Question about Minn Kota Endura 30 Freshwater Transom Mount Trolling Motor
Dear Sirs, I run a fleet of boats driven by Minn kota 30 engines. After time the switches burn out. Do you know why? We then replace the switches with new ones and they will only last a few hours before they burn out. What is going wrong, please help. Nigel Woodhouse
  • 4,924 Answers
the first thought for me is that things are heating up due to too much amperage being drawn by the motor or a loose connection.you will needs to check the specs on that motor to tell and need to know what normal readings are which minkota will gladly supply you.
but ..cause it happens to more than one ..it means that the switches you use..are not fit for the amperage this motor is working with ..Call the support (number is on the motor) ..and see what tip they recommend...
Posted on Aug 25, 2010
Only have a model number and need to order a Minn Kota electric motor propellor
Minn Kota go by the thrust which is mentioned on the top plate. I got mine off Craigs List as well.
  • Minn Kota Prop Compatibility Chart - TrollingMotors.net https://www.trollingmotors.net/blogs/selection/86967623-minn-kota... Minn Kota Prop Compatibility Chart Minn Kota Prop Charts. ... Minn Kota with a serial number and they can recommend a compatible prop for your older Minn Kota motor. ...
  • Minn Kota Motors www.minnkotamotors.com Prop Selection & Part ... Electric Anchor Winches; Shop All; APPAREL. ... A combination of a Minn Kota motor and foot controlled rudder steering allow you truly ...
  • Trolling Motor Replacement Props - Minn Kota www.minnkotamotors.com/Accessories/Trolling-Motor-Accessories/... Minn Kota builds the world's toughest ... Electric Anchor Winches; Shop All; APPAREL. Mens; Ladies; Youth; Shop All; WHAT MOTOR DO I NEED? LET US HELP YOU ...
  • Minn Kota Replacement Propellers - www.fishntech https://www.fishntech.com/minn_kota_propellers.html ... Minn Kota Electric Trolling Motor Replacement Propellers & Nut Kits, ... Minn Kota Replacement Propellers . ... Minn Kota Electric Trolling Motor Replacement ...
  • Minn Kota props replacement props for Minn Kota www.minn-kota.com/minn-kota/minn-kota-propellor/page/2 Minn Kota Replacement Props for propellor Weedless Wedge 2 Props ... Minn Kota MKP 3 Prop 2061151 ... MinnKota Trolling Motor Power Center $57.58; DeckHand Electric ...
  • MINNKOTA MKP 37 2091170 TROLLING MOTOR PROPELLER ' ... www.ebay.ca/sch/...nkw=MINNKOTA+MKP+37+2091170+TROLLING+MOTOR+P... Find best value and selection for your MINNKOTA MKP 37 2091170 TROLLING MOTOR PROPELLER ... MINNKOTA MKP 37 2091170 TROLLING ... MINN KOTA ...
  • Jun 08, 2016 | Minn Kota Endura 30 Freshwater Transom...
    What is the amp draw of the motor, so i can buy the right battery for a minn kota endura 30 trolling motor?
    You will need a 100 to130 amp hour deep cycle marine battery. Check prices of many brands in your area. (WalMart, Autozone, boat dealers,ect.)
    Sep 16, 2010 | Minn Kota Endura 30 Freshwater Transom...
    My Johnson Escape boat w/ Minn Kota engine stopped running
    I've had the same problem. It steams from the control panel. I took and ran a seprate ground wire directly to the motor. This is simple to do and takes 15 minutes. Starting in the battery compartment feed cable into the split-loom and continue feeding until reaching the control panel. Pull an extra 5 foot of cable and open dry hatch in rear by motor feed cable around and out to motor connections., Good time to replace rotary switch and circuit breaker. These also are trouble-some parts.
    Aug 01, 2010 | Minn Kota Boating
    Old outboard ground wire melting
    1. Short in the trolling motor itself
    2. TOO SMALL a ground wire. ..need at least 8 gauge wire!!!!
    3. Bad/dirty/corroded battery connections
    ..Make sure your battery/trolling motor is not accidentally touching the metal boat.. DO NOT CONNECT ANY WIRES TO THE BOAT!!! - PERIOD!!.
    Sep 11, 2017 | Minn Kota Maxxum 70 Freshwater Bow Mount...
    Got the Endura 30 from my wife for Christmas. Hooked it to the boat,a 12 foot MirroCraft and tested with battery and overall check, looks good so far. First time in the water on Monday, May 24, made it 30...
    have you called the dealer or returned to the store your wife bought it from. they should be the ones to warrenty the motor. if she bought it used then you need to buy the necessary parts from a suitable store and move on. minn kota is a good company and they make a good product. i do understand your frustration. you might ask for a manager at minn kota if your wife brought it new and she if you can successfully get a better answer on an appeal. good luck.
    May 28, 2010 | Minn Kota Endura 30 Freshwater Transom...
    Endura 30 Freshwater Transom Mount Trolling Motor: I JUST PURCHASED A Pellican pontoon boat 10e and i...
    probably an endura 50 would be a better fit for a potoon boat. assuming the boat is normal size. if its a smaller one then this motor might work just fine. give it a try and see if it moves you about fast enough for your taste.
    May 15, 2010 | Minn Kota Endura 30 Freshwater Transom...
    I need Minn Kota Power Drive operators Manual
    I'm installing a Minn Kota Power Drive 70# on my Crestliner Fishhawk. I understand the 24 volt system. however the boat has 2 black, an orange and a red wire running to the batteries. I know black to neg. but where do the orange and red wires go.
    Jun 09, 2009 | Minn Kota Maxxum 55 Freshwater Bow Mount...
    I have a Minn Kota Endura 30, transom mount. Just wondering, is there a way to rotate the controls so that I could use the motor on or near the bow of my 15' Aluminum fishing boat?
    There is kind of a collar on the lower side of the head where the head connects to the shaft. There is a single bolt that runs right thru the shaft at this location, remove it. Rotate the head 180 degrees and re-install the bolt. 5 minute job.
    Mar 10, 2009 | Minn Kota Endura 30 Freshwater Transom...
    Minn Kota Endura 30 Freshwater Transom Mount Trolling Motor Logo
    70 people viewed this question
    Top Minn Kota Boating Experts
    Mike Marcotte
    Mike Marcotte
    Andrew Taylor
    Andrew Taylor
    Colin Stickland
    Colin Stickland
    Are you a Minn Kota Boating Expert? Answer questions, earn points and help others
