Blue/Yellow: Steering wheel control
Brown: Mute Control
Blue White: Power Antennae (or Amplifier remote turn on)
White - White/black: +/- left front
Gray - Gray/black: +/- right front
Green - Green/Black: Left rear
Purple - Purple/black: right rear
Dec 21, 2010 | Car Audio & Video
I need to know the color coded wires for a car stereo, pioneer deh1500. whats speaker colors, power colors and constant power
The power color is red,the negative lead is black,the constant power is yellow.Now for the speakers ,the white lead is the + and the white with the black line on it is the - wire ,grey wire + and grey with black line wire - ,green wire + and green wire with black line wire -,purple wire + and purple with black line -.Hope that clear your mind.
Dec 09, 2009 | Pioneer DEH-1500 CD Player
How do I get rid of purple and green wiggly lines? The black screen that appears when switching between channels was green a couple of weeks ago, that problem stopped after I unplugged the set for a while....
You have a bad LCD control board,It overheats and causes colored lines,screen to darken,or the color go floresent. Also check the power supply for bad caps.
when you have it apart.They usualy go bad on these tv's. It will cause the tv to take longer to come on.Or you have to hit the power button several times to get it on.
Oct 26, 2009 | Samsung LN-T4061F 40 in. LCD HDTV
Need a wiring diagram for a radio on a 93 Explorer. The speaker wires in my truck are Green, Purple with white stripe, yellow, blue w/white stripe, Lt. Blue , Orange w/white strip, brown, and red w/white...
Constant 12V+ Green/Yellow
Switched 12V+ Yellow/Black
Ground Black
Illumination Blue/Red
Dimmer n/a
Amplifier Remote Blue
Antenna Right Front
Front Speakers 5" x 7" Doors
Left Front (+) Orange/Green
Left Front (-) Blue/White
Right Front (+) White/Green
Right Front (-) Green/Orange
Rear Speakers 5" x 7" Rear Doors
Left Rear (+) Pink/Green
Left Rear (-) Brown/Yellow
Right Rear (+) Orange/Red
Right Rear (-) Black/White
THanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Sep 08, 2009 | JVC KD-G210 CD Player
Wiring diagram for a Clarion CZ109
Clarion uses the industry standard wiring colors. Not every unit will have all of the listed wires
SPEAKERS:
White = Left Front +
White/Black = Left Front –
Gray = Right Front +
Gray/Black = Right Front –
Green = Left Rear +
Green/Black = Left Rear-
Violet = Right Rear +
Violet/Black = Right Rear –
POWER/ACCESSORY:
Yellow 14ga = Battery Main/Memory
Yellow 18ga = Battery CeNET Power/Memory
Red = Accessory (ignition on)
Black = Ground
Blue = Antenna Turn On +
Blue/White = Remote Turn On (amps) +
Orange/White = Dimmer
Brown = Phone Mute
Orange or Mint Green= Parking Brake Video Lockout
White/Red = CCD (camera) input instant on +
RCA Cables:
Gray = Front Output
Black = Rear Output
Purple = Non-Fade or Subwoofer Output
Aug 29, 2009 | Clarion CZ109 Car CD Player
Laptop screen has been invaded by green and red/purple germlins
haveyou tried shutting it down and restarting it? it may just be the screen going bad
Jan 26, 2009 | JVC AV-48WP30 48" Rear Projection...
Wiring pinout
Mar 31, 2008 | Pioneer DEH-27MP CD Receiver w/ MP3/WMA...
My camera will only take pictures of a purple screen
Sounds like a defective CCD imager. You may be in luck. Canon should fix this for you for free, including free shipping both ways. Please check the following two links for more info:
http://camerarepair.blogspot.com/2007/11/canon-digital-cameras-showing-black.html
http://www.usa.canon.com/consumer/controller?act=PgComSmModDisplayAct&fcategoryid=225&modelid=13390&keycode=2112&id=29819
Applicable cameras include:
A40, A60, A70, A75, A80, A85, A95, A300, A310, S1 IS, S60, S200, S230, S330, S400, S410, S500, SD100, SD110
Oct 28, 2007 | Canon PowerShot A85 Digital Camera
Acer Aspire 4315 Notebook Logo
59 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
